Brand new Tundra with major paint bubbles under clear coat
Discussion in '3rd Gen Tundras (2022+)' started by waves, Nov 22, 2022.
  1. Nov 22, 2022 at 7:48 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Makes me wonder if when dealer lot porter peeled the fallout protection film they inadvertently separated the white backing from the adhesive liner…
    take a close up shot of the edges of the the body line where the passenger fender meets the hood
  2. Nov 22, 2022 at 10:18 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
  3. Nov 23, 2022 at 6:10 AM
    Retired...finally
    My Fiat 124 had strange markings on the paint. A few days in the sun cured it. I think what happens is the white protective film is applied before the paint is done curing/drying. Or water seeps under the film and is held there for an extended period.
    So, give it a few days in the warm sun, if there is any and see if the spots go away.
  4. Nov 23, 2022 at 6:29 AM
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    Either way,
    I would have your Toyota dealership figure it out for you. You paid a lot of money for the truck. Let them work for it.
    Henry1jg, JLS in WA and Soflo like this.
  5. Nov 23, 2022 at 8:25 AM
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    Asking the real questions. This should have never been cleared for customer delivery in the first place. I don't care what bull$hit line the dealer feeds you...there's no excuse for this.
    I'm not saying it'll do much good, but after this is all resolved I would contact Toyota's Brand Engagement Dept about it. Link: https://support.toyota.com/s/article/How-do-I-contact-Toyo-7636?language=en_US
  6. Nov 23, 2022 at 8:31 AM
    osu1978
    osu1978 New Member
    Take it to the dealer and let them make it right. Don't start messing with it like I would and screw it up more before they have a chance to identify the issue. You don't want them blaming anything on you which they may very well try since their apparently so incompetent to let this truck out the door as is anyway.
    Buildn and landphil like this.
  7. Nov 23, 2022 at 9:13 AM
    TheLordwoulddriveaTundra
    TheLordwoulddriveaTundra New Member
    2022 Tundra Platinum Crewmax 4WD, Mag Grey
    Talons Cat Plate Tuff Skinz Inserts RetraxOne XR Bed Cover Premium Shield PPF Revivify Coating OEM Console Safe WeatherTech Mats
    a blow dryer/heat gun will likely take care of it like others have said. This is actually pretty common with new vehicles after the protective shipping film is removed. Most people never know it because dealers take care of hit ahead of time. My 3rd gen had the same thing when I went to the dealer to pick it up but they were already in the process of taking care of it before I got there.
  8. Nov 23, 2022 at 10:36 AM
    TundyMcTunra
    TundyMcTunra Irrational people are not often convinced by facts
    Lost in the PNW
    2010 Tundra Limited Crew Max 4x4, 2018 Tacoma Inferno TRDORDCSB, 2019 Rav4 Lunar Rock, 1991 4Runner Crawler. Ivan Stewart Edition
    In my 30+ years as a self employed auto detailer I have see this exact thing more times than i can count. Unfortunately your Tundra is a victim of production manufacturing.
    Factory automotive paint takes a minimum of 30 days and can take up to 90 days to fully cure depending on the paint manufacturer and the thickness of its application. Many times the white protective vinyl sheating they use for transport has been applied well before the paint has had time to cure. Your vehicle shows up at the dealership and when they remove the protective film it actually lifts the clear coat from the sub level paint causing separation between the clearcoat layer and paint. As I have told my many clients that have had this issue and like others here have said I would open a case with Toyota and have the affected areas repainted.
  9. Nov 23, 2022 at 11:00 AM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    What do you mean after the pandemic ? They never gave a shit, before or after pandemic. Very few people actually care enough to do it right the first time, always time to do it again the right way. I will never understand lazy people.
  10. Nov 23, 2022 at 7:06 PM
    YOTA_IL
    YOTA_IL New Member
    Yes a heat gun will take care of that all vehicles can come with it. It’s moisture under the wrap they remove.
    Here is my old ladies hood of her 2023 Highlander, we used a heat gun light heat and boom instantly gone!
