Black OEM Interior Trim
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Voyagermike, Feb 25, 2017.
  1. Apr 6, 2017 at 3:02 PM
    Voyagermike
    Voyagermike [OP] New Member
    California
    Let me see if I can find the links from tacomaworld. I haven't done this yet. Due to not getting my Tundra just yet
  2. Apr 6, 2017 at 3:06 PM
    Voyagermike
    California
  3. Apr 6, 2017 at 7:52 PM
    TexasMofo
    TexasMofo New Member
    Chad
    Great Country of Texas
    2017 Toyota Tundra TRD Pro
    Illegal Tint 2 Shims/ 3 inch Shacke
    What kind of lights are these? I need some in red!!!
    az1441[QUOTED] likes this.
  4. Apr 6, 2017 at 8:37 PM
    az1441
    az1441 6-0 G7s on the road
    Steeler Country
    2017 Toyota Tundra TRD Pro cement
    4" Readylift 35" Toyo M/T 20x9 0 BMF BATL Retrofit w RGB LED Halos and Strips
    Theese are blue/green LEDs in my dash that replaced that stock orange crap :)
  5. Apr 7, 2017 at 10:09 AM
    R-C
    R-C http://101financial.com
    Ryan
    Las Vega$
    2017 TRD Pro
    Ive been interested in doing this, its just not cost effective for me to order the parts. Was thinking about Plasti dipping them? Not sure it would hold up to the Vegas heat.
    Found this video https://youtu.be/Of2K-J0leMc
    for the disassembly have to pay extra close attention to the 1:33 mark :thumbsup::thumbsup::thumbsup:
  6. Apr 7, 2017 at 10:31 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Ok did you get the vinyl to curve in to the shifter area and cup holder area or did you trim it right at the edge.
    Reason why i ask is i have tried to do detail like that going into an area and there is always extra material that cant sit flush. Even heated and stretched. Maybe im doing something wrong but thinking about it its extra material when going that direction so stretching is wrong. It needs to shrink.
    Voyagermike[OP] likes this.
  7. Apr 7, 2017 at 11:13 AM
    Darth Tundra
    Curt
    17 CM TRD Black
  8. Apr 7, 2017 at 11:14 AM
    Darth Tundra
    Curt
    17 CM TRD Black
    Those are Katzkin ...Camo...Heated
  9. Apr 7, 2017 at 11:22 AM
    Darth Tundra
    Curt
    17 CM TRD Black
    Swiches
  10. Apr 7, 2017 at 1:12 PM
    CTX84
    CTX84 New Member
    ^^^ WOW that looks good!!!
  11. Apr 26, 2017 at 10:44 PM
    HornetOne3
    HornetOne3 New Member
    Columbus ,Ohio
    2016 Barcelona red Crewmax SR5
    I did leave some extra to overlap underneath to stick together both sides around those curve area as over time they wont pulled and lifted on the top ,also this way they will stick to each other and last for good long time . As for the curve and sharp corners you might want to use low heat to work them in until the wrap fully set in with the contour of the parts then use high heat and your finger rub it in gently so the glue will stick better .
    Took me 3 times to get a perfect fit ,so be patience and some practice you'll like the result !
  12. Apr 29, 2017 at 8:35 PM
    Voyagermike
    California
    Parts have been ordered! Looking forward to getting these installed.
    @Titus_Will_Toyota
    Thanks Jordan!
  13. May 5, 2017 at 7:28 PM
    Voyagermike
    California
    The parts have arrived!
    Sooner then I thought.
    Truck has not:annoyed:
    JimboSlice413, Ozcomm, PG94 and 3 others like this.
  14. May 9, 2017 at 8:31 PM
    HUTCHJ
    HUTCHJ I can ride my bike with no handlebars
    J
    Keep us posted!
  15. May 9, 2017 at 8:33 PM
    Voyagermike
    California
    PG94, Patch999, Kilos and 7 others like this.
  16. May 9, 2017 at 8:34 PM
    HUTCHJ
    J
    Damn. I love that color.
  17. May 9, 2017 at 10:00 PM
    TwoMoreChains
    TwoMoreChains New Member
    2014 MGM Crewmax TRD OR
    not even sure what was happening in that video haha
  18. May 10, 2017 at 9:55 AM
    R-C
    Ryan
    Las Vega$
    2017 TRD Pro
    @TwoMoreChains ya no ones caught that gem yet, forgot it was even tundra related.
  19. May 10, 2017 at 2:05 PM
    #49
    Voyagermike
    California
    Getting there!
    PG94, JRock, JH5370 and 1 other person like this.
  20. May 10, 2017 at 5:06 PM
    #50
    Voyagermike
    California
    Done! What a pain in the ass. Took a lot longer then I expected. The passenger side was the worst. Removing the trim below the glove box took me a while to figure out.
    IMG_1771.jpg IMG_1772.jpg IMG_1774.jpg IMG_1775.jpg IMG_1776.jpg IMG_1778.jpg IMG_1779.jpg IMG_1780.jpg IMG_1781.jpg
    bulldog93, gkelm, TxLock21 and 21 others like this.
  21. May 10, 2017 at 5:16 PM
    #51
    HUTCHJ
    J
    I like it! Very utilitarian. Looks great!
  22. May 10, 2017 at 5:20 PM
    #52
    Voyagermike
    California
    Thank you sir! Glade it's done. Like I said the worst part was figuring out the panel/trim under the glove box. The trim with the vents on the driver/passenger side was way to easy.
    I almost forgot how everything went back together. Lol.
  23. May 10, 2017 at 5:21 PM
    #53
    HUTCHJ
    J
    Lol I know that feeling. I really like the non chrome air vents. We're this easy to remove?
    Edit: nevermind. Lol. I see the entire install process now.
  24. May 10, 2017 at 5:31 PM
    #54
    Voyagermike
    California
    The two side vents attached to the outer trim pieces were really easy. All you need is decent trim removal tool. Those are the first to come off in the initial tear down.
  25. Jun 30, 2017 at 5:12 AM
    #55
    KB Voodoo
    KB Voodoo New Member
    Chad
    2017 Tundra Pro Crewmax, Cement
    Many KB Voodoo Fabrications accessories!!
    That looks pretty awesome!!
    Do you have a link to the kit that you bought?
  26. Jul 3, 2017 at 5:31 PM
    #56
    KB Voodoo
    Chad
  27. Jul 3, 2017 at 6:03 PM
    #57
    Voyagermike
    California
    No problem. :thumbsup:
    KB Voodoo[QUOTED] likes this.
  28. Jul 4, 2017 at 4:18 AM
    #58
    Scpringle
    Scpringle New Member
    Jackson MS
    2015 red Tundra double cab 4.6 L 4x2
    running boards , TRD sway bar and tundra 08 SR5 wheels. FRACmod, pop&lock and backup sensors installed .
    Get an SR like mine and its comes in all black! :rofl:
  29. Nov 22, 2017 at 10:13 AM
    #59
    Sting Ray
    Sting Ray New Member
    Ray
    Vegas
    2017 SR5 Crewmax
    Not enough space here...
    is there a difference in that center panel 2wd vs 4wd? does the center panel come with the 2 vents already?
  30. Jan 18, 2018 at 6:47 AM
    #60
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    Love this!
    PG94 and Voyagermike[OP] like this.
