Can’t believe this actually worked.
Discussion in '2.5 Gen Tundras (2014-2021)' started by bensky, Apr 29, 2019.
  1. Apr 30, 2019 at 6:33 AM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    Did you sand the stock ones before painting?
  2. Apr 30, 2019 at 7:13 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Well done! I’ve had those 3 products in mind for some time too. Thinking of doing my bumper caps once my vinyl wrap starts getting worse.
    Inspiring, up close can you see inconsistencies in the finish? I’m concerned caps are larger areas that’ll be more noticeable.
  3. Apr 30, 2019 at 8:08 AM
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    This is what’s I have been wondering. I worry about durability. I typically regard using a spray can of paint on the exterior of the vehicle as temporary- as in it won’t stand up to the elements the way actual urethane automotive paint sprayed from a gun and then clear coated will. Also, the chrome has to be blasted or sanded for the primer to adhere, making the change irreversible. How well the primer adheres will be critical to the survival of the paint.
    If I were going to tackle it, I would sand the bumper ends, use a self etching primer compatible with the duplicolor, then a compatible clear. Finally, I would apply the 3M clear chip guard as far up the bumper ends as possible without being an eyesore. (The same/similar stuff that is applied to our beds and rocker panels from the factory)
    After using retail and custom mixed spray cans to do restoration work on steering columns, steering wheels, seat frames, and engine tins, I am pretty sure I could get a great final appearance, it’s the durability that concerns me.
    JoshuaA likes this.
  4. Apr 30, 2019 at 8:20 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Think I’ll just bite the bullet and get my body guy to do it, durability is an important factor for caps.
  5. Apr 30, 2019 at 9:13 AM
    lamikela1
    lamikela1 New Member
    Michael
    2019 Silver Sky Platinum Tundra 4X4
    Revolver X4 cover, Bedrug, Pocket Flares. Previously owned... '86 Hilux, '94 4-Runner '95 Taco, '05 Taco
    Good job!!!
  6. Apr 30, 2019 at 9:22 AM
    thaskin
    thaskin New Member
    tom
    Red SR5 DC 4.6
    HYPER CHIP, K&N FILTER SOME WARLORD RIMS 2"LEVEL KIT, TRD PRO GRIL
    Very nice, been wanting to do mirrors. But the red is expensive to have a shop do it. Might have to try this.
    Drk_Jdi likes this.
  7. Apr 30, 2019 at 9:24 AM
    Tundra$
    Tundra$ White Trucks Matter
    Las Vegas
    2018 SR5 4x4 off-road CM 5.7 Super Fast White
    3/1 readylift, 35x11.5r20 ridge grapplers, 20’ fuel wheels, bakflip revolver bed cover, console safe, N-fab side rails, mini antenna, 2019 TRD Pro grill, color match hood bulge, front bumpershellz, baby car seat, to be continued...
    Looks perfect. Wonder if a 2 part automotive clear would work with this paint. I have some and a spray gun at home. Should protect better. I’d buy some 040 super white auto paint but it’s over 100$ a gal online. Maybe I’ll try this on my bumper caps and grill pieces
  8. Apr 30, 2019 at 9:24 AM
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    Nicely done, Spraying metallic through a rattle can is always a roll of the dice.lol you did good:thumbsup:
  9. Apr 30, 2019 at 9:34 AM
    Deuxlatch
    Deuxlatch AirBus
    Chris (Latch)
    Tomball, Tx./Lafayette, La.
    2010 Super White Tundra CM
    TRD Supercharger, TRD Big Brake kit, MotoMetal wheels, Undercover Tonneau with dual swing out saddle bag tool boxes.
    I tried that same paint process with the same products on my Spyder DRL panels in the front but my clear coat still came out flat, no gloss. Wonder what I did wrong?
  10. Apr 30, 2019 at 9:36 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    See posts 15, and 25. Apparently the OP did a comparison test, sanding one end cap, and not sanding an end cap. He couldn't tell that sanding made any difference in the application, and skipped sanding after the test. The real test of the coating system will be in durability. Door handles will see a lot of wear and tear, scratches, etc...it will be a good test for the system and the OP promises to update as time passes.
    Application to the bumper ends will be a different kind of duty. Less wear from rubbing, more exposure to road grit, debris and chipping. The clear will have to be really hard to stand up to that.
  11. Apr 30, 2019 at 9:44 AM
    JohnLakeman
    Since these products are compatible with each other, your clear should be glossy unless you applied it too dry. You have to apply enough material that it flows out before drying, eliminating MOST orange peel.
    Another cause is attempting to spray the coating in a hot garage, in the middle of the day, on the hottest day in the middle of the summer...it will dry before it can flow out. In the worst case of this, the material is actually almost dry before it contacts the part. Professional products use reducers that are adjusted for the ambient temperature.
    Edit: Your experience is exactly what makes good results with a rattle can very difficult to achieve. In attempting to get gloss, you can apply TOO MUCH material resulting in runs or sags. Then you have to correct with nib files, or if extreme, strip, prep and try again. With rattle cans, you can not adjust the reducer to help with the ambient temperature.
    GlobalGuy likes this.
  12. Apr 30, 2019 at 10:03 AM
    Twinky
    07 double cab work horse
    Was the color match good enough to do touch ups on the body?
  13. Apr 30, 2019 at 10:18 AM
    Twinky
    A really helpful tip i picked up a while back when spraying clear from a rattle can was to use 2 can at the same time.
    You kinda lock your thumbs together and then you keep the 2 can pointing at the contact area and spray like normal.
    Clear doesnt like to be applied in multiple light coats. Not that you cant get good results that way, but its not ideal.
