CB shims as a very slight lift for the front?
Discussion in 'Suspension' started by CCLJ03, Jun 8, 2021.
  1. Jun 10, 2021 at 11:38 AM
    Eborseti22
    Eborseti22 New Member
    Evan
    2020 Toyota Tundra TRD Offroad
  2. Jun 10, 2021 at 12:16 PM
    CCLJ03
    CCLJ03 [OP] Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    Well right on the product page it says they are necessary for lifts really over 3”…
    @Coachbuilder1 do I need bump stop extensions if I do 1.5” of lift on the drivers side and 1” on the passenger?
    That would be a .5” and a .25” shim on the drivers side, and just a .5” shim on the passenger side.
  3. Jun 10, 2021 at 12:22 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Don't stack that much - for one, you shouldn't need the extra shim to correct the "lean" but measure your hub-to-fender on the corners just to check. But you'll run out of threads on the coilover hat with more than the .5" of shims. You can add a few 3/8 fender washers to address the bumpstop issues. You don't need the big ones.
  4. Jun 10, 2021 at 12:25 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    This is what mine look like with two shims
  5. Jun 10, 2021 at 12:37 PM
    CCLJ03
    Craig
    I would have 2 shims on one side, and one shim on the other. That’s too much?
    I measured last night and I actually have about 3/8” lean, which surprised me. Measured from center of the wheel to fender.
  6. Jun 10, 2021 at 12:37 PM
    Eborseti22
    Evan
    Good info guys - I appreciate it.
    OP post up some pics with your final decision!
    CCLJ03[OP] likes this.
  7. Jun 10, 2021 at 12:38 PM
    BUCS_KID88
    BUCS_KID88 New Member
    Are this .5 or 1 inch ?
  8. Jun 10, 2021 at 12:42 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    You only have enough room for .5" total, so one .5" shim (1" lift) or 2 .25" shims (.5" lift each). You're maxed at 1" of shim lift with stock top hats.
    I have 2 .25" shims (.5" lift each) for 1" total lift.
    CCLJ03[QUOTED][OP] likes this.
  9. Jun 10, 2021 at 12:44 PM
    BUCS_KID88
    Oh okay gotcha.
  10. Jun 10, 2021 at 1:13 PM
    CCLJ03
    Craig
    I sure will! Going to take a couple of months because I’m waiting for my stock tires to wear out but I’ll be sure to post some pictures when it’s done!
    Ahh. I see. Thanks so much for explaining it! I don’t really give a rats ass about the lean - didn’t notice it before I measured. 1” on each side will be fine.
    You think I’ll be alright without bump stop extensions since it’s only an inch, or is it better to put them on?
  11. Jun 10, 2021 at 1:25 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I'd say throw like 3 fender washers on each bump stop just to be safe. If you're not planning on off roading much it shouldn't be an issue, but extending the stops will help you keep your shocks from getting crushed if you get in a bad situation.
  12. Jun 10, 2021 at 3:21 PM
    CCLJ03
    Craig
    CB extensions would be better? I don’t mind just paying the $40 or whatever it is for the extensions.
  13. Jun 10, 2021 at 3:35 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Those extensions are overkill and would probably do more harm than good in your case. They are meant for 3-4” spacers, so you wouldn’t want to stick a 1” bump stop extension in when you're only lifting an inch. Think of it as close to a 1:4 ratio of bump stop extension to spacer lift.
    CCLJ03[OP] and BroTun13 like this.
  14. Jun 10, 2021 at 5:16 PM
    BroTun13
    BroTun13 New Member
    Erik
    Beaumont, CA
    2021 White Tundra SR5
    I agree I bought those CB bumpstop spacers as well for my 2" spacer kit and had no up travel left. I took them off before even trying to drive with them
  15. Jun 10, 2021 at 9:45 PM
    CCLJ03
    Craig
    So you just installed the spacers and nothing else? I go off-road sometimes but no rock crawling or anything crazy. When I’m off-road I’m usually towing a camper lol.
  16. Dec 2, 2021 at 9:27 AM
    Eborseti22
    Evan
    @CCLJ03 you wear those tires out yet?!
  17. Dec 5, 2021 at 2:01 PM
    CCLJ03
    Craig
    they did! Got new shoes but haven’t done the shims yet…
    Here it is with just the 275/70r18 cooper rugged treks -
    I’ll get the shims ordered and update you when it’s done! Hopefully soon but I’m weirdly busy.
  18. Dec 5, 2021 at 5:44 PM
    Eborseti22
    Evan
    @CCLJ03 looks great! How are those tires working out? Look mean, but a guy I work with has em and says they’re still really quiet for such an aggressive tread, I’m skeptical though once they get some miles on them.
    I hear ya on busy! Haven’t even been able to wash the truck in a couple months. Seems like every time I have a chance, weather is shit.
    looking forward to the update!
  19. Dec 5, 2021 at 6:08 PM
    #49
    CCLJ03
    Craig
    @Eborseti22
    They have been absolutely flawless off-road. I was really rough in them during elk season in September. They never even flinched!
    However… they are pretty loud. Not as loud as other tires as aggressive as they are (they’re more aggressive than some mud tires) but they are much louder than a standard all terrain. The shop also had to put a ton of weights on to balance them, and there is still a decent shimmy between 40mph and 65mph.
    I still love them though. I just know they are tough as shit and I’m not getting stuck.
