Carista OBD2
Discussion in '3rd Gen Tundras (2022+)' started by Papa Smurf22, Jul 13, 2022.
  1. Aug 1, 2023 at 5:16 AM
    #241
    Breathing Borla
    Northern Illinois
    glad I could help
    Hella Krusty[QUOTED] likes this.
  2. Aug 1, 2023 at 11:38 AM
    #242
    ziznack
    ziznack New Member
    Texas Y'all
    2024 Lunar Rock Platinum
    How did it get better? I'm just curious what you mean by that.
  3. Aug 1, 2023 at 1:10 PM
    #243
    DynoDog
    DynoDog New Member
    Located in North Texas. If anyone wants to use it.
  4. Aug 2, 2023 at 6:25 AM
    #244
    ryanjay11
    ryanjay11 New Member
    I used the Carista to remove the fake engine noise, back seatbelt dings from child car seats, and lowered the A/C temp.
    Well worth the cost of the unit and subscription price. I need to look at a couple of more settings before the 30 days is up.
  5. Aug 2, 2023 at 6:53 AM
    #245
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    Come winter, you all will be changing it back by 4 degrees... :rofl:
    ziznack likes this.
  6. Aug 2, 2023 at 7:34 AM
    #246
    ziznack
    ziznack New Member
    Texas Y'all
    It won't matter, we will just put it on high. Will blow the same temperature.
  7. Aug 2, 2023 at 7:50 AM
    #247
    Hella Krusty
    Hella Krusty New Member
    I also added these
    - Lane change from 3 blinks to 5
    - Long press unlock and all windows go down and sunroof opens
    It blows colder so its easier to maintain the desired temperature with less fan. It seemed that prior tp changing it, the AC had to be working overtime with the fan wailing away just to try and keep up. Now it just idles like it should...gets colder and maintians with less effort
  8. Aug 2, 2023 at 8:01 AM
    #248
    DynoDog
    DynoDog New Member
    I agree the seat fans and AC noise is loud.
  9. Aug 2, 2023 at 8:04 AM
    #249
    ziznack
    ziznack New Member
    Texas Y'all
    But it doesn't actually blow colder. The temp of the air coming out does not change. You are correct about the fan though.
  10. Aug 2, 2023 at 11:52 AM
    #250
    Hella Krusty
    Depending on what the setting is on. My truck cools off quicker with the temp set at warmer than previous with 20% fan operation
  11. Aug 2, 2023 at 11:58 AM
    #251
    ziznack
    ziznack New Member
    Texas Y'all
    Because the fan is working differently. So just like a home ac, the temp blowing out is based on the temp going in. It's not like the actual air blows colder because you changed a setting. Don't get me wrong, I made the same change, but it doesn't work like people seem to think. For a home ac, it is in spec as long as the return (where the air goes in) is within a certain margin of temp (14-20 degrees F) of what is coming out of the strongest vent. So if the air is going in at 100, the as long as it's blowing out colder the 85-80 degrees it is right. Adjusting the thermostat does not make the air colder, it just makes the air blow longer.
  12. Aug 2, 2023 at 6:47 PM
    #252
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    You’re correct for the home system. A 21-25° degree delta is common on todays systems. But in todays vehicles there’s the hot and cold sides of the air flow separated by a plenum (a big air flap/valve) it blends hot and cold air to get the desired output temp. I’m only guessing, but this change made via Carista is probably closing the plenum more to the hot side (cutting off more hot air) hence allowing more cold air output. This plenum method gives finer control of the output temp vs just cycling the AC on/off like at home. It also eliminates the hot water valve that was a common failure point in old vehicles. Hot water flows through the heater core all the time.
    Hella Krusty, Durtywrench and ziznack like this.
  13. Aug 7, 2023 at 8:04 PM
    #253
    ziznack
    ziznack New Member
    Texas Y'all
    So did this happen to anyone else? I had bought the veepeak and used the carista app. I had done the one year that had a free week. I cancelled the subscription by the end of the week and I have not used it since. This was probably 3 weeks ago. I had an error and plugged it in tonight and realized I was still able to customize and everything else the subscription did in the 1 week trial. I double checked that I had cancelled and that I was never charged. Don't get me wrong, I'm fine with it, but just curious if it happened to anyone else.
  14. Aug 7, 2023 at 9:08 PM
    #254
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra
    None
    One year sub is a free month.
    ziznack likes this.
  15. Aug 7, 2023 at 9:12 PM
    #255
    ziznack
    ziznack New Member
    Texas Y'all
    I believe that's only if you buy the carista. I am 99% sure it was one week.
  16. Aug 8, 2023 at 6:41 AM
    #256
    CRFL82
    CRFL82 New Member
    SWFL
    2023 Lunar Rock SR5/TRD Sport
    You can see the customizations without a sub, but you cannot push any of them through. If you can actually change something after canceling your subscription then you got lucky.
    ziznack[QUOTED] likes this.
