Camaro stuck in a box, how to get it out- UPDATE: Camaro out of the box.
Discussion in 'Off-Topic Discussion' started by Dr Doobie, Apr 28, 2021.
  1. Apr 29, 2021 at 1:26 AM
    HighonFirewood
    HighonFirewood Everything can be fixed with a hammer.
    Stage Left. Colorado
    2019 Tundra
    Put 2x4s along the side to give a little buffer (like bumpers in a bowling alley) so the dollies only go north and south/not east and west.
  2. Apr 29, 2021 at 1:54 AM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    I got an idea I have done it before jack the car up and put a jump box on the starter so ground the ground of the jumper pack to chassis and positive to the big starter cable that will juice it up so you can either remote start the car or pop the locks. Not sure if anyone suggested that didn’t read thru all the post
    please use jack stands safety first
    Wallygator and Dr Doobie[OP] like this.
  3. Apr 29, 2021 at 2:24 AM
    RdKing
    RdKing Not A Roll Model
    Rich
    Eastern Seaboard
    2019 Tundra Platinum 3R3 / Barcelona Red
    Roadtunes By: Taylor's Audio/Tech12Volts Alma GA. JBL Complete System
    ThcAk
    Our 2011 Camaro had a “keyhole” around the left side of the rear seat back to gain entry in the trunk of the battery dies.
    The 2010 should have the same.
    https://youtu.be/_SwK4kIfapU
    Good Luck
  4. Apr 29, 2021 at 2:47 AM
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    Forget the dollies unless the wheels are fixed to keep it from moving to the side and wedging into the wall of the container. Dish soap on the floor of the container. Find a appropriate winch (I would use a hand winch) more control with smaller movements. Drag it out .
    If all else fails, cut the side wall of the container to gain access to the driver door.
    lonedrake, Luckydog and Dr Doobie[OP] like this.
  5. Apr 29, 2021 at 2:52 AM
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    Freaking brilliant. Never would have thought of it, yet so simple and obvious.
  6. Apr 29, 2021 at 4:37 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    Good lord, just jack the ass and drag it out.
  7. Apr 29, 2021 at 4:48 AM
    slowpokepete
    slowpokepete New No More
    Peter
    Hillsdale, NY
    2007 Blue Tundra DC 4x4 SR5
    LOL post of the day and it's not even 8 am :)
    SPP
    Dr Doobie[OP] and RdKing like this.
  8. Apr 29, 2021 at 4:56 AM
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    I guess I don’t understand...if there’s enough room to shimmy around the side of the car in the container and get a floor jack behind it, how is there not enough room to open the door? Get a kid to squeeze in there and release the trunk from inside...
    Dr Doobie[OP] likes this.
  9. Apr 29, 2021 at 10:46 AM
    Dr Doobie
    Dr Doobie [OP] Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    It's parked nose in. And not nuff room to open the door
    SnowyTundra and Wallygator like this.
  10. Apr 29, 2021 at 11:11 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Agree. Dollies I've seen have wheels that caster, so the vehicle can be pushed sideways. That's a good plan for Camaro pinball.
    Too hard to get the front dollies in position anyway. You would have to jack up the rear fairly high for access at the front, then lift each front wheel enough to place the dolly. This will be extremely dangerous when that second front wheel lifts off the floor with one dolly already placed, and that friction patch is lost. The owner should be the one under all these jacks in the air, don't be volunteering OP.
    I don't think the dollies gain you anything anyway. The Camaro's front wheels will roll fine unless they're flat, but they will have to roll straight. Hopefully, the OP's wife left the steering wheel straight ahead.
    Jack up the rear wheels off the ground, and pull her out. All reverse, dead slow. Have helpers watch the sides and be ready to shut it down quick if it begins to meander toward a wall.
  11. Apr 29, 2021 at 11:25 AM
    Dr Doobie
    Talkeetna,Alaska
    I agree with you that dollies in the front are useless.
    The owner is disabled vet so I'm the one that will be doing whatever needs to be done under and around the the car.
    And yes, fortunately she locked the steering wheel straight:)
  12. Apr 29, 2021 at 11:26 AM
    des2mtn
    des2mtn On the scenery looking at the road
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    2x4s or 4x4s as mentioned as a buffer on the sides, then a jack under the rear to drag it out?
  13. Apr 29, 2021 at 11:30 AM
    Dr Doobie
    Talkeetna,Alaska
    Looks like that will probably be the safest way. Dollies should be here on the 4th of May
  14. Apr 29, 2021 at 11:36 AM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    We want video of the extraction.
  15. Apr 29, 2021 at 11:37 AM
    des2mtn
    SW
    Tonto cover
    I'm confident in you especially since the steering wheel is locked straight. A few spotters if available never hurt.
  16. Apr 29, 2021 at 11:48 AM
    Dr Doobie
    Talkeetna,Alaska
    Definitely going to take pics. Will try to get video
  17. Apr 29, 2021 at 12:26 PM
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    This issue is not that complicated here is your starter the main terminal of the starter goes directly to either the main terminal on the alternator or battery every vehicle is wired differently but still ends up in the same place at the Battery so If you get a jumper box and put the negative clamp to chassis or engine block and put the positive cable on to the main wire on the starter that will power up the car now you will be able to unlock the car with the remote or even start it if you want It’s simple
    Wallygator, Dr Doobie[OP] and RdKing like this.
