Back Up Home Generator Question
Discussion in 'Home Improvement' started by texasrho83, Sep 7, 2023.
  1. Sep 29, 2023 at 7:14 PM
    #121
    texasrho83
    texasrho83 [OP] DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    What really burns me up is that we bought this AC system a little over a year ago and one of the salesmen mentioned a heat pump to me after the fact... saying it would help me with my heating bill. The cost: $5k. I told him wtf dude why didn't you tell me this before I pulled the trigger?!
    nobodyintexas likes this.
  2. Oct 9, 2023 at 3:04 PM
    #122
    Blufin
    Blufin Seasoned member
    Bob
    23 Capstone
    We lose power way to much and for to long at the slightest storm so I pulled the trigger and had a whole house standby with ATS.
    I use to service Generac commercial and residential and wasn't a fan of them,so say the least I went with Kohler.
    Since it's install 15 months now and it has been called to duty 6 times.
    Worth it's weight 100%
  3. Oct 9, 2023 at 3:35 PM
    #123
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    2006 Tacoma TRDS 4X4, 2021 Tundra LR TRD Pro
    We lose power about 30-40 times per year. Recovery is 1hr to 1 week. I also got sick of the extension cords through the window so installed a manual transfer switch that allows me to pick 8 circuits I want to power. Then my portable gen plugs into a single socket outside to power those 10 isolated circuits. When power comes back on, they are still switch to my gen and no longer closed to line power. I just have a small lamp plugged into an outlet that is not powered by my selected circuits so I know when power has been restored.
    Cheaper and safe solution. I installed the transfer switch myself but if your not comfortable, a competent electrician should be able to do it in 3-4 hours depending on complexity of where you mount the transfer switch and external power feed outlet.
    https://www.amazon.com/30-Amp-10-Ci...mzn1.fos.c3015c4a-46bb-44b9-81a4-dc28e6d374b3
    Mike59 and coTony like this.
  4. Oct 9, 2023 at 3:56 PM
    #124
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    I know the OP has already made their decision, but for others, we run a small 2200W Honda inverter off a 5 circuit manual disconnect switch. I use the “Companion” model that has the 30A twist lock.
    This little generator powers three rooms (living room, kitchen and bedroom), plus our attic (hot water heater only) and our septic system.
    Obviously doesn’t power the A/C, but that’s more a luxury instead of a need. Hondas are great, this little guy ran for 42 hours straight during Uri and has been used in two hurricanes. Very efficient on eco and it’s an inverter generator. Also super quiet and very light. You don’t need much to power essentials.
    WILLINH likes this.
  5. Oct 9, 2023 at 4:11 PM
    #125
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    It arrived last Thursday. Still waiting on a propane tank and for Centerpoint to install a meter (30-40 days out).
    It's pretty big for a portable. Here it is next to my riding mower.
  6. Oct 9, 2023 at 4:18 PM
    #126
    coTony
    Tony
    Sun Lakes, AZ
    I need to get a transfer switch then see if I can do anything that would help
  7. Oct 9, 2023 at 4:25 PM
    #127
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Here's the interlock kit my electrician installed
    Mike59, coTony[QUOTED] and NWPirate like this.
  8. Oct 9, 2023 at 5:08 PM
    #128
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    That’s where the generator cord plugs into. The interlock is usually in the panel, or that’s where I installed mine.
    Is that a 30 or 50 amp plug/wiring?
    NWPirate likes this.
  9. Oct 9, 2023 at 5:10 PM
    #129
    NWPirate
    NWPirate *Not a Ubangy
    Zach
    WA
    You're only back feeding 120V with your generator?
  10. Oct 9, 2023 at 5:11 PM
    #130
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    50A
  11. Oct 9, 2023 at 5:21 PM
    #131
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    No
  12. Oct 9, 2023 at 5:37 PM
    #132
    NWPirate
    Zach
    WA
    Looks like your plug is only 3 wire, maybe your receptacle is grounded through the plug body??
    Not trying to nitpick, just curious.
  13. Oct 9, 2023 at 5:57 PM
    #133
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    No it's cool. The electrician did a load read and knows the generator we went with. He set everything up to meet our needs. My cord is 50ft long and rated for 12,500W at 240V
    Mike59 and NWPirate[QUOTED] like this.
  14. Oct 9, 2023 at 6:03 PM
    #134
    NWPirate
    Zach
    WA
    Nice.
