Ask the Toyota mechanic!
Discussion in 'General Tundra Discussion' started by T-Rex266, Aug 15, 2015.
  1. Feb 1, 2017 at 7:59 PM
    #661
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Hey Jace, hope the home buying is going smooth. Question for you regarding ZPC. Have a 15 CM 4x4 with 2-1/4" lift in front and lowered 1-1/4" in rear. Extremely different angle than stock, so I took it to the dealer and had them do a ZPC. I assume they plug into the ODB port and do this. How long does the procedure itself take and what exactly does it tell the computer ? Is it giving it a new stance calibration ? I am changing the stance of the truck again, bringing the rear back to stock and the front up another 1/4" or so. How important to get it done again ? Thanks much.......
  2. Feb 1, 2017 at 8:36 PM
    #662
    Thegr8punkin
    Thegr8punkin A G.D.M/Sofa King Cool/COTJ's dreamboat
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    Should be a 22 like the rest of the 08+ tundras
    sprtbkr likes this.
  3. Feb 4, 2017 at 5:07 PM
    #663
    SoCalTundra213
    SoCalTundra213 New Member
    07 Limited DC
    14 Limited CM - Entune just hangs at Loading Maps and Waiting For Bluetooth. Anyone ever experience that? Any fix? Tried disconnecting tje battery. No go. #LOTSOFTOYS any insight? Thanks in advance for your time.
  4. Feb 6, 2017 at 6:45 PM
    #664
    Joeshaker
    Joeshaker New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    Lotsoftoys, I had you do the zero point calibration on my 13 s couple weeks ago. Does that do anything to the traction control system? Or is there something else that needs to be done to adjust for the bigger tires? My truck makes an awful noise going through downhill turns and the trac light comes on. No sign of rubbing and completely grinding noise free with the nannies off. It didn't do that until the tires, no Ill effects after the lift with stock tires. I've got the nitto exo grappler 285/70/18's, 34x11.5 E rated. So, 2" taller and .5" wider. I've been going through the forums and am not seeing much about guys having this problem, even those running even bigger tires and more lift.
  5. Feb 6, 2017 at 6:47 PM
    #665
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    By the way, the truck drives way better with the alignment dialed in! And the jam nut tight on the tie rod, haven't gotten around to giving firestone crap about that!
  6. Feb 6, 2017 at 7:03 PM
    #666
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
    U stock UCA's? I had that issue on my 2012. Only occurred at certain angles.
  7. Feb 6, 2017 at 7:19 PM
    #667
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Yeah, I'm on stock ucas with 6112's on top setting. 285's on stock trd wheels. No sign of rubbing and I can slide my fingers between the tire and uca. I went to a spot where I could park at extreme angles today and moved the wheels and tried different angles and am no closer than when it's parked on flat ground. It is only doing it with the steering wheel turned about 1/4 turn going into turns when the truck leans, same in rt. Or lft turns at around 30 mph or so. The truck really doesn't lean much with the rear sway bar and bags. And no rubbing noise with nannies off. Could just a very slight rub be the cause, so slight that it's not noticeable with the nannies off? Cv joint issues that are only noticeable with the nannies off? It is really loud and sounds horrible!
  8. Feb 6, 2017 at 7:24 PM
    #668
    Look for rub marks on the uca. What you described is exactly what I had. It only did it on certain angles turns - such as one particular freeway on-ramp that was twisted in nature
  9. Feb 6, 2017 at 7:29 PM
    #669
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    I've checked for marks on ucas and the inside of the tires. Can't see anything. Can you do something like the tire inflation chalk test to see it better?
  10. Feb 9, 2017 at 12:09 PM
    #670
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    I would wait until u have it where u want it to do the zpc. It takes half hour and yes it tells the computer, this is the new zero point of where the truck sits.
    Tsb, bring it to the dealer
    So Trac is kicking in when turning sometimes still? Are u on the gas???
    CM-LENNY[QUOTED] likes this.
  11. Feb 9, 2017 at 12:44 PM
    #671
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Yeah, trac is still doing the same thing. Doesn't matter if I'm on The gas, it actually seems to do it more coasting through downhill turns. Exactly The same position of The steering wheel ( 1/4 rotation)in both left and right turns. The tires are not rubbing anywhere that I can see. I just had one off the truck to get a better look, looks brand new, no marks.
  12. Feb 9, 2017 at 1:56 PM
    #672
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    5100s all around, 295-70-18 Defenders, 1.25 Spidertrax spacers, BD reverse lights, de-badged, interior LEDs, footwell LEDs, reverse LEDs, ARE cap, front receiver hitch for cooler holder, cooler holder/rod rack, backup camera, Kenwood HU, Westin nerf bars, Husky floor liners, folding rear seats, remote battery posts, plastidip grill chrome, Powder coat bumpers.
    What air pressure are you running? With my E rated tires at 60 psi and no load or trailer, certain road conditions will set off the VSC. Running normally at 35 psi, doesn't happen.
  13. Feb 9, 2017 at 2:39 PM
    #673
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Just dropped the psi from 40 ft and 38 rr to 35 all the way around and drove it, no change. It only does it turned in a certain amount. I took it through a tighter turn going faster and it didn't go off. Got the tires to break loose a little in dry sand on the pavement and it didn't go off. Its just the trac no vsc light.
  14. Feb 12, 2017 at 6:04 PM
    #674
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Huh... that's very odd
  15. Feb 12, 2017 at 6:12 PM
    #675
    CM-LENNY
    San Diego, CA
    Hello Jace........I have looked all over and even found different results. Can you post Torque specs for a 2015 CM 4x4 ( primarily suspension related ) Front UCA and related front components, rear u-bolts, leaf spring shackles etc. Thanks much.........
