Cell phone mount?
Discussion in 'General Tundra Discussion' started by hi_rawb, Feb 24, 2018.
  1. Feb 15, 2019 at 2:46 PM
    #91
    pschiller86
    pschiller86 2017 SR5 CrewMax
    Paul
    Temecula, CA
    There is a back plate provide by Hondo that tightens it. It doesn’t screw into the truck at all though.
  2. Feb 15, 2019 at 2:49 PM
    #92
    pschiller86
    Paul
    Temecula, CA
  3. Feb 15, 2019 at 3:10 PM
    #93
    salmonator
    salmonator New Member
    Tigard, OR
    2019 Tundra SR5 4x4 DC
    Also tablet mount for nav/map apps
  4. Feb 15, 2019 at 3:19 PM
    #94
    salmonator
    Tigard, OR
  5. Feb 15, 2019 at 4:00 PM
    #95
    hudrock
    hudrock New Member
    So Cal
    18 Tundra before 20 Sequioa now
    Check out Insignia Apple MFi Certified 6' Coiled Charge-and-Sync USB to Lightning Cable https://ebay.us/TkqHru via @eBay
    #95
    dmiller[QUOTED] likes this.
  6. Feb 16, 2019 at 9:41 AM
    #96
    CaptSpaulding
    CaptSpaulding ...ain't nothin but nothin
    Jake
    2010 White DC 4x4
    A-pillar ram mount, fits my Samsung Note 8 perfectly. No issues on the heaviest dirt trails
    Watt maker and Outbound like this.
  7. Feb 16, 2019 at 11:25 AM
    #97
    Cuzbee
    Cuzbee New Member
    2019 Platinum
    Based off of other recommendations from another post I ordered the setup from Hondo Garage. Received it a couple weeks ago and absolutely love the thing. And apparently they upgraded their design to allow the vent to open up almost completely. IMG_5151.jpgIMG_5149.jpg
    Njmike13 and CaptSpaulding like this.
  8. Feb 16, 2019 at 11:37 AM
    #98
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    Does anyone have any recommendations for a 2nd gen with the column shifter? I want to avoid the magnetic mounts since I use wireless charging a lot.
  9. Feb 16, 2019 at 12:24 PM
    #99
    CaptSpaulding
    Jake
    2010 White DC 4x4
    I used the A-pillar for a ram mount. Took some adjusting so I wouldn't hit it when turning or flipping the turn signal. Once adjusted, wouldn't change a thing. However, to change from landscape to portrait on the mount takes some re-adjusting
    BuckWallace[QUOTED] likes this.
  10. Feb 16, 2019 at 12:32 PM
    #100
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    Thanks. How does that mount to the A-pillar? I can't tell from your pic if it's just sticking directly to the pillar of if it's attached to the grab handle.
  11. Feb 16, 2019 at 12:46 PM
    #101
    CaptSpaulding
    Jake
    2010 White DC 4x4
  12. Feb 16, 2019 at 12:48 PM
    #102
    BuckWallace
    Oregon
    Sierra 3500 AT4 L8T
    Cool, thanks! Don't worry about taking pics, I was just curious.
    CaptSpaulding[QUOTED] likes this.
  13. Feb 16, 2019 at 1:15 PM
    #103
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Versions of the iOttie One Touch is what I gravitate to because of the ability to mount/dismount with one hand.
    Are there any other ones that we can do that besides magnetic? (as those can’t be used with wireless charging, save for removing the case every time).
  14. Feb 19, 2019 at 10:47 AM
    #104
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    LOL. I have them on mirror in bathrooms.
  15. Feb 19, 2019 at 10:53 AM
    #105
    Major
    Major TTC #0181
    Josh
    NC
    2017 CM Attitude Black Platinum
    Stock.
    georgiey22 likes this.
