ARB Summit Bumper is awesome but a pain to install
Discussion in '2.5 Gen Tundras (2014-2021)' started by Marshwalker, Feb 16, 2020.
  1. Sep 15, 2021 at 9:24 AM
    #91
    t-bear
    t-bear New Member
    NE Okla
    2019 Tundra CM SR5
    Soon to be 4WC Raven host. Mods to come.
    @Mallcrl
    Thanks for the advice here and below on mounting the DD SS3s to the ARB bumper. Is this the Paranoid Fabrication brackets you used (it states for Tacoma ARB bumpers and "similar")?
    https://www.paranoidfabrications.com/products/arb-fog-light-mounting-bracket-1
  2. Sep 15, 2021 at 11:18 AM
    #92
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '21 DC SR5 SX
    Akaklutz likes this.
  3. Sep 15, 2021 at 11:35 AM
    #93
    t-bear
    t-bear New Member
    NE Okla
    2019 Tundra CM SR5
  4. Sep 18, 2021 at 3:57 PM
    #94
    t-bear
    t-bear New Member
    NE Okla
    2019 Tundra CM SR5
    @Mallcrl
    Thank you for your help and advice. Some more questions please:
    1. Are you using Diode Dyanmics Tundra Specific Fog Lamp replacement SS3 (https://www.diodedynamics.com/ss3-led-fog-light-kit-for-2014-2021-toyota-tundra.html) or the standard SS3 pod - Round or Angled? (https://www.diodedynamics.com/off-road-auxiliary-led/led-pods/ss3.html)?
    And thank you for the Paranoid Fabrication link. I just need to know which version of the SS3 you went with...
    2. The ARB bumper instructions have you installing the fog lamps AFTER the bumper is installed on the truck. From the instruction pictures it appears you have a lot of room to work.
    So... from your experience would it be OK to add better LED fog lights at a later time using the Paranoid Fabrication aftermarket brackets? Or is the fitment and adjustment of the aftermarket brackets best done with the bumper OFF the truck?
    Question -
  5. Sep 18, 2021 at 10:29 PM
    #95
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '21 DC SR5 SX
    @t-bear
    Happy to help! So my SS3s are the generic round bezel, not the angled bezel that comes with their Tundra-specific kit (FWIW, I used them with the Tundra brackets on my OEM bumper, but I had purchased them for use with an aftermarket bumper on my 4Runner, and then sold that truck before they arrived)
    The fog lights definitely go in as the (nearly) last piece of the puzzle. Since I've done it 2 or 3 times, I can probably have both fog light assemblies (the entire piece that slides in) out of the truck within 5-7 minutes at this point. The longest time is taking the two lower "wing" panels off the underside of the bumper, but that's still only 2 minutes a side. I initially installed mine with the cobbled together brackets, then literally the next day my Paranoid Fab brackets arrived, so I took the assemblies out again, reassembled, looked at it, removed again to swap out the DRL/turn LEDs, and reassembled. Consider yourself warned, you'll hate the screws that hold the assembly into the bumper by the end of it.
    My "trick" for adjusting beam pattern was to mount the lights to the ARB assemblies, and then pop them in the bumper (without putting the screws in, they stay in place pretty well); make whatever aiming adjustments are necessary and then pop them back in and tighten them down. To be extra safe, flick them on one more time before you put the lower wing panels on as a just in case check of aim.
  6. Sep 19, 2021 at 8:42 AM
    #96
    t-bear
    t-bear New Member
    NE Okla
    2019 Tundra CM SR5
    @Mallcrl - Awesome thank you sir! You've been a big help not only to me but others here as well.
    Mallcrl likes this.
  7. Oct 20, 2021 at 5:31 AM
    #97
    MDUplander
    MDUplander New Member
    Looking to purchase this bumper soon and just wanted to see if those that own it could answer the following questions. Is it possible to add a winch after the bumper is installed or would the bumper need to be removed first? Saw this was asked earlier in this thread but never saw an answer, can you remove the grill/headlights with the bumper on or would you need to remove the bumper first? Is it possible to just remove the bull bars to do any of the above? Thanks in advance, can’t wait to get this.
    equin likes this.
  8. Oct 20, 2021 at 8:06 AM
    #98
    Fergie
    Fergie New Member
    Having installed my winch backwards initially, I can say for certain that yes, you can remove and install a winch after the bumper is mounted; you pull the lower valence cover piece and have plenty of room.
    I cant speak to the other parts of your post,.
  9. Oct 20, 2021 at 8:40 AM
    #99
    MDUplander
    Great to hear. Thank you.
  10. Nov 1, 2021 at 5:29 PM
    #100
    Fergie
    Fergie New Member
    These are the two female connector ends...finally got around to getting pics of them....C19 and my MH clinic have kept me crazy busy...
    Ideally, I'd like to have a pigtail adapter that goes betwixt the two without cutting...where can I find this?
    Thanks!
  11. Dec 27, 2021 at 11:17 AM
    #101
    Occidentalis
    Occidentalis Out Snakin'
    North Florida
    2015 Inferno TRD Pro
    For those of you with the summit bumper, have you tried fitting diode dynamics lights in place of the standard fogs? Trying to figure out what I need to do after an accident. Ss3 max from the old bumper into it is what I'm trying to do.
  12. Dec 27, 2021 at 12:28 PM
    #102
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '21 DC SR5 SX
    Scroll up a bit, I used the paranoid fabrication mounts
  13. Dec 27, 2021 at 12:51 PM
    #103
    Occidentalis
    North Florida
    I thought I had read this entire thread three times but missed that. Thanks. Going over it now. I currently have the angled assemblies
    Mallcrl[QUOTED] likes this.
