Bully Dog GT tunes settings
Discussion in 'Performance and Tuning' started by stujaspermma, Mar 25, 2020.
  1. Jun 13, 2020 at 3:30 PM
    Tundra_power
    Tundra_power New Member
    Nick
    I would call them back and make sure they fix it. I have the bdx one which is super easy to install and more user friendly. Just call them back or dirtydeeds might know what to do...
    Tundyfundy likes this.
  2. Jun 13, 2020 at 3:31 PM
    Tundra_power
    Nick
    And make sure you have a charger hook up to your battery very important...
  3. Jun 13, 2020 at 3:33 PM
    bigheadjack
    bigheadjack New Member
    2016 DC SR5 5.7 FFV 4x4
    Bilstein 5100s BAMuffler Standard 10” BD Platinum GT AFE Pro Dry S Method 705 18" Toyo AT3 LT295/70R18
    Yeah, I'll call them on Monday. I do have a trickle charger ready to go.
    Mnorris1206 likes this.
  4. Jun 13, 2020 at 6:01 PM
    Mnorris1206
    08 tundra
    I was told by BD to use a charger not a trickle but idk I would think it would be ok.
  5. Jun 13, 2020 at 7:01 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I don’t think a trickle charger will work. It has to be a certain number of amps. I think 30 or so. Just make sure it meets the amp requirements.
  6. Jun 13, 2020 at 7:08 PM
    bigheadjack
    sounds good! I'll pick one up.
  7. Jun 14, 2020 at 4:51 PM
    TX210Tundra
    TX210Tundra New Member
    2008 RCSB 5.7 2WD "Sport" / 2022 Limited Hybrid
    2008 - SOS 2/4 Lowering Kit : Firestone Bags : Bilstein Sports at 4 corners : TRD Pro Grill : TRD Pro 18in BBS Forged : Grip Pro LSD : Mike's "ByeNanny" : ARH LT 1 3/4 : ARH Cats : 3" X-Pipe: 3" Dual Borla XR1's / 3" Vibrant Resonators: 3" Tail pipes: DIY SABM: TRD Intake : AFE T/B Spacer : TRD Accelerator : LED Interior/Exterior : Atoto Pro HU : Cerwin Vega 10in Slim : AVS Visors : Sequoia Leather Seats : TRD shift Knob - OVTuned "Spicy 91 Torque Tune" 2022 Limited Crewmax Sonic Red Hybrid - TRD Filters : EGR Window Visors : Cheer Dring Android Adapter : RC Bed Cover : RC 1.75 Level Kit : Undercover Swing Case
    Yep I used a regular charger here when I installed my tune.
    Question, anyone else have a dead spot in the performance tune ? When I take off it goes then hits a spot in the rpm where it just hits a wall and picks right back up and goes after a second or two.
  8. Jun 14, 2020 at 5:00 PM
    Mnorris1206
    08 tundra
    I had that happen on the regular tune running performance shift took the performance shift off and some how its gone now. I like the bully dog itself but not sure yet what tune I want to keep it on im still messing with mine alot to try to see what I like most.
  9. Jun 16, 2020 at 2:49 PM
    bigheadjack
    I was finally able to get on the phone with BD today. apparently what happened to me is common. the customer service guy did a remote session and directly loaded the correct files onto the card. I'm going to pick up a charger on my way home and get this thing going.
  10. Jun 16, 2020 at 8:32 PM
    bigheadjack
    Ok, this is fun. I have it on premium with the throttle and shift points set to performance (and in beast mode). it’s not a rocket, but it feels so much better...it’s not running in quicksand anymore.
  11. Jun 16, 2020 at 8:55 PM
    Tundra_power
    Nick
    Make sure you run 93 octane looks like everything work out for you...
  12. Jun 16, 2020 at 10:13 PM
    bigheadjack
    yes, i have 93 in it. i'm not in tow/haul, so not beast mode. i do have the nannies turned off.
  13. Jun 17, 2020 at 5:41 AM
    Mnorris1206
    08 tundra
    O had mine in performance shift mode. But I experienced something that concerned ne so I turned it off.
    So from secound into third a couple times track control came on i didn't feel the tires brake loose so I was concerned that it was the trans slipping. Has anyone experienced this before ?
