Brake service mode
Discussion in '3rd Gen Tundras (2022+)' started by markshoffit, Sep 7, 2023.
  1. May 2, 2024 at 8:18 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
  2. May 2, 2024 at 9:13 PM
    eddiefromcali
    Eddie
    100% Stock
    Which bolts gave you grief? Caliper bracket bolts are easy, the caliper pin bolts are tough if you don't have means of holding the sliding pin from spinning
  3. May 3, 2024 at 2:40 AM
    Dpoll995
    Dpoll995 New Member
    Houston TX
    2024 Tundra Limited
    It’s in the manual
    Tundrastruck91 likes this.
  4. May 3, 2024 at 5:10 AM
    umrex
    umrex New Member
    The bolts were all easy to take off. Idk how to make the caliper piston retract. Some have mentioned to leave the truck in neutral, which I prefer not to do especially when truck is jacked up. How does one retract the caliper piston correctly?
  5. May 3, 2024 at 7:16 AM
    eddiefromcali
    Eddie
    100% Stock
    Turn off the auto ebrake, open up the brake fluid reservoir, apply 12v to the ebrake plug to retract the internals, then use a caliper spreader to push the piston in. You can also turn the piston clockwise and that will also drive it in. I didn't go this route as the seal was twisting. I applied 12v and pushed it in little by little.
    MrKABC and Tundrastruck91 like this.
  6. May 8, 2024 at 1:27 PM
    Oldandfat
    Oldandfat New Member
    Cannuckastan
    2024 SR5 TRD Offroad Lunar Rock
    this was my thought, but apparently you need to do more
  7. Jul 31, 2024 at 11:18 AM
    SiXGUN
    SiXGUN New Member
    Eddy
    2022 Tundra SR5 6.5 Bed
    My 2 cents to help someone that may be doing this in the future - Just replaced my rear rotors and pads. Ended up leaving the truck in Neutral jacking up one side at a time with wheel securely caulked. I removed the ebrake motor and manually compressed the piston while backing the ebrake motor out with a torx bit. Not sure this is the best way but it worked. It was my first time dealing with an electronic parking brake so I had to improvise some.
  8. Jul 31, 2024 at 11:19 AM
    SiXGUN
    SiXGUN New Member
    Eddy
    I essentially used TakiEvo's recommendation in this post. Thanks TakiEvo!
