Behind the grille light bar, anyone done it?
Discussion in '2.5 Gen Tundras (2014-2021)' started by divinguy, Jun 5, 2020.
  1. Aug 6, 2021 at 4:31 PM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    It supplies all the light I will probably ever need, but in hindsight I wish I would've gotten a longer light bar.IMG_2007.jpg
  2. Aug 6, 2021 at 5:24 PM
    Cthulhu
  3. Aug 6, 2021 at 5:34 PM
  4. Aug 6, 2021 at 6:07 PM
    Cthulhu
    No I’m way too cheap for one of those :rofl:
    LED Light Bar 40 inch - 4WDKING Screwless 200W IP69K Waterproof Off-Road Combo LED Work Light Super Bright Truck Driving Fog Lamp Fit for Ford F150 Polaris RZR Jeep Wrangler https://www.amazon.com/dp/B07PYSPF76?_encoding=UTF8
  5. Aug 7, 2021 at 3:29 PM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    I used the Rough Country 30” single row Black Series w/ DRL with Rago Fabrication stealth mounts. I will say for the price, the RC bar was well made and casts plenty of light. I had tried a cheap Amazon one and the threads on the ends of the mount caps/plates stripped before every getting it installed (cheap aluminum threads with stainless screws cross threaded as soon as tension was applied) The DRL feature on the RC was nice to actually be able to turn it on when driving on the street without blinding all of traffic. The high power mode was impressive when off-road and back forest hwy with no traffic at night.
    Brettstation37 likes this.
  6. Aug 8, 2021 at 12:49 PM
    TRD.PNW
    TRD.PNW New Member
    Eric
    2019 Calvary Blue TRD
    Do you think the double row would work well in that spot?
  7. Aug 8, 2021 at 3:04 PM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    You could possibly fit a double in there…but honestly it would be overkill from an actual usage perspective. The single row throws way more light than even my brights reach. It’s more than enough light on high mode. The DRL version is cool for actually being able to turn it on outside of backroads. The high mode is great when out of the city for spotting deer or other animals far in advance, or just off-roading at night.
  8. Aug 9, 2021 at 4:56 PM
    Brettstation37
    Brettstation37 New Member
    Brett
    Catskills NY
    2020 Tundra CrewMax TRD Sport
    2nd on the RC 30” light bar, just installed one myself and on the back roads it’s bright enough for myself
  9. Aug 26, 2021 at 2:23 PM
    SpooledReel
    SpooledReel Insufficient Funds
    RickyP
    Spanish Fort, AL
    2015 Tundra CM Limited 4x4
    I have this same light. The first one I received showed condensation within the first week. They sent me another to replace it and it has worked fine for the last year. Rough Country never asked for the other back so I dissected it. The weak point is the seal behind the plexi lens. If the bolts are not tightened down right, the stretched gasket slips. I dont know how they get that gasket in there, but it doesnt seem to ever want to go back in without having gaps. I ended up sealing it with black dicor rv sealant. Maybe I will throw it in behind my grill?
  10. Aug 26, 2021 at 3:24 PM
    1P7R9O4
    1P7R9O4
    AZ
    ‘17 White 1794 Pro
    @SpooledReel
    Not a bad idea…fortunately, no condensation/gasket issues on mine, but not a bad deal if your sealant holds up; glad they took care of you with the warranty and potentially a 2 for 1 as well.
    SpooledReel likes this.
  11. Oct 13, 2021 at 12:24 PM
    ErikTRDTUNDRA
    ErikTRDTUNDRA New Member
    Erik
    2018 Tundra crewmax 1794
    Can you give a update on the quality of this light? Maybe a pic of it installed? Seems the reviews on this are far better than the Nillight
  12. Oct 13, 2021 at 1:09 PM
    Cthulhu
    Still no condensation behind the lens. Expectations exceeded.
    Tundra14Platinum and Taco-Spike like this.
  13. Oct 13, 2021 at 1:13 PM
    Taco-Spike
    Two Trucks
    Cthulhu[QUOTED] likes this.
  14. Oct 13, 2021 at 1:36 PM
    ErikTRDTUNDRA
    Erik
    Did you use provided mounting hardware?
  15. Oct 13, 2021 at 2:10 PM
    Cthulhu
    No I used the SDHQ mounting kit.
  16. Oct 13, 2021 at 2:55 PM
    ErikTRDTUNDRA
    Erik
    It appears to come with mounting hardware correct? Any particular reason for not using the hardware it came with? Don’t mean to bug ya to death just wanna get the correct hardware for mounting.
  17. Oct 13, 2021 at 3:18 PM
    Cthulhu
    No worries, I just saw SDHQ’s bracket specifically designed for the Tundra hood bulge and figured it’d be easier than using the brackets that came with the bar. Hindsight, I should’ve saved the money and used the bracket that came with the bar.
  18. Oct 13, 2021 at 3:57 PM
    ErikTRDTUNDRA
    Erik
    Ah perfect, exactly the reason I asked. Appreciate your advice.
  19. Feb 6, 2022 at 11:11 AM
    #49
    Spielightdude
    Spielightdude New Member
    Joseph
    2019 Tundra TRD off road and towing package
    Cthulhu, Great setup and love the look.
    What are you running in the hood gap there?
    I am looking to do something like that as I want to keep away from the grill area and I have a 2019 SR5.
    Thanks
