Brother's 2023 Tundra won't start, dealer clueless (SOLVED)
Discussion in '3rd Gen Tundras (2022+)' started by SDHNTR, Apr 9, 2024.
  1. Apr 17, 2024 at 9:04 AM
    #61
    Lifer
    Lifer New Member
    Vince
    2000 Ltd 4x4 2008 SR5 4x4 LB 2021 SR 4x4 LB
    Fab tech on the 2000
    Wow. That is a hard sell to me. Unreal
  2. Apr 17, 2024 at 9:05 AM
    #62
    ryanwgregg
    ryanwgregg 46,000 miles & counting...
    DFW, TX
    VXKA75L-PSUZZA
    .....OEM+ Mods..... ..I DO NOT WORK.. ....FOR TOYOTA....
    Let me see what I can find on that...
    I'm vaguely aware a Toyota Tech Tip that talked about this in regards to this...
    Leo's first likes this.
  3. Apr 17, 2024 at 9:14 AM
    #63
    SDHNTR
    SDHNTR [OP] New Member
    What if it's from a neighbor's house? Or city powerlines/utilities?
  4. Apr 17, 2024 at 9:17 AM
    #64
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
  5. Apr 17, 2024 at 9:18 AM
    #65
    SDHNTR
    Yes battery was checked and test results shown, all good. NSS was supposedly checked. As for the "Key RF Signal Interference. RF Response not received (electrical waves present)." I'm quoting directly off the Vehicle Diagnostic Report from Toyota.
    Tundrastruck91 and Leo's first like this.
  6. Apr 17, 2024 at 9:23 AM
    #66
    Matt2015Tundra
    Matt2015Tundra New Member
    That's certainly a possibility that would suck.
    The next time the truck doesn't start, I would methodically turn off any electronics around the house, one by one. With any luck, it's something simple like the garage door opener.
  7. Apr 17, 2024 at 10:23 AM
    #67
    GutenWurst
    GutenWurst New Member
    Middle Tennessee
    '23 Army Green 1794 w/TRD
    Hella Krusty and Leo's first like this.
  8. Apr 17, 2024 at 10:37 AM
    #68
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    So its not solved
  9. Apr 17, 2024 at 10:52 AM
    #69
    SDHNTR
    Haha. Yes, technically you're correct. It's been determined, not solved. Thus far, there is no solution.
  10. Apr 17, 2024 at 11:08 AM
    #70
    CRFL82
    CRFL82 New Member
    SWFL
    2023 Lunar Rock SR5/TRD Sport
    Try to get them to bring another Tundra to the same location. If that truck does not start as well, you can be fairly confident that it is a Tundra problem.
  11. Apr 17, 2024 at 11:12 AM
    #71
    nodak67
    nodak67 New Member
    JR
    since when is a rogue radio interference a toyota problem? this harkens back to the pirate radio stations in vehicles to fool FCC people (if you are old enough to remember those) :)
    Hella Krusty likes this.
  12. Apr 17, 2024 at 11:58 AM
    #72
    cmiles97
    cmiles97 New Member
    2018 Toytota Tundra SR5 4x4 XP
    XP package
    This right here. Prove it.
    Did they give him a loaner? If so it is obviously starting up with no interference. How about any other vehicle? No problems at the place, then it is a Toyota issue.
    Kung likes this.
  13. Apr 17, 2024 at 12:01 PM
    #73
    cmiles97
    cmiles97 New Member
    XP package
    This is where Toyota thinks your brother lives.
  14. Apr 17, 2024 at 12:06 PM
    #74
    GutenWurst
    Middle Tennessee
    The "field specialist team" explaining the "interference".
  15. Apr 17, 2024 at 12:12 PM
    #75
    SDHNTR
    I have a 2024 Tundra. I've been to his place a couple times since I've owned it and no problems for me. But his problem is so intermittent, that I'd have to move in with him to see if it happens to me too. He's got a 2 yr old and a newborn, so no thanks!
    MrKABC and Leo's first like this.
  16. Apr 17, 2024 at 12:17 PM
    #76
    Matt2015Tundra
    If you guys check out the link I posted earlier, you'll see the radio frequency interference with FOBs is a real and fairly common problem. And it's not just with Toyotas.
    That doesn't make it any less frustrating for the OP's brother, but finding the problem is half the battle. Finding the solution is the other half.
    ZappBrannigan and Mattedfred like this.
