Battery size and options
Discussion in 'General Tundra Discussion' started by csuviper, Dec 24, 2016.
What battery brand do you use on your Tundra?
  1. AC Delco
    0.9%
  2. AutoCraft
    1.2%
  3. Bosch
    0.6%
  4. DieHard
    2.7%
  5. Duracell
    2.1%
  6. EverStart
    2.7%
  7. Exide
    0.3%
  8. Interstate
    10.7%
  9. Kirkland
    1.2%
  10. NAPA
    2.1%
  11. Northstar
    16.9%
  12. Odyssey
    11.9%
  13. Optima
    8.0%
  14. Stock for now :(
    38.9%
  1. Sep 12, 2019 at 7:51 AM
    #61
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    This thread really helped me out. I voted stock for now, but ordered an X2 Power by Northstar 27F from Batteries Plus today! Getting it in preparation for a 12v fridge for camping. Also plan to use the fridge in my wife's Pilot for less rigorous tarmac trips. Now to get the appropriate always on 12v outlet wired up, and decide on a fridge. Then no more soggy sandwiches (I hope).
  2. Sep 24, 2019 at 7:01 PM
    #62
    Zero One Actual
    Dear Grizzled Battery veterans. I have a 2019 CM that has or will have the following on it:
    20 inch LED light bar
    12,000 winch (Smittybilt XRC Gen3 12K)
    Fog lights
    Air Compressor for rear air bags
    50 watt GMRS/HAM radio
    @mattgecko under hood LED and truck bed LED lights
    2x rear Rigid 1x2 scene lights on back of rack
    At what point do I need to consider a duel battery setup versus a single Northstar or Odyssey battery? I am a total rookie. None of the items listed above are used daily together. Meaning, the GMRS radio would be on, but I would not be using the winch or the light bar, or the winch and light bar could be on at night time, but the air compressor and rear LED or bed LEDs would not be in use. Thanks for any information and explanation. If there is a single battery solution, I would like to go that route first and see how it goes, so let me know what you suggest.
    mattgecko likes this.
  3. Sep 24, 2019 at 7:04 PM
    #63
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    I started with the single x2 power northstar 27f from batteries plus. I wanted to start slow and maintain a mostly stock configuration. If you have the dough go dual battery though. I’m building my rig slow and felt 92ah was enough for a start.
  4. Sep 24, 2019 at 7:05 PM
    #64
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    Your goals sound more dual battery territory. If I was doing such a heavy build I’d go for the genesis off-road setup.
  5. Sep 26, 2019 at 12:12 PM
    #65
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    Stoked Added an always on 12v outlet for the fridge.
  6. Oct 3, 2019 at 11:38 AM
    #66
    tstieb
    tstieb New Member
    2014 CM TRD
    That battery fit in the tray ok? I was looking at it but the listed dims were bigger than the stock battery. But it did look like the battery narrowed down near the base, so I was unsure. Either way that is one heavy battery. Thinking of going with an Odyssey simply because of that.
  7. Oct 3, 2019 at 12:29 PM
    #67
    SandyTRD
    SandyTRD New Member
    ‘16 Pro
    Dented bumper
    Perfectly. Put the same in my truck last weekend.
    tstieb[QUOTED] likes this.
  8. Oct 3, 2019 at 5:37 PM
    #68
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    No problems with the battery fitting the tray. I’ve seen videos that upsize the battery, but I stuck with the stock size 27F.
    tstieb likes this.
  9. Oct 3, 2019 at 5:47 PM
    #69
    motoxscott
    motoxscott New Member
    Scott
    Hurricane, UT
    2017 Tundra
    Camburg - FOX - Method - General Tire - Deaver - Rigid
    Went with the Odyssey 34R-PC1500 with @sdhq_offroad billet terminals and hold down. Gonna upgrade to their new dual battery setup down the road.
    - Scott @ Camburg
    Damie Street, sdhq_offroad and Skey44 like this.
  10. Oct 3, 2019 at 7:51 PM
    #70
    Zero One Actual
    70F44C38-6F14-47FB-9C54-FE47B4E24E8D.jpg 7E258D2B-C569-4B70-B5CD-4FB83B3F7DD5.jpg
    Current info from each company per their websites as of Oct 2019. Given this information and the fact that the Odyssey is $304.87 and the North Star is $289.95, do these numbers sway any of you towards one over the other now?
    North Star data listed below Odyssey although the post looks like one big picture.
  11. Oct 4, 2019 at 6:44 AM
    #71
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    Are you doing the smaller battery than stock because you’re doing a dual setup? I don’t quite understand why you’d pick the 34 over the 27f otherwise. This is the x2 power by northstar’s numbers. Available at batteries plus.
  12. Oct 8, 2019 at 7:17 PM
    #72
    K1NJO
    K1NJO New Member
    Allen
    Bay Area, CA
    2011 Black Tundra TRD Sport
    Unfortunately had to go with Interstate. Not that it's a bad battery. My current battery was dead and needed to be replaced asap. No b&m stores in the area with Odyssey, otherwise I would've went with that just to keep with the red & black theme :D
  13. Oct 9, 2019 at 3:42 AM
    #73
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    I have an East Penn AGM battery in my 2012 Crewmax.
