Carista: Settings you can change on a 2019
Discussion in '2.5 Gen Tundras (2014-2021)' started by Cement, Mar 27, 2019.
  1. Sep 10, 2021 at 9:55 PM
    #61
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Nope, Carista doesn’t do either. Pretty sure you need Techstream.
  2. Sep 12, 2021 at 6:18 AM
    #62
    PJR202
    PJR202 New Member
    I don't see it on the list, but I would love to be able to increase the max volume of the GPS voice. It's half the reason I don't use it.
  3. Sep 12, 2021 at 6:44 AM
    #63
    Skyboss
    Skyboss New Member
    Oak Ridge NC
    2021 SR5 TRD Off-Road
    I think the answer is No, but can you do the customizations with Veepeak/ OBDfusion app the same way? Or are the customizations a Carista subscription thing only?
  4. Sep 12, 2021 at 4:37 PM
    #64
    Skyboss
    Skyboss New Member
    Oak Ridge NC
    So, I think I've figured out that OBDfusion does not have the customizations, however, I think the Carista app will work with Veepeak, instead of needing the Carista dongal. Can anyone confirm this? i already purchased a Veepeak to use with OBDfusion to check atf temp, but haven't used it yet.
  5. Sep 12, 2021 at 9:39 PM
    #65
    AndrewSmith
    AndrewSmith New Member
    Thornhill, Ontario
    2021 Sequoia Limited
    I didn't use the Carista dongle and it worked fine.
    But Carista can't do anything that Techstream cannot do.
  6. Sep 16, 2021 at 4:39 PM
    #66
    Skyboss
    Skyboss New Member
    Oak Ridge NC
    FYI; Carista and VEEPeak work great together. That was almost too easy. Customizations complete. Now the truck is mine.
    Henry1jg, Bammer and Drainbung like this.
  7. May 12, 2023 at 1:27 PM
    #67
    PDX_Beav
    PDX_Beav New Member
    Portland, OR
    2016 Tundra TRD Pro
    I'm geeking out on a way to shutoff the headlight warning buzzer (ding) when I turn off the ignition. Did you verify that carista can actually shut that off. I can't find an option anywhere in techstream.
  8. May 12, 2023 at 1:32 PM
    #68
    PDX_Beav
    PDX_Beav New Member
    Portland, OR
    2016 Tundra TRD Pro
    I should add that almost all of these settings that you can actually adjust in techstream or carista are also just built in customizations you can execute from the entune head unit. Check the customizations section of your owner's manual. Mine are on page 543 for a 2016 TRD Pro.
  9. May 15, 2023 at 9:13 PM
    #69
    AndrewSmith
    Thornhill, Ontario
    Oh, is that why it beeps when I turn the engine off with the door open? Pretty please tell me if you find any way to turn that off!
  10. May 16, 2023 at 4:21 AM
    #70
    PDX_Beav
    PDX_Beav New Member
    Portland, OR
    2016 Tundra TRD Pro
    You can turn off the headlight warning. I did. It with an OBDLinkMX+ and the Carista app.
  11. Jun 17, 2024 at 1:20 PM
    #71
    GbRunner10
    GbRunner10 New Member
    My dealer performed Toyotas SB for PCS with a modified vehicle without my consent. Long story short, they fried my radar, replaced it, but it’s now configured to default to “off” every time the truck starts.
    Can someone confirm for me what the “pre-collision system (pcs) sensitivity: remember last state. Disable/enable” does?
    I’m looking to see if I can set the pcs system to remember to be “on” every time I start the truck.
    Thanks!
  12. Jun 17, 2024 at 1:39 PM
    #72
    JohnWhicker
    JohnWhicker New Member
    You can change that through the truck menu if I remember correctly. Just research how to navigate to it. Is not a hidden setting that you need Carista for.