  17. Apr 17, 2024 at 12:18 PM
    #77
    MaineTundy
    MaineTundy New Member
    2012 Rock Warrior
    Dents and scratches
    Trade trucks with him for a couple weeks. Beat his up the mountain in 4lo while yours gets to sit in his driveway, cranking start couple times a day. A win win… for you. :)
    Retired...finally and Mattedfred like this.
  18. Apr 17, 2024 at 12:30 PM
    #78
    SDHNTR
    Haha! good idea.
  19. Apr 17, 2024 at 12:32 PM
    #79
    rlc177
    rlc177 Data Logger
    Northeast PA
    I looked up the FCC ID on the key fob it uses 314.35Mhz and 312.10Mhz
    and the RFID part uses 134.2Khz.
    Lot of different things use that frequency so it could be other brands key fobs or also chamberlain uses that frequency so possibly a problem with the garage door opener nearby.
  20. Apr 17, 2024 at 12:47 PM
    #80
    Rcflyersd
    Rcflyersd Wingnut
    Mark
    Dakota
    01 Tundra SR5, 02 Sequoia SR5, 23 Tundra Limited double cab
    Faulty 110 volt LED light bulbs (not in the vehicle) in a garage, etc. etc. especially the cheap ones can emit interference that will block low power RF signals. Have seen it cause garage door openers to not work or only have just a few feet of range. Disconnecting these or unscrewing them all of a sudden normal RF operation is resumed. Probably not what is going on with said vehicle but it is food for thought...
    ZappBrannigan, Polo08816 and rlc177 like this.
  21. Apr 17, 2024 at 12:51 PM
    #81
    rlc177
    rlc177 Data Logger
    Northeast PA
    Yeah that just came to mind that some LED bulbs interfere with that 300 mhz range
    https://www.allstyledoor.com/blog/l... drivers inside,can interfere with each other.
  22. Apr 17, 2024 at 1:09 PM
    #82
    Timmy23
    Timmy23 New Member
    OR
    23 SR5 CM TRD OR MGM Tundra
    3” lift kit, 35’s, WW flares, tonneau etc.
    Baby monitor is my guess.
    Mattedfred likes this.
  23. Apr 18, 2024 at 11:22 AM
    #83
    HLR_NM
    HLR_NM New Member
    Harry
    It was that Elf on the Shelf the whole time :rofl:
    Mattedfred and Leo's first like this.
  24. Apr 18, 2024 at 11:24 AM
    #84
    Polo08816
    Polo08816 New Member
    2014 BMW 335i
    I've experienced this.
    Rcflyersd[QUOTED] likes this.
  25. Apr 18, 2024 at 11:34 AM
    #85
    SM Tundra
    SM Tundra New Member
    Cody
    2024 Limited Smoked Mesquite Tundra
    No shot, OP said his brother has a 2 year old and a new born. I’d argue this would destroy the interior way faster than driving the other truck in the mountains in 4LO. That backseat stands/ area stands no chance with babies and toddlers. His truck would come back equally as ruined hahah
  26. Apr 18, 2024 at 12:11 PM
    #86
    Retired...finally
    To add insult to injury you don't have tow hooks to drag the truck out of the driveway and down the street away from the dirty RF.
  27. Apr 18, 2024 at 12:12 PM
    #87
    c&wsinbad
    c&wsinbad Pay yourself FIRST!
    Clark
    Copperas Cove, Texas
    2024 Magnetic Gray Metallic 1794 w-Saddle interior
    BAKFlip MX4
    @SM Tundra I've cleaned up my daughter and SIL vehicle a couple times; 4 children, 7/5/3/and 6months. It is TRULY an experience and generally takes all day. Shop vac gets a great workout! Fortunately leather seats can be scrubbed pretty well and then conditioned. Carpets--well, they take time to dry after cleaning.
  28. Apr 18, 2024 at 12:19 PM
    #88
    MaineTundy
    2012 Rock Warrior
    Dents and scratches
    OK, Ok, you got me. We never had kids. lol.
    Wouldn’t it be ‘funny’ if it’s the baby monitor as Timmy suggests.
  29. Apr 18, 2024 at 12:19 PM
    #89
    SM Tundra
    Cody
    Yea I’ve had to ban certain snacks to keep the mess to a minimum, plus have a seat cover in the back to help keep the mess down. But it seems no matter what I do it’s always a mess!
  30. Apr 18, 2024 at 12:21 PM
    #90
    Matt2015Tundra
    Most modern garage door openers operate at 315 Mhz, which is the same frequency as our FOBs. Just saying.
    Black widow TRD and Mattedfred like this.