  17. Aug 8, 2023 at 7:48 AM
    #257
    PoundHard
    PoundHard Knows just enough to be dangerous
    22 SR5 TRD OR Prem
    3" Lift, Defender Flares, EGR Deflectors, Ceramic Coat, UnderCover ArmorFlex, DIY De-chrome, Headwaters Seat Covers
    Yep this happened to me too. I was able to turn off the rear seatbelt chimes after I cancelled and the trial was over
  18. Aug 9, 2023 at 4:11 PM
    #258
    Topwhite007
    Topwhite007 New Member
    2023 1794 TRD
    06418 here if anyone around is interested.
    Just signed up with Carista for a 7day trial. Modded everything I wanted using old Vgate OBD2 reader I bought for like $15 years ago on ebay, i.e. all 5 sits dings, lane change to 5, doors open/close, steering wheel and sit adjustment when existing.
  19. Aug 9, 2023 at 7:00 PM
    #259
    Mlm682577
    Mlm682577 New Member
    DFW Texas
    MY22 TRD Pro, solar octane
    Mods - Retrax Pro XR tonneau cover - Fumoto valve - Tundra and TRD Pro badges - Rear differential breather relocation - OEM dash cam - OEM console safe - Custom bedside decal - Door and console compartment liners - Forward bed rail relocation - Added bike thru-axle locking mounts - Rhino cross bars - Light bar in lower grill - Front and rear door sill protectors - Auxbeam 8-button switch panel and fuse panel (GB80) - Top of tailgate “Tundra” overlays (solar octane) - Tailgate handle “Toyota” overlays (solar octane)
    Forgive my ignorance, I was looking at the Carista website. They only show that the device is applicable for a 2nd gen. Does one device cover all applicable vehicles or do you have to buy one specific to a Tundra. TIA.
    ziznack likes this.
  20. Aug 9, 2023 at 7:12 PM
    #260
    ziznack
    ziznack New Member
    Texas Y'all
    The vehicle listing when you buy it doesn't matter. I bought a veepeak on Amazon for a ten dollars cheaper and did the 1 week trial for carista
    Mlm682577[QUOTED] likes this.
  21. Aug 15, 2023 at 7:35 AM
    #261
    e263rd
    e263rd New Member
    Are theses specific to a manufacturer or one size fits all?
    Amazon doesn't seen to carry it any longer...
    Carista site states tundras 2nd gen, no option for 3rd...
  22. Aug 15, 2023 at 9:47 AM
    #262
    KrissyMattAlpha
    KrissyMattAlpha New Member
    2023 SR5
    So can someone tell me if all these scan tools will clear out a limp mode malfunction?
    I ask because... I've read in other threads that if you allow the 3rd gen to run out of fuel it automatically goes into limp mode. The fuel gauge on my 23 is completely ridiculous. With no rhyme or reason it just shows an arbitrary value and I'd like to be prepared on the day when it truly goes empty.
  23. Aug 15, 2023 at 2:50 PM
    #263
    iforceAZ
    iforceAZ New Member
    Does using this product and changing settings have any effect or reason they could use to void a warranty?
  24. Aug 15, 2023 at 5:25 PM
    #264
    Hella Krusty
    Good description I have it at a warmer temp with 70% less fan and its colder. Colder with 70% less work.....its blowing colder
  25. Sep 14, 2023 at 10:46 AM
    #265
    RandomTundra
    RandomTundra New Member
    Do you know if they’ve changed the options in the Carista app? I just got the Carista obd2 adapter and the app on my phone with the one month trial and under the customize tab here are my options
  26. Sep 14, 2023 at 12:41 PM
    #266
    ziznack
    ziznack New Member
    Texas Y'all
    Looks the same as mine from a few months ago.
  27. Sep 14, 2023 at 12:49 PM
    #267
    RandomTundra
    And you were able to turn off the fake v8 noise? Which section was it in? I don’t see it anywhere and all the videos I find for the 3rd gen tundra are showing more options then what I have shown on those two screenshots
  28. Sep 14, 2023 at 1:11 PM
    #268
    Maharisc
    Maharisc w/Patty
    Karl
    Does your truck meet the criteria of being a CrewMax with the JBL sound system?
    The DoubleCab with JBL will not have that option.
    The CrewMax without JBL will not have that option.
    Onetrack97 likes this.
  29. Sep 14, 2023 at 1:12 PM
    #269
    machd08
    machd08 New Member
    CLARENCE
    Sumter, South Carolina
    2025 Land Cruiser/Land Cruiser
    Just got Carista, turned off the fake V-8 noise, seat belt chime drivers side and adjusted the A/C to -2C.
    How quite it is now, that will change as soon as I get my Dirty Deeds exhaust.
  30. Sep 14, 2023 at 1:20 PM
    #270
    ziznack
    ziznack New Member
    Texas Y'all
    Sorry I take back my comment. Mine has an engine chassis option. Like another user said, if you don't have the jbl system in your truck, you don't have the fake engine noise.
    TunderMuffin likes this.
