Checking nuts on new suspension
Discussion in 'General Tundra Discussion' started by BTBAKER, May 17, 2018.
  1. May 18, 2018 at 6:32 AM
    Our torque guys are spoiled somewhat. They cal and repair all mfrs. They frown on the "cheaper" brands that most of us have. My Harbor Freight one is actually OK for my use. Kobalt is apparently total crap with them. So many of the torque wrenches are made by same company too. The fact that you get a calibration certificate with the Tekton is a plus.
    BTBAKER[QUOTED][OP] likes this.
  2. May 18, 2018 at 6:36 AM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Yea, I would buy that. I use paint pen when I’m building substations. No marks on mine that I can find. I don’t know about the thread locker but I guess it can’t hurt.
    I disagree with the new vehicle never needing a retorque. It is wise to check and verify and Toyota specifically calls for retorque of the prop shaft quite often and they have no pen marks..
  3. May 18, 2018 at 7:52 AM
    geno0506
    geno0506 New Member
    Michael
    :cheers:
  4. May 18, 2018 at 8:15 AM
    Vizsla
    Vizsla 2 = 2.5
    I only referred to suspension, and thread locker is called for on almost every suspension fastener. The 4 nuts you found loose are supposed to have it. The only retorque called for in my owners manual are the prop shaft bolts. The tighten chassis and body bolts is just looking for loose stuff(notice no drivetrain or suspension). Definitely not saying don’t retorque stuff, but if installed properly, it is probably not needed. I tighten my LCA cams as maintenance also, but they don’t use thread locker.
  5. May 18, 2018 at 8:25 AM
    BTBAKER
    BTBAKER [OP] .
    Brad
    Castle Rock
    I believe you. I am pretty damn sure I have no locker on my threads and they were not torqued. I wish I had the ability to do all my own work because I trust no one to do the job to spec every time.
  6. May 18, 2018 at 8:27 AM
    Anything specific my man?
  7. May 18, 2018 at 10:52 AM
    geno0506
    geno0506 New Member
    Michael
    Mainly the top bolts on the 6112’s! Do I just tighten by feel! I have some loctite should I use it on them or no!
  8. May 18, 2018 at 12:18 PM
    46lbs of torque up top
    100lbs of ft torque for long bolt at bottom
    Never use nylocks
    Which loctite are you using? The red is supposed to be perm, but it's never done correctly. Technically, you're supposed to buy the stage one (primer) and then use the red loctite to make it perm. I would never make it perm and just use the temporary one such as blue loctite. However, loctite, anti-seize, etc wont matter as its acts as a lubricant which should be used first. Hope that helps =)
    geno0506[QUOTED] likes this.
  9. May 18, 2018 at 12:33 PM
    geno0506
    geno0506 New Member
    Michael
    Thanks so much, :cheers:
    I'll do it without and loctite type stuff, so the 4 bolts at top 46lbs and one shock long bolt bottom 100lbs!
    Also the rear 5160's top and bottom bolts, would you know their torque!
    Next tire rotation I may ask the dealer to re-torque the front end bolts I used when installing!
    Thanks so much for the help Brother!
    Wes likes this.
  10. May 18, 2018 at 12:52 PM
    geno0506
    geno0506 New Member
    Michael
    :cheers: :thumbsup:
    Watt maker likes this.
  11. May 18, 2018 at 1:34 PM
    5160's top you dont torque. You tighten until the washer is the same diameter as the bushing. Bottom: 47lbs
  12. May 18, 2018 at 1:41 PM
    mudslinger79
    mudslinger79 New Member
    Christopher
    Williamsburg, Va
    2006 Double Cab, Phantom Grey Pearl
    Leveled. 16x8 Pacer 164 wrapped in 295-75-16 General AT2. Flowmaster exhaust. K&N Cold air intake.
    Come to Virginia. I'll do it for food and a ride in a lifted tundra.
  13. Jun 20, 2020 at 10:52 PM
    sillydadztrksR4momz
    sillydadztrksR4momz New Member
    So how often does the suspension need to be tightened?? I know about the 500 miles but how often after that??