  18. Apr 29, 2021 at 12:42 PM
    Dr Doobie
    Talkeetna,Alaska
    Yeah, that is a great idea and I've suggested that to the owner, but I think he has his mind set on dollies.
    SnowyTundra likes this.
  19. Apr 29, 2021 at 1:45 PM
    #49
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    Pull a tail light or license plate bulb and hook a battery to the wires. Now the car has power and you can unlock the trunk with a key fob. Leave it plugged in long enough and you’ll probably be able to start it. If not you can shift it to N and roll it out.
  20. Apr 29, 2021 at 1:56 PM
    #50
    Dr Doobie
    Talkeetna,Alaska
    I thought about that, but unless the ignition is on, or headlight/ running light switch is on I don't think that power will back feed to the battery?
    SnowyTundra and landphil like this.
  21. Apr 29, 2021 at 1:58 PM
    #51
    Wallygator
    Was your Camaro a convertible? Almost positive only the convertibles came with a keyhole, not the hard tops, which makes no sense whatsoever.
  22. Apr 29, 2021 at 2:04 PM
    #52
    RdKing
    Rich
    Eastern Seaboard
    eick thats brilliant!
    As long as the jumpers dont arc or ground out and pop the fuse it should back feed 12 volts to activate the key
    Well done!
  23. Apr 29, 2021 at 2:14 PM
    #53
    eick
    eick New Member
    Well as pointed out by OP the circuit may not be closed on the other end so it may not work :(
  24. May 4, 2021 at 6:32 PM
    #54
    Dr Doobie
    Talkeetna,Alaska
    update:
    My son and I went over today and were successful in removing the Camaro out of the container.
    We arrived at about 1:30 this afternoon and got to work. KIMG0488.jpg KIMG0489.jpg KIMG0490.jpg KIMG0491.jpg KIMG0492.jpg KIMG0493.jpg KIMG0496.jpg KIMG0501.jpg
    There it is, I'm not very good at documenting stuff.
    What we were able to do is jack it up, place the dollies under the rear wheels and just slide it over to one side. That gave us about 10"-12" of clearance between the car door and container wall. At that point we were able use the key to unlock and open the door.
    Then my son was able to slide in through the door, over the back seat, into the trunk and then was able to open it with the emergency release handle...
    Trunk now open we put a new battery in and started the car.
    While the car was warming up we got the ramps rigged up and stable.
    Then I removed my muddy boots,crawled in through the trunk like a snake got into drivers seat and backed it out at about 3:15
    I'd like thank everyone here for all your help and great suggestion. He is a happy vet, tickled pink!! He has an appointment with the va tomorrow and now he can go in his pride and joy!
    Edit: no injuries or damage during all that..
    He just sent me this txt. tire was a little low so I pull up to the house to put air in and didn't see a cooler!Resized_20210504_160724.jpg
  25. May 4, 2021 at 6:45 PM
    #55
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    There is a hidden lock for the trunk that you can use the key to open. The bad news is, its between the back seat and rear quarter panel inside the car.
    Whichever engineer thought that was cute should be kicked swiftly in the nuts.
    Your only real option here without breaking a window is jack up the rear, put it on dollies, carefully wheel it out. Then you can use the key to open the door (hopefully that has a lock) and work your way through to the trunk. Replace the battery and next time put an extension cord and a battery tender on it.
  26. May 4, 2021 at 6:50 PM
    #56
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Well dang I should really finish threads before posting. Good job!
    GODZILLA, NoRcptn, T-Rex266 and 5 others like this.
  27. May 4, 2021 at 7:04 PM
    #57
    Dr Doobie
    Talkeetna,Alaska
    It's all good bro, thank you!
    I'll make sure he knows about that,in case he's ever in a situation and needs to use it.
    SnowyTundra and Darkness[QUOTED] like this.
  28. May 4, 2021 at 7:27 PM
    #58
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    If your pal owns the container and has no plans of getting rid of it, he could have a welder come and fabricate a door in the side of the container (now that the car is out) so that he doesn't have people crawling through the car to get it out.
    Also, he might want to put some plastic/visqueen on top of the car while it's in the container. One little hole rusting through could create a world of hurt for a car stored in a container for 6 months.
    Maybe line the sides of the container with some old blankets, just in case.
    Darkness, TheBeast and Dr Doobie[OP] like this.
  29. May 4, 2021 at 7:35 PM
    #59
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    That looks much easier than just putting a key slot in the trunk like cars have had for 50+ years... :facepalm:
  30. May 4, 2021 at 7:46 PM
    #60
    Dr Doobie
    Talkeetna,Alaska
    Lol oh no!
    Next winter it's going in the heated garage for 8 months of storage, where it should have been stored last winter.
    The Motorcycle, atv, riding mower, rototiller, snowblower, and all that kinda sh!t is going in the container.
    I told him I would help, but he just didn't want to move all that stuff last fall and now he's dealing with the consequences of not taking anyone's help or advice. lol