  16. Feb 19, 2019 at 12:39 PM
    #106
    salmonator
    Tigard, OR
    My iottie one touch is mounted to a ram arm via ball adapter. I had to mill the ball slightly smaller to fit in the back of the iottie.
    https://www.amazon.com/gp/aw/d/B01MZXRSST?psc=1&ref=ppx_pop_mob_b_pd_title
  17. Feb 20, 2019 at 12:56 PM
    #107
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    You gave me a great idea! I let my wife have my iOttie vent and was doing without. Had an old suction cup iOttie, took it apart, and attached it to a cheap vent ball I already had from the dollar store and it worked.
    Name that tune on my HU lol
  18. Feb 20, 2019 at 1:26 PM
    #108
    hnsmrob
    hnsmrob New Member
    Tampa, FL
    Maximum Effort
    @Cuzbee
    Can you provide details on the setup? looks great! I'd like to utilize the vent. I hate how phone vent mounts completely cover the air vent.
    thanks!
  19. Feb 20, 2019 at 2:05 PM
    #109
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    I think it's the Un-Holey and whatever mount you want to add. I like the bolt solution because our vents rotate, future consideration myself.
    https://shop-hondogarage.com/collections/toyota-tacoma-mounting-systems
  20. Feb 20, 2019 at 2:15 PM
    #110
    Cuzbee
    Cuzbee New Member
    2019 Platinum
    That's correct. The website has it under Tacoma. The mount will work for both trucks. Click on the "bundle" and you will get the "perfect squeeze" mount for the phone, 2 RAM Balls, 1 RAM double socket arm, and the Un-holy mount that goes onto the air vent. @Joshua is correct. Once you install the phone mount, the air vent will not rotate. However, the new design allows for the vent to open almost all the way.
    Sunnier and JoshuaA[QUOTED] like this.
  21. Feb 20, 2019 at 2:19 PM
    #111
    Cuzbee
    Cuzbee New Member
    2019 Platinum
    The nice thing about the socket arm is that you can move/swivel the phone mount around and out of the way of the vent.
    Watt maker, CaptSpaulding and JoshuaA like this.
  22. Feb 21, 2019 at 6:52 AM
    #112
    hnsmrob
    hnsmrob New Member
    Tampa, FL
    Maximum Effort
  23. Feb 21, 2019 at 7:57 AM
    #113
    1794-BlackTundra
    1794-BlackTundra New Member
    Sergio
    2019 Black Tundra 1794 Edition CM
    Rhino Linings, Smittybilt 11500 Winch (Internal), BAKflip MX4, RotopaX, MaxTrax, ARB Simpson III tent, Old Man Emu suspension, TRD rims, Pioneer Platform with Rhino-Rack Backbone System
    Africa by Toto ;)
  24. Feb 21, 2019 at 9:21 PM
    #114
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Can you share the details, I like how inconspicuous this magnet is?
    Rocko9999 likes this.
  25. Feb 22, 2019 at 12:33 AM
    #115
    KneeeYaa
    KneeeYaa New Member
    2018 Cavalry Blue TRD Off-Road SR5
    I have this installed. I'll take a picture when I can. Only thing about it is I have to put the magnet on the outside of my Otterbox. When I tried to leave the magnet inside the case, every bump would knock it off the stand.
    https://www.amazon.com/gp/product/B079FH1W1B/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
  26. Feb 22, 2019 at 8:28 PM
    #116
    Major
    Major TTC #0181
    Josh
    NC
    Stock.
    On Amazon search Hummix. Should be the first option.
  27. Feb 22, 2019 at 8:47 PM
    #117
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    I guess I'm the only one who did.
    ...I'm just sad I missed the big day. :(
    War Machine[QUOTED] likes this.
  28. Feb 23, 2019 at 9:45 AM
    #118
    multirc
    multirc New Member
    Ron
    2018 Tundra 1794 Edition
    This is mine, I love it. I Put a small piece of foam underneith so it doesnt rest on dash creating an indentation.
    CaptSpaulding likes this.
  29. Feb 23, 2019 at 9:50 AM
    #119
    Cuzbee
    Cuzbee New Member
    2019 Platinum
    What brand is that?
  30. Feb 23, 2019 at 10:05 AM
    #120
    multirc
    multirc New Member
    Ron
    Panavise...$60.00 but well worth it.