  14. Jun 21, 2020 at 9:25 PM
    009m
    009m New Member
    2010 Black Tundra Platinum
    Tuner, cold air intake, catback exhaust
    The Bully Dog GT states in the set up screens that at least a 10amp charger is required. Im glad I did not try to use my 1amp trickle charger, at the end of the day I had to shell out $70 for a decent 10 amp charger, but it was something I can always use and that money outweighs the risk of bricking my ecm.
  15. Jun 21, 2020 at 9:31 PM
    SalsaTheTundra
    SalsaTheTundra New Member
    jd
    Birmingham, Alabama
    2008 Salsa Tundra Double Cab SR5 5.7
    Ubar led headlights K&N filter +50HP
    Anyone run the economy tune? i need the extra mpg but don’t wanna lose a ton of power. I might just have to sacrifice mpg bc i love my performance. i’m using stock tune rn.
  16. Jun 21, 2020 at 10:06 PM
    Tundyfundy
    Bay Area, CA
    There you go! 10 amps it is.
  17. Oct 20, 2020 at 7:01 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    I'll be towing my camper 2000 miles to Canada from Florida. Tow/performance/ performance or tow/economy/ economy? I have a small tank on flat lands in regular tune /economy/ economy is giving me average of 10mpg. I want to be able not to have any problem with elevation, but don't want to stop for fuel every 200 miles.
    Any opinion will be greatly appreciated.
  18. Feb 1, 2022 at 8:57 PM
    ChewyTheTundra
    ChewyTheTundra New Member
    Mitch
    2013 Tundra SR5 Texas Edition 5.7L 2WD
    Bullydog Gt Tuner, dual single in single out Flomaster Super 44s, 3/2 leveling kit, 35x12.50R20 Federal MTS Xplora tires on 20x9.5 -18 offset moto metal black and chrome accented wheels, bullbar, LED 6500k headlights and fog lights, tri-fold tonneau cover, Line-X spray in bed liner
    Id be more worried about why my wife is so uncomfortable using her work computer lol. You're not a child. What is she in the fbi or something?
    I know this is an old post.. but yes mine does the same exact thing and always has in performance shift mode while on premium tune. I rune performance shift points on rugular tune 99% of the time and i like it. Ive never tried premium tune with stock shift points though
    Mnorris1206[QUOTED] likes this.
  19. Feb 2, 2022 at 3:06 PM
    #49
    Mnorris1206
    08 tundra
    I have just recently sold my truck lol. I actually still have the bulldog tuner if anyone is looking for one. My wife didn't want me using her computer because it was provided by IU, Indiana University. Lol
  20. Feb 7, 2022 at 8:24 AM
    #50
    MoToad
    MoToad New Member
    Toad
    BC Kanuckistan
    2009 Tundra DLX
    My new (to me) came with the Bullydog GT Prem. As a wire was pulled off I had to figure out how to reinstall it. All done now. With all this very complicated setup I don't think I would buy another especially as people have mentioned there are others a lot less complicated. With the battery charger hookup, it can be done without if your battery is at 12.5 or above. Oddly mine read 12.7 and at first Bullydog was telling me it was 11.5. So, I don't know if it's there way of saying use the charger or what. I did leave the charger on for a couple of hours (don't use the truck much and it's cold here), disconnected and used without.
  21. Feb 24, 2022 at 9:11 PM
    #51
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Quick question on these. If your battery dies does your computer lose the last set tune?
  22. Feb 25, 2022 at 8:22 AM
    #52
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    It shouldn't. I've had my tune installed for a little over 2 years and have disconnected the battery multiple times and it's still there.
    Mountun Goat likes this.
  23. Feb 25, 2022 at 8:31 AM
    #53
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Tunes are hard written. Battery disconnect only resets learned values.
    Mountun Goat[QUOTED] likes this.
  24. Feb 25, 2022 at 9:15 AM
    #54
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Thanks fellas :fistbump:
  25. Mar 15, 2022 at 9:04 AM
    #55
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Woohoo installed my tunes! :thumbsup:
  26. Jul 27, 2022 at 11:45 AM
    #56
    Echoesineternity
    Echoesineternity New Member
    Has anyone had the invalid characters in vin error in update agent for the bullydog tuner gt+ gas? T401. I’m able to install the correct year and model of tundra, but when I go back to download and update the actual tunes I get this error in update agent. And when I go to setting my vin is definitely in there so I don’t think it’s been previous locked to anyone else.