  14. Dec 27, 2021 at 8:45 PM
    #104
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '21 DC SR5 SX
    I think the angled housing would work, but they are fairly inexpensive and easy to replace with the regular round versions
    Occidentalis[QUOTED] likes this.
  15. Dec 27, 2021 at 10:03 PM
    #105
    Occidentalis
    North Florida
    I bought a set of the brackets you linked and I'm thinking I'll go with a new pair of the lights with the backlight because the housing got hit pretty hard and I don't really know the extent of the damage. The ss3 in round with the standard generic bracket is what you got to fit, right?
  16. Dec 27, 2021 at 10:14 PM
    #106
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '21 DC SR5 SX
    Exactly, fits great
  17. Dec 28, 2021 at 9:02 PM
    #107
    Occidentalis
    North Florida
    Thanks! At which piece of the puzzle does the winch go in? Trying to determine if I can do it myself after the bumper goes on or if it has to be part of what happens at the body shop. Planning on cutting the level on my harbor freight apex. From the instructions I see for the tacoma bumper it looks like they have you put it in before mounting the bumper on the vehicle.
  18. Dec 29, 2021 at 9:11 AM
    #108
    Fergie
    Fergie New Member
    Winch, at least my Smitybilt XC, can be removed with the bumper installed, and reinstalled. I know this because I installed mine backwards and had to redo it after the bumper was in. Pretty easy to do from the bottom.
    Occidentalis likes this.
  19. Dec 29, 2021 at 9:15 AM
    #109
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    Sounds difficult. lol
  20. Dec 29, 2021 at 6:58 PM
    #110
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '21 DC SR5 SX
    You could probably replace the winch without pulling the bumper depending on the size of the motor/housing; but that would be a huge PITA; specifically because of the foot front mounting (there's nothing for it to rest on while bolting it in)
  21. Jan 7, 2022 at 6:33 AM
    #111
    Luke_Skywalker
    Luke_Skywalker New Member
    Luke
    2020 Tundra TRD Pro
    Eibach TRD Pro Front Springs, Dirt King UCA's Coachbuilder +3 shackle (poly bushings)/carrier bearing drop, steering upgrade, bumper shims, White Knuckle Sliders, Leitner Designs, Baja Designs, Switch Pro, Victron Solar, BORA 1.25", BFG KO2s, Wheelers Superbumps, VLED interior lights, 12" Sub, Window Tint.
    Heeeeavyyyy! Just like the 200 plus pounds i have from my ARB on the FJ. Styling wise, gotta be my favorite. I wish they made an aluminum version for vehicles, I’d spring for that in a heartbeat! Looks good!
  22. Jan 7, 2022 at 6:42 AM
    #112
    Fergie
    Fergie New Member
    Definitely wasnt fun, and doubly so since it was my own dumbass that got the orientation knackered. Triple so in that I had already clocked the housing, and had to re-clock it after pulling it off.
  23. Jan 17, 2022 at 12:41 PM
    #113
    t-bear
    t-bear New Member
    NE Okla
    2019 Tundra CM SR5
    What specific hawse are you guys using? I see the preferred is an "offset" hawse that is extra thick.
    I know ARB wants to sell me a hawse mounting kit which spaces a hawse further out from the surface area of the recessed hawse/fairlead "pocket" (so at an angle, the synthetic rope won't get abraided).
    https://sleeoffroad.com/products/sof1113/
  24. Jan 17, 2022 at 12:56 PM
    #114
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '21 DC SR5 SX
    ARB Hawse mounting kit + Standard ComeUp hawse fairlead... I purchased the Factor55 1.5" fairlead and it is entirely too wide for the opening.
    That being said, the ARB mounting kit isn't absolutely necessary, but bumping it out further does help in the event of a less-than-straight-line winch pull
  25. Jan 17, 2022 at 12:58 PM
    #115
    t-bear
    t-bear New Member
    NE Okla
    2019 Tundra CM SR5
    @Mallcrl Thank you again. I will mark the Factor 55 off my list - much appreciated. I am going to skip the ARB hawse adapter kit and just go with a thicker hawse.
    In your opinion, is the 1.5" thick hawse the correct thickness to eliminate the ARB spacer?
    Tundra18overland likes this.
  26. Jan 17, 2022 at 3:03 PM
    #116
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '21 DC SR5 SX
    If I had to guesstimate, the spacer/plate that makes up the ARB kit is probably 1" thick; so if you can fit a 1.5" thick hawse in there, that would work.
    I know that with the Ironman bumper (almost a direct knock off of the ARB) on a GX, the same issue of fairlead width comes into play, and I know of at least two people (with those trucks) who took cut down their "thick" fairleads to fit the width constraints
    t-bear[QUOTED] likes this.
  27. Apr 27, 2022 at 10:45 AM
    #117
    t-bear
    t-bear New Member
    NE Okla
    2019 Tundra CM SR5
  28. Apr 27, 2022 at 10:48 AM
    #118
    Occidentalis
    North Florida
    Any thoughts from any of you why the installer left out the factory tow / recovery points on my install?
  29. Apr 27, 2022 at 11:09 AM
    #119
    Tundra18overland
    Tundra18overland Traversing the million mile road
    Jesse
    GA
    2018 SR5 CM Expedition Build
    Not sure. They shouldn’t have had to be removed or manipulated.
    Easy to just bolt back on though?
  30. Apr 27, 2022 at 11:12 AM
    #120
    Occidentalis
    North Florida
    I think so? It looks like the factory skid plate on the pro interfaces there so I'll have to see. In the shop for 35 hours and it still needs winch electrical hooked up, winch reclocked, wiring to bumper turn signals is loose, no fairlead, no recovery points.
