Ball joints upper and lower
Discussion in '1st Gen Tundras (2000-2006)' started by Built2last23, Dec 27, 2017.
  1. Dec 9, 2019 at 5:15 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    What press did you use on the upper? Did you pull the whole spindle out?
  2. Dec 9, 2019 at 5:32 PM
    Aerindel
    Aerindel New Member
    Montana
    I did not use a press. I cut a section of steel pipe the right diameter and length and tapped it out with a hammer, which worked but was kind of a hassle. I did this on the truck, with the hub/spindle supported by a jack
    If I had it to do again, I would just rent a ball joint press kit from a parts store.
  3. Dec 9, 2019 at 5:34 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Good luck. I tried that. That giant C clamp they give you is so big that it doesn't fit. A few people swung the spindle out and made it work. Not easy though. I'll know for next time.
    Aerindel[QUOTED] likes this.
  4. Dec 9, 2019 at 5:40 PM
    Aerindel
    Aerindel New Member
    Montana
    Good to know. I just assumed the 'right way' would be easier than how I actually did it. A mistake I have made before.
  5. Dec 9, 2019 at 6:07 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    But how did you get it back in without a press??
  6. Dec 9, 2019 at 7:27 PM
    Aerindel
    Aerindel New Member
    Montana
    Same way, used a pipe and hammer to tap it in. This was significantly easier than getting it out. Wether you use a hammer or a press its the same process, you're just applying force and pushing the part into or out of the the socket.
    TX-TRD1stGEN[QUOTED] likes this.
  7. Dec 10, 2019 at 12:20 AM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    I am yet to do this on my Tundra (it’s in the near future), but I have done many ball joint replacements on other vehicles and always used a pickle fork to get everything apart.
    They’re cheap, easy, and you still get to use a hammer.
    Aerindel likes this.
  8. Dec 10, 2019 at 1:30 AM
    Aerindel
    Aerindel New Member
    Montana
    One of those things I keep meaning to buy but always forget until I've started the project.
    bmf4069 likes this.
  9. Dec 10, 2019 at 11:27 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Does a hammer work for the upper? I've seen videos using the auto part store press, but it's pretty hard to fit in there.(I'm mentally prepping for my SPC install)
  10. Dec 10, 2019 at 11:49 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yes it is. You either have to be prepared to swing the spindle out or I think you can buy a Toyota ball joint press that works better.
  11. Dec 10, 2019 at 11:59 AM
    Whothefat
    Whothefat New Member
    Clark
    Las Vegas
    2006 Black Tundra DC 4x4
  12. May 18, 2021 at 11:19 PM
    01tunder
    01tunder New Member
    Ca
    2010 4x4 trd tundra
    I'm having a real hard time trying to remove the ubj. The press I rented from oriellys doesn't have the correct recievers. They don't have the Honda/toyota one
    Anyone know if Can I use regular wrench sockets as the recivers? If so what size?
  13. May 19, 2021 at 5:00 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  14. May 19, 2021 at 5:01 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    To remove your UBJ you need the ball joint remover kit. Then you gotta work it in weird ways to get it to come off. That's how I did it anyways.
  15. May 19, 2021 at 8:19 AM
    Skyride56
    Skyride56 New Member
    Joe
    Franklin, TN
    2005 Black Tundra Limited DC
    Leveled w/ Bilsteins 5100, 285 70R17 Nitto Ridge Grapplers, 17x9 +01 Fuel Vapor wheels
    I just did one of my UBJ yesterday and I too used the removal kit from Oreilly’s which was shitty but I was able to get it out. You won’t be able to press in the replacement UBJ with that kit since it doesn’t have the correct cups. If you have an Advanced Auto near by they have the kit you need. It’s their “big” kit if they ask which one you want.
    Here’s a link: https://shop.advanceautoparts.com/p...OR 10002076 OR 10002083 OR 9150007 OR 9150042
    Removal tips: disconnect your ABS sensor so can rotate the knuckle out of the wheel well. A good impact will greatly help since a breaker bar is too unstable when torquing the press.
    Installing is a PITA even with the Advanced kit. Line up the new UBJ in position so it’s straight then tap it with a hammer so it stays in place while you setup the press and get into position. Hand tighten the press making sure the cups are perfectly aligned. Hit it with an impact at full torque while watching to make sure it’s going in straight. I used my fingers to feel the gap underneath while using the impact. It took me 4-5 attempts to finally get in. Had to press it out when it went in crooked. After it’s in, put the C-clip on before placing the grease filled boot over it. I bought a c-clip tool from oreilley’s. If your kit comes with the coiled up wire, make sure you straight out the wire then wrap it around twice, twist the wires together, make sure there’s about a 3/4” of twisted wire the faces towards the front of the truck (if the wire is facing the tire it may puncture the grease boot when compressed). After snipping the wire beat it down over the arm
    Good luck, I did both sides LBJ, tie rod ends, swaybar links, brakes, and rotors. The UBJ was my biggest challenge but doable with patience, the right press kit, and a good impact gun.
  16. May 19, 2021 at 4:13 PM
    01tunder
    01tunder New Member
    Ca
    2010 4x4 trd tundra
    Thank you got the press and got it done..going to do passager side before I turn in the press., but I ran into a problem, I took off the brake line and emptied the brake fluid and refilled it but brake line is on and brakes are very weak..