    The best results from clear come from riding the limit a tad less than the amount that will cause it to run/sag. Thats what makes an auto painter good. How well he can lay on the clear.
    Theres a vid on youtube that does a good job of showing how to do it. Ill see if i can find it.
    Drk_Jdi likes this.
  14. Apr 30, 2019 at 10:26 AM
    Deuxlatch
    Deuxlatch AirBus
    Chris (Latch)
    I went slow enough with the clear coat until it was about to run, and looked shiny, but it still dried to a matte finish, and the temperature here in Texas was about 70 that day.
  15. Apr 30, 2019 at 11:13 AM
    JohnLakeman
    At 70 deg, conditions for spraying should have been near optimum. If the clear was glossy after application, it should have dried that way, with or without runs. There are only two reasons I can think of why it wouldn't: (1) the clear was a product incompatible with the base coat, or (2) it was a clear product that was supposed to flatten to a matte or satin finish when dry.
  16. Apr 30, 2019 at 11:39 AM
    Twinky
    Well, humidity is a possibility in Texas. In deep east Texas it sure is. Thats just a guess though.
    Some rattle can clear coats you can recoat and the solvents in it will re-wet (for lack of a better term) the previous coat and clear it up. Normally that window is really short.
    Heres that vid about spraying clear i mentioned.
    If you decide to give it another go then you might like this way.
    https://youtu.be/TfNq8DEbT60
    JohnLakeman likes this.
  17. Apr 30, 2019 at 11:44 AM
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    *applause* i never would have guessed they had been painted!
  18. Apr 30, 2019 at 12:04 PM
    Deuxlatch
    Deuxlatch AirBus
    Chris (Latch)
    I will have to check the can closer when I get home. I may have to take a scotch brite pad to it again and then hit it.
  19. Apr 30, 2019 at 12:29 PM
    #49
    bensky
    bensky [OP] PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
    I tested the system on two of the small end caps. I sanded one and the not the other. No difference at all in finish or adhesion.
  20. Apr 30, 2019 at 12:34 PM
    #50
    bensky
    Ben
    Utah
    Mine was a little flat too when finished. I just waited 48 hours and then polished with a foam pad and a light cut polish. I used Meguiar’s ultimate polish.
  21. Apr 30, 2019 at 12:35 PM
    #51
    bensky
    Ben
    Utah
    I would recommend trying a light cut polish first.
  22. Apr 30, 2019 at 2:30 PM
    #52
    Trdordie
    Trdordie New Member
    2010 Soupacharged TRD Pro Prototype
    Test bed for future TRD Pro 1of1
    Sequoia painted door handles are a direct swap
  23. Apr 30, 2019 at 7:57 PM
    #53
    Knoyes
    Knoyes New Member
    Karl
    MD
    2010 tundra
    RC 3.5 lift, 35x12.5, Fuel rims,
    Outstanding work! Let me know how it holds up. That is next on my modification list with plasti dipping the badges
  24. May 1, 2019 at 4:56 PM
    #54
    itsjustmetal
    itsjustmetal New Member
    Ryan
    Dang that looks great for spray can! Body matched handles are the way to go!!!
    Rocko9999 and tundradude23 like this.
  25. May 1, 2019 at 5:00 PM
    #55
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    the balance tires in the van??
  26. Jun 29, 2019 at 6:29 AM
    #56
    jbcrewmax
    jbcrewmax New Member
    SETX
    2019 TRD Pro
    Looks amazing! You’ve inspired me to do this to mine.
    What grit did you use?
  27. Jun 29, 2019 at 4:53 PM
    #57
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    I'm going to try the Dupli-Color Megnetic Gray Metallic on my door handles, as well as some pocket fender flares. HOWEVER, for clear coat, and I cannot recommend this enough: Eastwood 2k Urethane "Aerospray". It comes in a spray can with a puncture button on the bottom of the can that is used to puncture an internal chamber wall and causes the two parts (clear paint; 2k activator/hardener) to mix inside the can. Let me tell you, I have used this product on several different projects (car parts; carbon fiber bicycle frames; pc cases) and it is awesome!!!! It gives a beautiful glossy finish (assuming you choose gloss although they have matte as well) and it is extremely hard (protective). It's about $25.00 a can. I'll post a thread about how mine turned out as soon as it is done.
    bensky[OP], thetwood and Drk_Jdi like this.
  28. Jun 30, 2019 at 7:50 PM
    #58
    Drk_Jdi
    Drk_Jdi New Member
    Jeremy
    Tacoma, WA
    2014 Platinum Crewmax Barcelona Red
    Belstien 5100's front to level Belstien 5112's rear w/ 1.5" block lift Tesla style Android radio Front windows tinted to match factory rears TRD shift knob - dark grey Color match mirror caps Color match handles Light bar in hood scoop
    Thank you for sharing this how to. Painted my handles today, came out really good. I just wish that I had washed my truck before I started, was just too excited to have color match handles!
    bensky[OP] and jbcrewmax like this.
  29. Nov 3, 2019 at 11:36 PM
    #59
    bensky
    Ben
    Utah
    Update: It’s been 6 months and many times through the car wash and they still look like the day I installed them.
    I also used the same paint on the AJT Designs vent rings, cup holder trim, and key fob. I did the key fob to give the paint a real torture test. Let’s see how it holds up to clanking against my other keys.
    ultraman29 likes this.
  30. Nov 3, 2019 at 11:39 PM
    #60
    bensky
    Ben
    Utah
    I used about twice as much clear coat as recommended (total of 7 coats) to get it shiny.
