Cant believe this... suspension
Discussion in '1st Gen Tundras (2000-2006)' started by Aaol1, Nov 1, 2023.
  1. Nov 3, 2023 at 2:33 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Yea, as long as the front isnt too stiff to get articulated. Looks good. Doors work easy while crossed up? If not, inspect body mounts.
    shifty` likes this.
  2. Nov 3, 2023 at 2:47 PM
    Aaol1
    Aaol1 [OP] New Member
    Sam
    05 DC tundra TRD offroad 4x4 V8 w/ LSD and tow
    2 inch lift, diff drop
    Just tried, everything was good! Thanks for that, good tip
  3. Nov 3, 2023 at 2:52 PM
    Aaol1
    Sam
    Ground to fender not sure I didn't measure at the spot I was at and my driveway is way off, I'll have to check some other time
    I'll wait and see how it settles before deciding on bringing it down one or not, I do have the diff drop so CV angles aren't bad, see pic
    shifty`[QUOTED] likes this.
  4. Nov 3, 2023 at 4:04 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    FYI 1/8" spacer = approx 1/4" as it's almost a 2:1 ratio when correcting lean.
    A 1/4" spacer will get you about 1/2".
    noahrexion likes this.
  5. Nov 3, 2023 at 5:22 PM
    Aaol1
    Sam
    Good to know! Had a taco before but never actually did the spacer
  6. Nov 4, 2023 at 9:19 AM
    mthoodbill
    mthoodbill New Member
    Mt Hood, Oregon
    2000 Tundra SR5 Access Cab 4x4
    Bilstein 6112, .5" front lift. 5100 rear. 17" FJ steel wheels
    That shock bolt to lower control arm is on backwards. Nut should be facing forward. I did the same thing when replacing lower control arms and found the bolt extended a bit too close for comfort to the cv axel boots. Easy fix and makes torquing a bit easier too.
    Aaol1[OP] likes this.
  7. Nov 9, 2023 at 10:23 AM
    Aaol1
    Sam
    Well alignment finally got done today, I thought camber was way off the way I set it but it wasn't too bad.
    This was done by a dedicated 4x4 shop with great reviews. I asked about caster still being in red , but they said it's normal due to SPC uppers being clocked at D , and it giving a +2 caster . I'm not an expert so I'm guessing that's fine?
    They also work with SPC uppers many times a week , again being a dedicated 4x4 shop
    Thoughts?
  8. Nov 9, 2023 at 10:47 AM
    shifty` Oddfellows local 151 behind the firehouse
    I think @assassin10000 would tell you you want the maximum caster you want while keeping camber and toe in check.
  9. Nov 9, 2023 at 1:51 PM
    bmf4069
    bmf4069 Something something Miller Lite
    Beau
    TX
    02 AC sr5 4wd v8
  10. Nov 9, 2023 at 2:01 PM
    Aaol1
    Sam
    Interesting, wonder what setting he had his SPC on
  11. Nov 9, 2023 at 2:06 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Your alignment specs are great! The caster is red because it's higher than the Toyota specs, but that's a good thing for lifted.
  12. Nov 9, 2023 at 2:08 PM
    Aaol1
    Sam
    perfect thank you! gives me some confidence haha
  13. Nov 9, 2023 at 8:00 PM
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC
    Looks good.
    Close to what @alb1k runs with his solo lowers (approx 4.5 caster iirc).
    OEM arms I typically recommend:
    -.3 camber
    2.6-2.8 caster
    .10-.15 total toe
    With extra caster arms, 3-5 degree caster is ok.
    Drive a bit faster, -.5 camber.
    bmf4069, FrenchToasty and shifty` like this.
  14. Nov 9, 2023 at 8:09 PM
    Aaol1
    Sam
    perfect! I must have missed the 2.6-2.8 caster for OEM only part at first, shop definitely didnt want to go for those numbers. Im glad I went with them lol
  15. Nov 9, 2023 at 10:35 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 350k+
    2” Lift, Bilstein 5100’s and 885’s, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags with Daystar Cradles. Spider Trax 1.25” Wheel Spacers, Factory Wheels wrapped with Toyo 285/70r17 AT2’s.
    Your numbers look good :thumbsup:
    Camber and Toe are important to prevent excessive tire wear. Castor is to keep you tracking straight. More Castor on the passenger side corrects for road crown.
    Less Castor isn’t necessarily a bad thing. Wider Tires and greater offset wheels offset the effects of less Castor.
    Also, too much Castor can affect handling, because as you turn, one side of the vehicle lifts and the other lowers, this effect increases with more Castor.
    Aaol1[OP] and shifty` like this.
  16. Nov 10, 2023 at 6:53 AM
    Aaol1
    Sam
    That's some great info, thank you! Sounds like I'm right where I'm supposed to be then, even the little difference in passenger to driver castor ( road crown correction)
    Diablo169[QUOTED] likes this.
  17. Nov 10, 2023 at 3:12 PM
    jwilly0404
    jwilly0404 New Member
    Jesse
    2001 TRD Limited AC 4x4
    Bone Stock
    I will say this, the lower coil over bolt is a pain in the ass to deal with. I just installed my new Bilstein’s and it wasn’t fun. I fought the passenger side then when I went to the driver side. I just dropped the lower ball joint out.
  18. Nov 10, 2023 at 3:14 PM
    Aaol1
    Sam
    Yea I put in new lower control arms to so it was easy. More costly, but easy
    jwilly0404 likes this.