  17. May 19, 2021 at 9:30 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Gotta bleed em if you opened the line. It's got air in there.
  18. Apr 22, 2024 at 4:57 PM
    MT-Tundra
    MT-Tundra Agnostic Gnostic
    Montana
    2002 AC 4wd V8 Limited
    I'll go ahead and save anyone the trouble of adding this.
    But of course that's the whole point of a forum. A well organized, helpful thread hopefully avoids twenty-five threads on the same topic....
    I'm getting up to speed on this job. I'll be doing my work outside of town. I'll have a backup vehicle to use if I need to, but it's a good 30 minute drive on mostly dirt roads to get to an auto part store (and that assumes part stores will have what I'm missing in stock). Toward the end of the video, he shows several parts that aren't included in the rented ball joint press. I'm guessing that's what the linked Honda kit covers? I just want to make absolutely sure that the Honda kit has everything I'll need for pressing the UBJ out of the knuckle. I have the normal OTC front end kit to get to that point. But looks like the extra-specialty tools come into play once you've got the knuckle off, and are ready to press the ball joint out.
    Otherwise seems like I just need some cotter pins, a 35mm socket for the axle nut, my OTC front end kit, and otherwise fairly standard tools?
    Obviously I plan to do this job with the 'remove the knuckle' technique. I've looked at the other methods and this is the one I'm going with.
  19. Apr 23, 2024 at 5:35 AM
    #49
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    I don't think that one will do it. I had to use this one:
    https://www.amazon.com/OrionMotorTech-Heavy-Removal-Adapters-Trucks/dp/B01N7CO50E?th=1
    Lemme find the thread with my description of how to do it.
    Post number 5 kinda explains how to do it.
    https://www.tundras.com/threads/front-wheel-bearing-and-hub-replacement.63508/
    Weagle likes this.
  20. Apr 23, 2024 at 6:12 AM
    #50
    kentuckyMarksman
    kentuckyMarksman New Member
    2006 Tundra SR5 Double Cab - 4.7L V8 4x4
    When I did my upper ball joints I "rented" the ball joint press kit, and the ball joint press accessory kit from Autozone and had everything I needed.
    I also removed my steering knuckle when changing the ball joints (did wheel bearings too), so I actually didn't even use the ball joint press at all, just the accessory kit. I used a shop press to change my upper ball joints, was very easy on the press.
  21. Apr 23, 2024 at 7:05 AM
    #51
    MT-Tundra
    Montana
    Hm. Well it seems like people do it different ways...My plan is to rent the large c-clamp ball joint press, and my understanding from reading this thread is that the kit I linked has the missing cup sizes. Hopefully that's true. Already spent the money.
  22. Apr 23, 2024 at 7:09 AM
    #52
    kentuckyMarksman
  23. Apr 23, 2024 at 7:21 AM
    #53
    This is ultimately the truth. I tried a few other ways people had success, only to find their method, with similar adapters, wasn't working for me at all. My reality is, even when I had the knuckle off, the combination of cups and such I ended up using was totally different from what others did.
    Have a basic kit. If you can't get a cup combo that works, don't mull over it for an hour or two trying to find workarounds like I did on my 1st attempt, before bailing and buttoning everything up (I was sick that day, related to some tonsil cysts). Instead, just pull the knuckle, or go to the local parts store and rent a kit like @kentuckyMarksman suggests, so you've got more options to work with.
    kentuckyMarksman and Weagle like this.
  24. Apr 23, 2024 at 9:27 AM
    #54
    MT-Tundra
    Montana
    Alright. Between my OTC front end kit, the rented ball joint kit and the Honda cup kit, I'll assume anything I might be missing can be addressed with large hammer.
    Thanks.
  25. Apr 23, 2024 at 11:04 AM
    #55
    rock climber
  26. Apr 23, 2024 at 11:07 AM
    #56
    kentuckyMarksman
    I'll also say that if the stud of the UBJ is too tall when pressing it out you can cut it with an angle grinder to make it shorter.
  27. Apr 23, 2024 at 11:16 AM
    #57
    @assassin10000 encouraged me to grab those too, that they're awesome. I was my typical stubborn ass self.
    This, in a nutshell was my problem. Had I cut the stud down, I could've easily pressed out the UBJ using the 20yr old shitty HF kit I had with the knuckle still installed.
  28. Apr 23, 2024 at 11:42 AM
    #58
    MT-Tundra
    Montana
    I did read a tutorial where they cut the top off with a sawsall. I guess I could try that, rather than removing the knuckle, but I think I'd rather just pull the knuckle, get it in a vice, and save myself some frustration.
    Yeah that Chaos Fab kit would have been nice. Same price as the Honda kit, but only the exact parts I'll need. Maybe I'll work on putting together an official ball joint thread where all this stuff is listed, as best as possible, in one post, so people know the different methods and what tools are needed/available for each of those methods...
  29. Apr 23, 2024 at 11:48 AM
    #59
    Don't even need a vice. Just lay the MF'er on the floor and do it up.
    metalpete likes this.
  30. Apr 23, 2024 at 12:13 PM
    #60
    MT-Tundra
    Montana
    "Need", no. I've done plenty of stuff on the floor. But I've also had access to a vice for some jobs, and watching the youtube videos where they use a vice, I'm always jealous. Having something up at chest level, secured, where I can stand up straight and work on it without it scraping around on the ground and me bending over is well worth it.
    rock climber likes this.
