Bought a RZR and 12' trailer. Truck is a dog!!
Discussion in 'General Tundra Discussion' started by FloridaTundra, May 18, 2020.
  1. May 18, 2020 at 7:00 PM
    KeetAz
    KeetAz New Member
    Gilbert AZ
    2020 SuperWhite PRO
    Am I the only one that sees a problem with people going 80 mph while towing? Slow it down people!
  2. May 18, 2020 at 7:01 PM
    Not at all. 65MPH max while towing.
  3. May 18, 2020 at 7:02 PM
    KeetAz
    KeetAz New Member
    Gilbert AZ
    2020 SuperWhite PRO
    Word! :thumbsup:
  4. May 18, 2020 at 7:03 PM
    FloridaTundra
    FloridaTundra [OP] New Member
    Vero Beach, FL
    2011 Toyota Tundra CrewMax
    7" lift
    I use tow haul mode to keep truck in 5th at 2500rpms. In regular mode it turn 3000+ I understand that the 35s play a huge roll in this, but it's just worse than I expected. Guess I need to wind her a little harder.
    Rica25 likes this.
  5. May 18, 2020 at 7:04 PM
    Wallygator
    Found the problem!
    So funny when people completely change the gearing in the truck and expect stock performance...then blame the truck for a situation they created. Since diesels have almost 1000 ft lbs of torque they can better weather the big tire/no re-gear ignorance.
    Oh and the 7" lift didn't help at all either. The truck is already a brick and now it's a 7" higher plus bigger tires brick.
  6. May 18, 2020 at 7:06 PM
    Wallygator
    Or have the truck re-geared to bring it back to proper specs.
    GODZILLA and Cpl_Punishment like this.
  7. May 18, 2020 at 9:22 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    I'm thinking a super charger might help :thumbsup:
  8. May 18, 2020 at 9:27 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    What's the issue doing 80 while towing out of curiosity? If you're driving smart and within the trucks limits, I don't see how it's much different than not towing. Especially in Florida where it's totally flat.
    OP get a blower if you want to go fast towing.
  9. May 18, 2020 at 9:28 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The 35s are killing you. Regear
  10. May 18, 2020 at 9:30 PM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    I tow a 24’ camper 5-6klbs at 70mph, S4 and sits right at 2900-3k RPM and will easily pull past that. Plenty of power left. I’m on 33’s
  11. May 18, 2020 at 9:34 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Must be something wrong with your truck.
    Even my 3rd gen 4runner with the 5vz can pull my 3500# trailer and 2 quads with ease at 80, it doesn't set acceleration records but can easily keep up and pass. There is no way a 5.7 could struggle with that load.....
    Cpl_Punishment likes this.
  12. May 18, 2020 at 9:34 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    For one, check out speed ratings of trailer tires. Many are rated for 60-65 mph max.
    Second, a 12’ trailer most likely has no brakes of it’s own. What is your trucks stopping distance with another 1500 - 2000 lbs behind it at 80 mph?
    chugs, JLS in WA, GODZILLA and 9 others like this.
  13. May 18, 2020 at 9:47 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    Take the drop brackets off and slow down a little bit; the truck is fine.
  14. May 18, 2020 at 10:04 PM
    17inferno
    17inferno New Member
    My truck in a 2017 Limited crew cab Tundra 5.7 with bigger tires, and wifes is a Lariat Ram crew cab with th hemi. I tow a lot, 3000 (my sxs, that pushes a lot of wind) up to 10000, and it does fine, but I hate to say it, the Ram does tow quite a bit better...wouldn't tell her that though. :)
  15. May 18, 2020 at 10:10 PM
    Redcon41318
    Redcon41318 New Member
    Slow it down go 40-50mph, cruise at 55mph when towing. Drive to arrive
  16. May 18, 2020 at 10:54 PM
    ND90
    ND90 New Member
    2019 Limited Off-road
    Maybe some underlying issues?
    I have a 21 foot hydro tilt bed and have pulled my Jeep wagoneer and J10 around and barely feels like it’s there
    Cpl_Punishment and Tundyfundy like this.
  17. May 19, 2020 at 12:04 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Toyota really dropped the ball on this....
    sorry, too soon?
  18. May 19, 2020 at 1:47 AM
    Bravohook
    Bravohook New Member
    Addame
    NY
    2007 RCSB
    Cool Things
    Brother, your feeling the same thing I felt when I went to a half ton. Had a 2002 7.3 powerstroke before my Tundra. Wasn't fast but you could put anything behind it and it would tow like a dream. I towed a D5 dozer on a goosneck trailer at 70mph with out a sweat. I put my 3500lb camper behind the Tundra and you can definitely feel it.
    Now I just leave earlier for my hunting trips. Keep it at 65 in Tow/Haul and S mode set to 5th. Tundras like to gear hunt so S mode I can keep that under control. The 5.7 just doesn't have the torque curve a diesel has. You have to get into high rev range to feel it. Which I don't normally do.
