Bully Dog BDX tuner
Discussion in 'Performance and Tuning' started by darkknight2014, Nov 12, 2016.
  1. Feb 15, 2018 at 6:38 AM
    #61
    dradd
    dradd Sometimes there is just us
    City of Champyinz
    '17 TRD Pro
    pending...
    Just to make sure I am understanding you correctly. The BDX is hooked up to install the tune. Once that is completed you can unhook it and store it until you want to tune again. I am interested in a tuner but not interested in having a cable and device just hanging around in the cab.
  2. Feb 15, 2018 at 6:38 AM
    #62
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    @dirtydeeds sells these things I think. Maybe he could chime in here and clear up some of these discrepancies.
    O'hAodha likes this.
  3. Feb 15, 2018 at 6:39 AM
    #63
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Correct. I keep mine safe in the tool box.
    dradd[QUOTED] likes this.
  4. Feb 15, 2018 at 7:20 AM
    #64
    dradd
    City of Champyinz
    '17 TRD Pro
    pending...
    Thank you!
  5. Feb 15, 2018 at 7:26 AM
    #65
    Taco-Blender
    AZ
    2010 DC 4x4
  6. Feb 15, 2018 at 1:56 PM
    #66
    Troysbama
    Troysbama New Member
    Troy
    Tampa, FL
    18' White Tundra Plat CM
    6" DirtyDeeds exhaust TRD Front and Rear Swaybars (5.5" front lift and 4" rear lift) Maxtrac Spindle lift 2.5 Fox IFPs up front and 2.0 Fox for the rear +3 Coachbuilder Shackles, bushing, carrier bearing drop kit Dakar leaf springs Coachbuilder steering links FRAC harness Cheap Ebay Rivet fender flares (I really like) 33x12.5x20 Cooper ST Maxx that I'll be updating to 35s when they wear out 20x9" Fuel Boost wheels 1.25" spacers for rear wheels
    Are you sure this is not an adjustment on the Bullydog display ONLY? Mine doesn't work yet on my 2018 but on my old 2008 I'm pretty sure you needed the hypertech plugin to adjust speedo on the vehicle.
    Prostar 190 likes this.
  7. Feb 15, 2018 at 2:04 PM
    #67
    Taco-Blender
    AZ
    2010 DC 4x4
    That's possible. I'll jack it up +50% when I leave work today and see what it does.
    More to come.
  8. Feb 15, 2018 at 3:57 PM
    #68
    Taco-Blender
    AZ
    2010 DC 4x4
    You are correct Troysbama. Speedo remained unaffected but the BD speed reading read +50%.
  9. Feb 26, 2018 at 5:07 PM
    #69
    O'hAodha
    O'hAodha New Member
    2014 DC SR5 FFV
    Lift, 35's on 20's, BAmuffler/ dirty deeds budget dump, S&B CAI, NFAB Front and Rear bumpers, blacked out headlights and tailights.
    Alright, Performance tune, Performance throttle and perf. Shift points is impressive. Mpg gain and of course power. Running on 93octane.
    boostedtrdpro likes this.
  10. Mar 8, 2018 at 3:23 PM
    #70
    walter93
    walter93 a Newbie: speak slowly and use small words
    Walter
    Houston
    2017 White Tundra SR5 crewmax 4x4 5.7
    TRD air filter TRD air maximizer TRD dual exhaust Gatortraxx MX rolling tonneau cover
    The Bully Dog Website shows it should work for my 2017 5.7 flex. Have you also tested the Hypertech?
  11. Mar 8, 2018 at 6:37 PM
    #71
    dirtydeeds
    Keith
    USA
    more than I can list here
    It works on 17 now. I posted that back in 2016
    NCinCO and walter93 like this.
  12. Mar 8, 2018 at 6:38 PM
    #72
    dirtydeeds
    Keith
    USA
    I have tested Hypertech. They both make the same power. But Bullydog has more options.
    And unfortunately Hypertech will often times throw a check engine light on a 14+ tundra.
    walter93 and darkknight2014[OP] like this.
  13. Mar 8, 2018 at 6:55 PM
    #73
    walter93
    Walter
    Houston
    I just want to load a tune and not keep it plugged in all the time. All of the options are not very desirable for me, personally. I just want more HP, more TQ, and more MPG. Don't plan on changing tire size or disabling seat belt alarms, etc. It looks like the Bullydog BDX you can flash and unplug but the GT you have to mount on your dash. Is that correct?
  14. Mar 8, 2018 at 7:09 PM
    #74
    dirtydeeds
    Keith
    USA
    Both bdx and platinum are downloaded and may be unplugged after downloading the tune. Neither has to be left plugged in.
  15. Mar 22, 2018 at 6:50 AM
    #75
    Bigcav02
    Bigcav02 New Member
    Frazeysburg ohio
    2016 Black Tundra Platinum
    6 inch lift on 35’s
    Does the BDX do speedometer calibration as well?