  11. Nov 30, 2022 at 11:25 AM
    waves
    waves [OP] New Member
    Update: went back to the dealer, definitely no clear film, they tried to buff it out and it didn't do anything. General opinion was that clear coat has separated from the paint when vinyl factory protection panels were removed. They offered to repaint the hood and right fender, I refused, so they offered to buy it back and get me into the only 4x4 Limited w/6.5 ft bed they had in stock. Ended up paying about $3k more in options I didn't want or care about (sunroof, air suspension, Qi charging) but this one doesn't have any paint issues that I can see. On the minus side, air suspension makes for a bumpy ride compared with standard suspension and there seems to be no way to soften it.
    Kap1, myt1, TundyMcTunra and 2 others like this.
  12. Nov 30, 2022 at 11:28 AM
    Breathing Borla
    Northern Illinois
    geez, thats kinda shitty that got delivered to the customer like that.
    I keep second guessing buying one of these things, it seems like there is more and more BS.
    very unlike toyota, just a rough new model launch so far
    TheBeast likes this.
  13. Nov 30, 2022 at 11:28 AM
    YOTA_IL
    YOTA_IL New Member
    Why did you not use a heat gun?! Like me and another person said.
    A heat gun takes that off….. ‍♂️‍♂️‍♂️‍♂️‍♂️
  14. Nov 30, 2022 at 11:30 AM
    YOTA_IL
    YOTA_IL New Member
    You can’t buff off that stuff.. that’s why a heat gun fixes it. Ugh! I woulda kept what you had and done the heat gun trick it removes it like magic just like how it removed it on my old ladies car that I posted the same issue about.
  15. Nov 30, 2022 at 11:57 AM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    With the air suspension being bumpy make sure and search the forum on the process to adjust the rear ride height. If the dealer didn't do the initial adjustment for you the rear is hitting the bump stops and causing the terrible ride.
  16. Nov 30, 2022 at 12:03 PM
    Breathing Borla
    Northern Illinois
    there is an official fix TSB from toyota for this now
  17. Dec 5, 2022 at 12:33 PM
    Yeah, not sure why a heat gun/hot hair blow dryer was not attempted. Takes no time at all and costs nothing. Forums are only as good as the advice given AND the advice taken. Heat gun/blow dryer, or paint work or $3K more for a different vehicle? Oh well.
    JLS in WA likes this.
  18. Dec 5, 2022 at 12:56 PM
    YOTA_IL
    YOTA_IL New Member
    Right!!! I even showed him my old ladies brand new highlander that had the exact same thing haha!!! Whatever though lol
  19. Dec 5, 2022 at 1:37 PM
    #49
    T315
    T315 New Member
    2022 Tundra Crewmax TRD Offroad
    You shouldn't have to use a heat gun to remove bubbles under a clear coat of a brand-new car. Who knows if the integrity of the paint has been compromised or whatever. Also, no one needs to take a random person's opinion online. "lol haha!!!"
  20. Dec 5, 2022 at 2:53 PM
    #50
    SoCalTundy
    SoCalTundy Tundra Owner since 2017
    Icon Shocks. Total Chaos UCA. Deaver u748 TC shackles Flowmaster super 50. Diode Dynamics fogs. 5.29 Revolution Gears. SSW 17" wheels on BFG 35x12.5
    People deal with issues differently. I'm with OP on this one. I shouldn't have to use a heat gun to repair an issue out of the factory and I wouldn't do a paint job on it either. It is never the same as factory paint. Personally, I would have taken them up on their offer to buy the truck back and gone somewhere else. But if you're satisfied with the solution, that's all that matters. Got a pic of the new truck?
    Hank Hill, myt1, Russ_S and 2 others like this.
  21. Dec 5, 2022 at 3:05 PM
    #51
    mannyg84
    mannyg84 New Member
    Usually when I take ownership of a new car I will spend the first Saturday doing a clay/seal/wax on it. Just what I do. I have had the leftover crap from the transport film and gotten rid of it. Now from another Toyota owner I know, not a Tundra, he had paint issues and after a fight Toyota bought his car back. Hope yours is an easy fix.
    Kap1 likes this.