  19. May 19, 2020 at 2:20 AM
    #49
    StoneyWV
    StoneyWV New Member
    Calvin
    2020 Tundra TRD Sport
    Rough Country Level,
    Proper tool for the job. You don't buy a Diesel because you tow twice a year, and you don't buy a 1/2 ton truck because you want to not feel a load behind it.
    Instead of 35's and a 7 inch lift you could have installed the supercharger for probably about the same cost. I've never gone up over 3 inches in tires and not re-geared. For the money it's the best investment you can make in a lifted truck if you perform the work yourself. Depending on the tire type, it's just as much the excess rotating weight as it is the leverage arm change with the additional height. Double trouble.
  20. May 19, 2020 at 5:33 AM
    #50
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    Not really a disadvantage, but you'll keep the rpms down without it. You might see some fuel savings. Hes not towing a very heavy load, around 3000lbs. The truck should handle it just fine.
  21. May 19, 2020 at 6:47 AM
    #51
    spicychickentundie
    spicychickentundie New Member
    Danny
    SOMD
    2014 Barcelona Red Tundra SR5 CM 4x4
    TRD RSB
    My boat is about 5000-6000 lbs on the trailer depending on fuel and gear. I bought it a few years ago over 200 miles from home. At the time I owned a Tacoma and I knew a 200 mile tow with that much weight would be hard on it so I used a buddy's Duramax Denali. It towed like a dream. On the highway the Denali go in to 6th gear and chugged along effortlessly, like the boat wasn't even back there. It didn't even shift out of top gear on grades. When I got home and towed with my Tacoma it was so bad I had to buy a Tundra to tow safely. My local boat ramp is only 3 miles from home and my boat shop is about 15 miles. Tacoma to Tundra towing was night and day. Tundra is a good tow rig, but it is still a night and day difference between the Tundra and a diesel.
  22. May 19, 2020 at 6:54 AM
    #52
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Why did you replace your last diesel with a gasser?
  23. May 19, 2020 at 7:01 AM
    #53
    AircoolerKirk
    AircoolerKirk Old School VW Nut
    Allen, Texas
    Magnetic Gray Metallic 2017 Tundra TSS 4wd
    Yup. Ive towed thousands of miles, never needed to be above 70. Ever.
  24. May 19, 2020 at 7:49 AM
    #54
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    Amen!
    GODZILLA, Cpl_Punishment and Oey12 like this.
  25. May 19, 2020 at 9:03 AM
    #55
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    :rofl::rofl::rofl::rofl::rofl::rofl::101010:
    Bravohook[QUOTED] and RPS1030 like this.
  26. May 19, 2020 at 9:25 AM
    #56
    Cavalrysr5
    Cavalrysr5 New Member
    Jared
    2020 tundra cavalry blue sr5
    I have done something similar(probably not 6000 pounds) but that bastard did better than the v6 tacoma I had with the auto.
    I just did a tuscon to socal haul of my brother's stuff. Truck did great! It was around 6000 pounds of crap and never did I feel like it didn't have enough power.
  27. May 19, 2020 at 9:59 AM
    #57
    15whtrd
    15whtrd Mr. Blonde
    I bought this truck with intentions of buying a travel trailer and towing occasionally. As well as a good camping rig. The travel trailer hasn’t happened yet LOL. But I have towed a few things including a 3000 pound boat and trailer. I thought it towed great. I had thought about getting a diesel and I’m so glad I didn’t. The amount of use that truck would get would be silly to own the diesel for me. I have used them in the past and they are a dream out on the highway. But the maintenance cost for how little it would be used and the fact that they really aren’t intended to just be driven back-and-forth to work on a short commute. It would literally have to be a truck I left in the driveway and only used for the specific purpose of long trips hauling something.
    I mostly just haul ass now.
  28. May 19, 2020 at 10:28 AM
    #58
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    I'm in the same boat as you. I'd love to have a toyhauler camper, but would need 3/4 or higher with a diesel to handle it (payload and torque). I have a company provided truck to commute and use for work. My personal truck only gets about 10k miles per year on it as a result.
    I really cant justify buying a $50k plus diesel truck to sit in the driveway most of the time. For now I'll just tow within my means...
  29. May 19, 2020 at 10:55 AM
    #59
    15whtrd
    15whtrd Mr. Blonde
    I’m right around 5K a year Haha. I was going to pick a toy hauler or travel trailer that was well within the means of the tundra. I like them small and agile. Plus I need one to fit in a certain spot in my driveway. Looking at 21 feet total so around a 17 or 18 foot trailer. Which is perfect for me and the wife. Obviously a big giant travel trailer would be sweet But our trucks are right around 10 K max towing. Personally I’d like to be about half that for various reasons. In a perfect world I’d have a big bad diesel and a 30 foot toy hauler LOL as well as the toys to go along. But I know I’d only go once or twice a year. So the smarter choice for me would to be to keep it half ton capable. I’m sure my truck
    is down for the task of once or twice a year.
  30. May 19, 2020 at 11:58 AM
    #60
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    I'd prefer as small as possible too, but my utv is 82" tall and 66" wide and weighs about 1800lbs which means a tall and wide trailer. Sadly that would require a diesel truck most likely
    GODZILLA and 15whtrd[QUOTED] like this.