    You can see my confusion in the picture, 4 wire male end with a 3 wire female end.
    The female end is grounded through the case.
    Sounds like you're set! :thumbsup:
  15. Oct 9, 2023 at 6:43 PM
    #135
    nasher75
    nasher75 New Member
    Erik
    Los Gatos, CA
    Damn, that's a big boy. Didn't know they made open team portables 1.5kW
  16. Nov 15, 2023 at 1:55 PM
    #136
    Coastboater
    Coastboater New Member
    Wheels & Tires, Power Running Boards
    After a 4 day outage for hurricane Matthew and 5 days for Irma, installed a Generac 24kw unit.
    BOOM!
    No hurricanes since the installation:D
    Lifer, Mike59, nasher75 and 4 others like this.
  17. Jan 27, 2024 at 2:06 PM
    #137
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Update: Power outage the other night at around 0230 until 0700. Hooked up the Duromax for its maiden voyage and it performed flawlessly. I even did it in the rain. I shut off all the major appliances with the intent of only using the microwave and, of course, power to the fridges and freezer. The generator barely acknowledged a load. This was on propane as we still don't have a NG line in place (Centerpoint is clearly not in a hurry for new customers).
    Just drained the oil after the break-in and it looked brand new. Waiting on new filter from Amazon and I was going to pull the trigger on some synthetic oil for 4 cycle engines. The Duromax is a 4-stroke. My research shows the two terms are interchangeable so should I opt for the "specialized" 4 cycle oil or just buy some automotive 10w30 and call it good?
    Blufin, ColoradoTJ and nobodyintexas like this.
  18. Jan 30, 2024 at 5:23 AM
    #138
    300BLK
    300BLK New Member
    2014 Tundra SR5 - Black
    I run automotive oil in my Predator 9500 without issue. I wired a near identical setup to yours and it works great for our use case as well. I've heard good things about those generators. I almost got one but went with the Predator really for noise. Its unbelievably quiet even under load.
  19. Jan 30, 2024 at 6:21 AM
    #139
    Retired...finally
    For those considering getting a generator let me add this: Columbus Ohio had a summertime storm hit and AEP, the local power company gambled on skimping on line clearance and lost. Thousands were without power. After this our public utilities commission put out their recommendation. One of which was for AEP to change their notification policy from customers having to opt in for alerts to all customers get the text messages unless they opt out. Very little was mentioned in their report about clearing trees near the power lines.
    So, it's not going to get any better.
    texasrho83[OP] likes this.
  20. Jan 30, 2024 at 7:39 AM
    #140
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I have a smaller Predator generator too. I love it. Soooo quiet.
  21. Jan 30, 2024 at 7:42 AM
    #141
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I guess they're saving a ton of money on linemen. I heard that it's cheaper to repair issues than maintenance on lines, clearing limbs, etc.
  22. Jan 30, 2024 at 8:18 AM
    #142
    Retired...finally
    Ever since the big power outage in the early 2000's a law was written that all transmission lines be cleared of brush every 5 years. It's mostly ignored
  23. Jan 30, 2024 at 8:27 AM
    #143
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Laws can be ignored when enforcement is non-existent... We see that in a certain southern region I will not name :frusty:
  24. Jan 30, 2024 at 9:28 AM
    #144
    Blufin
    Bob
    23 Capstone
    Agreed, and a Law is only as good if it is upheld.
  25. Feb 9, 2024 at 11:42 AM
    #145
    Dsptundra
    Austin TX Area
    2021 Silver Limited CM
    Husky X-act, front windows tint, Xpel PPF, center console organizer and tray, TRD rear sway bar, touch screen cover, transmission cooler, wireless charger, keyless tailgate lock.
    I have been mulling backup options and the Predator ones from HF caught my eye, especially with a 25% off coupon they just sent. How often do you use it?
  26. Feb 9, 2024 at 12:58 PM
    #146
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I've only used it 3 times in about 6-8 mos. Powered my freezer in the garage, fridge, portable AC, router and some lamps without a problem
  27. Feb 9, 2024 at 1:24 PM
    #147
    Dsptundra
    Austin TX Area
    What size did you use? Been looking at the 5,000 watt one for basics.
  28. Feb 9, 2024 at 1:41 PM
    #148
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I have the 4550 and run a 10 ga cord with 3 outlets on it
    Dsptundra[QUOTED] likes this.
