Bully dog vs DAP tuning
Discussion in 'Performance and Tuning' started by IronHead90, Jan 9, 2018.
  1. Aug 9, 2018 at 9:25 PM
    #91
    No, not into potentially clogging my cats with a CAI. I may do some headers down the road, but honestly I may just get a muscle car at some point to cure that craving.
    trdprobped17[QUOTED] likes this.
  2. Aug 9, 2018 at 9:34 PM
    #92
    trdprobped17
    trdprobped17 New Member
    That's understandable. Besides, the stock air intake works better with most mods, than the aftermarket ones.
    T-Rex266[QUOTED] likes this.
  3. Aug 12, 2022 at 5:56 AM
    #93
    Steamin
    Steamin New Member
    2017 silver tundra crewmax 5.7 Trd trim
    Bought new June 2017. Mods done May-June 2019 (I got busy, and boy am I happy): *Elka 2.5 coil overs front, elka 2.5 rear both with reservoir cylinders: https:/us.elkasuspension.com/product/2-5-reservoir-front-rear-shocks-kit-for-toyota-tundra-2007-to-2017-2-in-to-3-in-lift/ (set to Elka factory settings, with built-in compensation for lean, 2.5" of suspension lift in front). (Bought from Toytec, installed locally) *Total chaos UCA: (bought Toytec, installed locally) *New rear leaf spring pack: don't have link (provides about 2" of lift and stiffens things up a little bit) *35x12.50 Falken on 20" MR 309 Grid "race" wheels (Really, really regret that I didn't get 18" or even 17" wheels. Like the look and road performance, wish I had more rubber to play with on the trail, poor choice). *Stealth light bar in grill valance: https://www.roughcountry.com/toyota-30in-led-bumper-kit70655c.htmlgclid=CjwKCAjwuqfoBRAEEiwAZErCshDWqD9kgBWOkMW3JR7J4Q0STQuMzrP2CZ5pWdlsICepeiPyVB4M-xoCWEwQAvD_BwE (this thing is bright, and almost drowns out my high-beams even at distance. It cost about $250... I have no idea why anyone would spend over 1K on a rigid bar) *LED projector headlight bulb replacement: (gotta find the link) *Headlight Revolution LED fog light replacement: https://headlightrevolution.com/2014-2017-toyota-tundra-led-fog-light-bulb-upgrade-gtr-lighting-ultra-series/ (similar to post above about the bar... these are expensive, but about 1/3 of rigid, and plenty bright for both on and off-road use) *Dark window tint (matches the rear and back window, so quite dark). *stubby antenna (Don't do this if you live in a rural area without XM, it looks cool, but like much of it's ilk, it isn't functional and you lose signal easy. My long antenna whistles above 80 mph though and I have satellite radio). from Ebay June 2017-July 2019 *Chrome delete (this wasn't easy or particularly cheap, and I started 2 years ago, just did the bumper ends ). Done: grill surround, pro-grill insert, badge overlays-matte black, Front bumper ends, 1d6 color matched bumpershellz (messed up the install, made it waaay harder than it is, found the directions once they were on and one was cracked), rear bumper came color matched. Most were used parts found locally or on ebay. Next up: In the next two weeks: -RCI Skid plates -RCI Rock Sliders both to be installed by Toytec in Denver Later (whenever I can pull it off without my wife killing me): *Front winch bumper *Rear arb air lockers *Exhaust upgrade: Bam 8" or OEM PRO *Rear bumper replace Seems there's always one more thing to do...
    I ran a bullydog gt on my ‘17 tundra 5.7 ffv for 3 years. I had zero issues with it and enjoyed a very nice driving experience. Great, immediate throttle response.
    Shifting is light years better than stock; quick and firm.
    I have run 35s since I tuned it and the tune eliminates the need to re-gear, unless you’re looking to do a lot of rock crawling.
    Mine was hammered on in the desert. My feeling is that that 5.7 is so overbuilt, in every way, but more so even with the big ffv injectors, that there is only upside to tuning for better performance.
    The increased fuel economy with any “performance” type tune on a massive V8 is a unicorn. More power, quicker throttle and torque responses, etc all burn more gas. It’s a simple equation.
    *Oh, and what they don’t tell you, but Keith at DirtyDeeds told me: When you’re on the performance tune, you gotta run high octane or you WILL develop engine knock.
    Anyway, ran it 3 full years. Lots of trips to the sand and other off-road adventures and the BD made it all better.
    For me it was perfect and there are zero signs of any issues caused by the tuner.