  22. Dec 9, 2022 at 2:18 PM
    #52
    Hadelson
    Hadelson New Member
    Allentown - Pennsylvania
    23 Tundra TRD Pro. Fun Ride 2019 RS3 Roush SC Mustang
    Took Delivery of my 23 TRD Pro last Saturday. I completed a thorough walk around checking it. Washed and waxed it last week and all looked good. Now today, I checked it in early morning light and my hood looks exactly like this. It is almost an exact duplicate of the pictures you posted. Direct Sunlight and it's very hard to see.
    Took it over to Local Professional Detail shop. It's clear-Coat Separation. We also found a few other spots on the Passenger side Front Fender along the top. Went directly to the local Toyota Collision Center-Have appointment next week for them to review. Hmm.
    Henry1jg, TundyMcTunra and Russ_S like this.
  23. Dec 11, 2022 at 5:48 AM
    #53
    Russ_S
    Russ_S New Member
    Central New York
    2023 Tundra 1794 TRD Off Road
    Please share the results. I saw this post before taking delivery of a 2023 1794. It has this issue on the hood, part of the fender, and parts of the roof. I've taken pictures and emailed a detailer I've used in the past and some locally respected body shops. Trying to decide what I should do. I can still walk away from the deal as I haven't signed the final paperwork yet. I don't want problems and I feel if I take it I'm stuck with it and Toyota's "fix" will be a respray, which I really don't want.
    Leo's first likes this.
  24. Dec 11, 2022 at 6:27 AM
    #54
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Boom ! Nailed it with the correct diagnosis. Would there be any downside to a repaint, besides another 30 day cure time ?
  25. Dec 11, 2022 at 6:30 AM
    #55
    Russ_S
    Russ_S New Member
    Central New York
    And here's the advice from a local trusted body shop owner:
    Don't walk away-run! If it is truly delamination of the clear from the base color that is a major issue. To repair the panels affected each would need to be stripped to the primer sealer then re-base coated and cleared, this would include major disasembly of body panels and more. Honda is having a similar issue with some colors.
    Cause maybe the rap to protect it was allowed to bake in the sun on fresh paint or an issue with the time span between application of the color and clear coat. Finally, a poor chemical mix of the color or clear.
    Looks like I'm passing on this one.
    BTW, no other Tundras or new cars on their lot have this issue.
    Kap1 and Leo's first like this.
  26. Dec 11, 2022 at 7:34 AM
    #56
    Tell them to hit it with a heat gun. Ffs, why is no one taking this advice or asking the dealer to? Neither party has anything to lose if it is indeed trapped moisture. Myself and many others in this forum and every other car forum have seen this and used a heat gun/blow dryer and it worked. My truck had it, a guy on this thread posted photos of his with exact same thing and it was fixed with a heat gun. I mean, holy shit man. Why not try it? Takes no time and costs nothing. Why is the immediate reaction to do the most complicated, expensive thing first?
    in_the_mud, JLS in WA and YOTA_IL like this.
  27. Dec 11, 2022 at 7:50 AM
    #57
    Paul Moll
    Paul Moll New Member
    Paul
    Idaho
    2023 1794 TRD off-road
    Do we know for sure that the heat gun method will be a permanent fix? As in 10+ years down the road there won't be a problem in these locations.
    GG.Offroad, Boerseun and Russ_S like this.
  28. Dec 11, 2022 at 8:01 AM
    #58
    DrZoidberg
    DrZoidberg New Member
    Dave
    SATX
    Tesla MYP
  29. Dec 11, 2022 at 8:03 AM
    #59
    DrZoidberg
    Dave
    SATX
    Tesla MYP
    My white pro had some missing spots and chipped easily, so o sold it. I hope there’s nothing wrong with the production line right now and a batch rolled it like this because my 23 platinum was built last week and in transit.
  30. Dec 11, 2022 at 8:28 AM
    #60
    10+ years down the road, you're going to have issues with all the paint unless you've filmed, sealed, or coated your vehicle as much as necessary over that time period. Mine had zero distortions or blemishes afterwards. Then I filmed every part of my truck forward of the rear fenders. This isn't something new or specific to tundras. This is more common than people think across all brands and dealerships. Like I said in a post above, good dealerships typically have it taken care of before you get there. I would bet my Tundra that some of you guys had this happen to your trucks but you are completely unaware because they put it under heat lamps before you picked it up. If I hadn't asked why my truck was under the lamps, I would never have known.