  16. Feb 12, 2017 at 6:24 PM
    #676
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Hey Jace, yeah I am stumped as to what the issue is. I can't feel the brakes engaging or the throttle cutting out. Just the sound like the tires are chewing into the fender liners and the trac light. Is it possible that the tires could make such a racket and leave no marks? Should I make another appt to take you on a ride in it so you can get a better idea of what it is doing?
  17. Feb 12, 2017 at 7:19 PM
    #677
    mjr415
    mjr415 New Member
    2011 Toyota Tundra SR5 Double Cab
    Jace, first I want to say thanks for taking time out to answer Tundra questions. My dilemma is I just recently had my 2011 leveled with Bilstein 5100's and it threw my ABS, Brake, and Traction light on. The mechanic who installed it said when he realigned it that he couldnt get a Yaw reading after the install. Not sure what to do, still driving with the lights on!!
  18. Feb 14, 2017 at 7:29 PM
    #678
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    I will try to remember tomorrow. Just did a lift on a 17 the other day but don't wanna mess up the numbers from trying to remember.
    U can if u want man, I can't do much other than look at wheel speeds and sensors and maybe do the zero point again. Pm me.
    I bet he stretched an abs wire. Did he pull codes?
  19. Feb 15, 2017 at 6:22 AM
    #679
    mjr415
    mjr415 New Member
    He pulled a code, but the one he pulled was an existing one for my AIP. When I left there after the 2nd alignment to figure out what the problem was, I tried to pull the codes myself and they never popped up! Just the AIP code P2442. Of course my reader doesn't have ABS on it. Would it still read it anyway?
  20. Feb 15, 2017 at 5:24 PM
    #680
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Yeah u gotta have a pretty advanced scantool to pull abs codes
  21. Feb 16, 2017 at 4:51 PM
    #681
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    I've got an easy question that's probably been asked and answered before.
    I put bilstein 6112's up front on highest setting. I'm not going to put any kind of shims or lift. Do I need the diff drop kit? I bought it and it's sitting on my bench. Should I have the dealer throw it on when I do the first oil change?????
    My thinking is id rather just put it in if necessary to avoid any warranty issues for cv's, or if it's even necessary. I've basically just leveled it like a TRD pro. Do they come w a diff drop kit?
  22. Feb 16, 2017 at 5:02 PM
    #682
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 Long Travel DC
    Pros do not.
  23. Feb 16, 2017 at 5:06 PM
    #683
    Frkypunk
    Frkypunk "If a man is to be a street sweeper"
    2010 Tundra limited...2015 highlander limited
    Should I worry about the clunk when I put my 4wd in on the fly? Is it normal or should I just stop the truck...then engage?
  24. Feb 16, 2017 at 5:55 PM
    #684
    CM-LENNY
    San Diego, CA
    I was just up at Bilstein Corporate offices in Poway, CA yesterday. Great group of guys up there that didn't believe I had 37's on my truck with the wheels and lift I have. I had an original phone conversation and they wanted to see it in person. Anyway back to your question. From what I understand, the Pro shock is only approx 2" lift. Diff drop not needed. The 6112 at top setting is 2-1/2" lift. Diff drop kit not 100% needed, but they highly recommend it as good cheap insurance to the other components. ( CV's, steering links etc. ) I recommend putting it in.......
  25. Feb 16, 2017 at 6:21 PM
    #685
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Cm. Thanks. That's sort of what I was thinking. Cheap insurance. I appreciate the reply.
    Cat3ILS and CM-LENNY like this.
  26. Feb 19, 2017 at 8:07 PM
    #686
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Vvvvvvv great advice there
    No they all clunk a bit. Some ore some kess. All depends on alot of things
  27. Feb 19, 2017 at 8:21 PM
    #687
    Frkypunk
    Were you drinking when you typed the response?:)
  28. Feb 20, 2017 at 11:49 AM
    #688
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    Yes
    Yes, alot.... lol! Stupid phone...
    Meant to say
    Some more, some less
  29. Feb 21, 2017 at 9:27 PM
    #689
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Looks like the issue with my trucks trac issue is the e rated tires. Dropped them all the way down to 25 and it barely went off. Put them back up to 35 hot, so Probably about 32. My local independent Toyota tech plugged in tecstream and we took it on the same roads where I know it has been acting up. Of course it only went off a little. Hope it was enough to get good data. Dave's not sure if it's possible to get into the programming to adjust for the bigger tires. Apparently Toyota built some you can adjust and some you can't. Like scion, they know the kids they're marketing to are going to change wheels and tires. But they don't think tundra guys will.:annoyed:
    LOTSOFTOYS likes this.
  30. Feb 22, 2017 at 8:41 PM
    #690
    Tundra4us
    Tundra4us New Member
    "D"
    Not sure if this has already been answered ( sorry still "newbie", trolling around here ) I have been following a post here from a member (krohsis) posted Oct. 6 2016 regarding the trans thermostat by-pass mod. What he has done is "pinned" the thermostat in the open posistion to help with lowering the fluid temps. Is there any negative affects when doing this? As of now I am not towing a lot , but I am lifted with 35" tires and I am driving in the mountains quite frequently to the snow. i have not experienced the trans "hunting" as i know when to use it in 4S VS keeping it in regular drive mode. i just want to keep my truck running at peak performance for years to come. Thanks! looking forward to what you think about this mod.