    It’s also nice how it allows you to customize your lighting, warning chimes, etc. (Haven’t had a car since the early 90s that didn’t yell at me for not wearing my seatbelt, until I turned it off with my tuner in the ‘17.)
    For the money the BD platinum gas tuner was perfect for my needs. (And at first I was scared it would f up my motor, but not at all).
    I also like that it allows you to read and clear codes very simply.
    I cannot speak to the DAP tune.
    dirtydeeds likes this.
  4. Aug 12, 2022 at 6:33 AM
    #94
    dirtydeeds
    Keith
    USA
    more than I can list here
    Yes. Yes it will. And the Bullydog gives you tons of options. You can change the tune to your liking. It’s not just one thing that you’d better be happy with. If you’re not happy with the throttle response, change it. If you don’t like how it shifts, change it. If you wanna run regular instead of premium because you’re going on a long trip, change it.
  5. Aug 12, 2022 at 6:37 AM
    #95
    dirtydeeds
    Keith
    USA
    Your findings are very odd. I run e30 in my 06. Untuned. Fuel trims go up a little. But the truck still gets 15-17 mpg depending on how I drive it.
    only e15 doesn’t have any affect on economy what so ever.
  6. Aug 12, 2022 at 9:03 AM
    #96
    Tundra1D6
    Has anyone with the bully dog gt canned tunes had these two issues;
    Flat spot on “performance shifting” from 1-2 3-4 shifts? My truck Boggs down when shifting, I removed the performance shifting and put it back to stock
    Reduce power when flooring it from a stop, almost like it has a rev hang? This is on a regular tune, not stock or performance using 89 octagon fuel in an 08 2wd crew max.
    Ive updated the tuner as of three weeks ago also
  7. Aug 12, 2022 at 4:45 PM
    #97
    V10Ace
    V10Ace New Member
    Salem, Oregon
    '21 TRD PRO
    Harrop w/ Prospeed goods & Kooks LTs
    Shrek from DAP flew into the NW last night for his annual tuning event with PNW Tundras this weekend and he tuned my '21 Pro and a '20 a few hours prior. First time doing so on either year and there were no hiccups. Much better throttle response and no more gear hanging. Will be towing my 30' TT Labor day weekend.. we'll see how it does.
    AZTundra and WVI like this.
  8. Jul 12, 2023 at 1:42 AM
    #98
    BlackMax
    BlackMax New Member
    Chad
    Blue Ridge Mountains, Virginia
    2010 Black CrewMax TRD Rock Warrior
    BullyDog GT Tuner, Drilled & Slotted Brake Rotors, 305/65R17 BFG A/T KO2, K&N Air Filter
    This may answer some of your questions about the BD GT gas tuner. I made a video of my 0-60 times without the BD, and then with the BD tune. I actually found that the 93 octane towing tune gave me better results over the 93 performance tune. I've been running the BD towing tune for a little over 5 years now with no complaints. Here are the links to the 2 videos on my Youtube channel.
    2010 Tundra CM 4x4 TRD on 33x12.50-17 tires: https://www.youtube.com/watch?v=yWjAVncp-5o
    2010 Tundra CM 4x4 TRD on 33x12.50-17 tires with the BD GT tuner installed: https://www.youtube.com/watch?v=H1qfw24vAeY
  9. Jul 12, 2023 at 4:22 AM
    #99
    Tundra1D6
    Can you take a look and tell me what version software your running ?
  10. Jul 12, 2023 at 1:01 PM
    #100
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, DIY Traction Bars, Tuning by snivspeedshop.com
    @Tundra1D6. Have you tried removing he GT tuner, return to stock, and seeing if it still happens? I removed mine when I was getting DAP tuned. It was doing the same thing. I could let off and it would shift then act normal. The tuner didn't know what to make of it. Could be something in torque management. Wonder if the BD left any code when un-installing it. I need to look into it myself as I got used to letting of then getting on it when it shifted.
    Good luck.
  11. Jul 12, 2023 at 1:14 PM
    #101
    Tundra1D6
    I have and it’s not really an issue. I’m at the point where it’s not really doing me much of anything. I run the lowest tune in an effort to not burn 93 octane. The trans acted all sorts of wonky with performance shifts so that’s turned off. It’s mostly a gauge at this point.
    But I had hopes mine simply wouldn’t update or they have a better version tune now available
    Mdl[QUOTED] likes this.
  12. Jul 19, 2023 at 2:19 PM
    #102
    BlackMax
    BlackMax New Member
    Chad
    Software: 2.1.7.0 1000