  16. Mar 22, 2018 at 6:59 AM
    #76
    renlo
    renlo New Member
    Rene
    2016 Tundra Platinum
    Bilstein 5100 top setting Coachbuilder .25" Shim SPC UCAs Bilstein 5100 Rear
    BDX does not do speedo calibration. You will need the Hypertech in-line speedo calibrator
  17. Mar 22, 2018 at 7:05 AM
    #77
    Bigcav02
    Bigcav02 New Member
    Frazeysburg ohio
    6 inch lift on 35’s
    Thanks for the info I have seen it stated on several websites selling them that it does thought I would double check on here
  18. Mar 22, 2018 at 8:06 AM
    #78
    dirtydeeds
    Keith
    USA
    It can on some vehicles. So they list it as being able to do it.
    15whtrd likes this.
  19. Mar 22, 2018 at 8:52 AM
    #79
    Bigcav02
    Bigcav02 New Member
    Frazeysburg ohio
    6 inch lift on 35’s
  20. Mar 22, 2018 at 8:56 AM
    #80
    15whtrd
    15whtrd Mr. Blonde
  21. Mar 22, 2018 at 8:59 AM
    #81
    Bigcav02
    Bigcav02 New Member
    Frazeysburg ohio
    6 inch lift on 35’s
    Agreed I did just that you it’s a no go is Hypertech the only option then
  22. Mar 24, 2018 at 2:35 PM
    #82
    15whtrd
    15whtrd Mr. Blonde
    Got my BDX uploaded and installed in my truck now. Took it for a quick spin it definitely feels different. The throttle is much more sensitive but not as sensitive as tow haul. It will take some getting used to but I like it. I might want to turn the throttle sensitivity to stock when off-roading or install the trail tune. In preparation for this I’ve already been running premium the last two tanks of fuel. The shift points are much better. The transmission seems like it’s still figuring out what’s going on, but towards the end of my drive it started being more consistent. I did one full throttle pass into third gear, it held the gears out and made very confident shifts. I also noticed there is a option for zero point calibration if ever that comes into need. That’s cool! I’m glad I put the truck on the charger while doing the initial updating process of the tuner. It took about an hour total to get it all done.
    The best way I can describe how it feels is that it overall is more crisp. It feels more refined and accelerates with a purpose. It doesn’t short shift as much. It’s like a in between stock and tow haul with a little more power and tidier shifts.
    If you have kids and they drive it, you can have a speed limiter 65 or 75 mph lol.
    Neutral rev limiter, disable chime, horn,beep, power windows, multiple other peramiters. Its a nice tool.
    Oh and if you want to let the dealer know you use it, it comes with metal Bully Dog emblems. One for each side of your truck ha ha.
    GNTundra likes this.
  23. Mar 24, 2018 at 2:39 PM
    #83
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I didn’t know about the speed limiter and neutral rev limiter. Where are these options?
  24. Mar 24, 2018 at 2:42 PM
    #84
    15whtrd
    15whtrd Mr. Blonde
    I think it was at the main menu you go to vehicle settings. I was quite surprised at how much it listed. I did not try them all so I can’t confirm if they work or not. I would think they do because I didn’t see a option for speed calibration for tire size. And I know they listed for other vehicles.
    GNTundra and BlueBottle[QUOTED] like this.
  25. Mar 24, 2018 at 2:43 PM
    #85
    15whtrd
    15whtrd Mr. Blonde
    You may want to make sure the tuner is up-to-date with the latest file for your truck.
  26. Mar 24, 2018 at 4:43 PM
    #86
    surferjoe956
    surferjoe956 New Member
    Joe
    2018 Toyota Tundra 4X4
    Is there an option for better gas mileage?
    I did t see the 2018 on there. Anyone know if that’s available yet?
  27. Mar 24, 2018 at 5:21 PM
    #87
    15whtrd
    15whtrd Mr. Blonde
    There is not an option for better gas mileage. But some claim to get slightly better mileage if you can keep your foot out of it. I would think you might want to keep the stock shift points for better mileage. But I really don’t know, as I’m still a day into using it. And I think I remember reading somewhere that it’s not available for 2018 yet. Best bet is to call them.
    surferjoe956[QUOTED] likes this.
  28. Mar 24, 2018 at 9:07 PM
    #88
    surferjoe956
    Joe
    Yeah mines only got 400mi on it so far
    15whtrd likes this.
  29. Mar 25, 2018 at 10:58 AM
    #89
    dirtydeeds
    Keith
    USA
    2018 is still about 6 months out
    15whtrd likes this.
  30. Mar 25, 2018 at 11:15 AM
    #90
    15whtrd
    15whtrd Mr. Blonde
    Thanks for all your help Keith. The tuner was installed without a hitch. It feels really good I like it.