  14. Oct 19, 2019 at 8:27 PM
    #74
    tstieb
    tstieb New Member
    2014 CM TRD
    Got an Odyssey yesterday from 4WP with their no sales tax sale for $300 incl the plastic spacer tray. Could have got a Northstar X2 for about the same price from Batteries Plus with their recent 20% off sale but I thought it was just too heavy.
    The OE battery performed fine in the cold temps I was in last week, but at 5yrs, I wanted to replace it before it went downhill.
  15. Oct 20, 2019 at 2:54 PM
    #75
    hi_rawb
    hi_rawb New Member
    rob
    Bay Area
    2018 CM TRD SPORT 4x4
    2018 Trd Sport
    Just put this on Friday night..
    Skey44 likes this.
  16. Oct 20, 2019 at 4:37 PM
    #76
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Leer 100XL, Bedrug, Go Rhino running boards, LED int/ext lighting, Bilstein 6112/5100 1/2”shims up front, Coachbuilder +3 shackles, CB drop, TRD front/rear sway bar, 275/65/20 Michelin LTX M/S 2, sequoia painted mirror cap/door handles, Rago Fab low pro ditch brackets, Baja Designs S2 sports ditch lights. Baja Designs S2 sport rear flush mount pod
    Just ordered the Northstar, thanks to all of you for helping me reach for the plastic again
    :rofl::spending:
    hi_rawb likes this.
  17. Nov 23, 2019 at 6:59 PM
    #77
    Rlynch356
    Rlynch356 New Member
    Apex NC
    2019 Tundra TRD Pro
    Did anyone fit a group 31 odyssey battery... The battery box specs seem to work, but will need to remeasure it.
    Not sure why the 34 or 25 groups are an option since they are much lower Amp Hours than stock. but YMMV..
    But in reality the g27 is 92 ah hr and the 31 is 100 ah hr which should be enough for just the truck loads.
    I'd like to do a dual setup but they all use the smaller batteries so you are not gaining much AH Hr capacity. Ideally 2, group 27 or 31 batteries would be perfect.
    Will probably go with a DC charger for the house battery (redarc looks nice) and locate in the rear.
    I have had a northstar before and had no issues, my other trucks have Odyssey though.
  18. Feb 23, 2020 at 1:48 PM
    #78
    Mgmtundra
    Mgmtundra MGM Crew
    Anyone try an AGM from Costco?
    TheBeast likes this.
  19. Feb 23, 2020 at 1:52 PM
    #79
    jordan0317
    jordan0317 Just hoodrat things...
    Jordan
    Martin, TN
    2017 White Tundra XP 4x4
    Thinking of going with an H8 platinum agm from Advance Auto Parts as its local in town and I'm leaving for a trip in the next day or two, anybody ran one? I know zero about batteries
  20. Feb 25, 2020 at 7:33 AM
    #80
    Mgmtundra
    Mgmtundra MGM Crew
    The H8 looked huge, if you try it please post thoughts of fit.
    jordan0317 likes this.
  21. Feb 25, 2020 at 7:52 AM
    #81
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    dealer original , 27R , 120.00 , 1rst one lasted 7yrs and no problem , just a maintenance thing. Keeping old one for spare in bed.
  22. Apr 11, 2020 at 10:19 AM
    #82
    TheBeast The Beach
    didn't know costco carries AGM. any feedback ?
    my oem toyota is about 5 years old now so time to replace it with an AGM since now I got a lot more aftermarket parts :)
    should I get 27F or 34R ? going AGM for sure and the SDHQ terminals
  23. Apr 11, 2020 at 10:39 AM
    #83
    Mgmtundra
    Mgmtundra MGM Crew
    Unfortunately the Costco I was at only had the H6, H7 or H8. The 27F was not AGM.
  24. Apr 11, 2020 at 12:31 PM
    #84
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    I’ve always used dinky little 24F AGM batteries and they’ve been perfectly fine:notsure:
  25. Apr 11, 2020 at 2:30 PM
    #85
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Agreed. 24f and 27f typically have the same CCA between like batteries. 27f just has a larger reserve capacity. Unless you’re using power without the truck running a lot, a 24f is fine.
    YardBird and TheBeast like this.
  26. Apr 11, 2020 at 3:29 PM
    #86
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    If you consider yourself a hardcore off-roader I say 34R due to battery boxes being available. I went with the 27f which does offer more power but I cant find any battery boxes/cages for that size.
    If I could do it over I’d probably get this battery Odyssey Batteries 34R-PC1500T Automotive/Light Truck and Van Battery https://www.amazon.com/dp/B008FY5UF8/ref=cm_sw_r_cp_api_i_LuKKEbS92A4HD
    You can run it without a spacer if you use sdhq hold down bracket or there are a bunch of cages for it to bolt it down to where that fucker won’t budge
    TheBeast[QUOTED] likes this.
  27. Apr 11, 2020 at 3:47 PM
    #87
    TheBeast The Beach
    good to know. thanks. I'm probably gonna stick to 27F.
    YardBird likes this.
  28. Apr 16, 2020 at 11:33 AM
    #88
    Mgmtundra
    Mgmtundra MGM Crew
    Did Your Costco have a 27F agm?
  29. Apr 16, 2020 at 1:38 PM
    #89
    RitcheyRch
    Richard
    Santa Clarita, CA
    I have a Deka AGM in my crewmax
  30. Apr 16, 2020 at 3:31 PM
    #90
    TheBeast The Beach
    I have not checked yet.
