Chrome Delete Covers for Tundra Bumpers - BumperShellz
Discussion in '2.5 Gen Tundras (2014-2021)' started by EC1, Oct 19, 2018.
  1. Jun 24, 2019 at 5:33 PM
    #2311
    EC1
    EC1 [OP] Ask about our BumperShellz Vendor
    Rocklin, CA
    BumperShellz
    Most of the nibbing and polishing happened today, so most of them should be on their way tomorrow.
    eric1916[QUOTED] and jdh564 like this.
  2. Jun 24, 2019 at 5:44 PM
    #2312
    EC1
    Rocklin, CA
    BumperShellz
    Sorry about these mistakes guys! Brett, I believe your replacements went out today. Glad that happened because I hadn't been able to get on the forum until just now. @Spitfire Yeah, that was a dumb oversight that was easily preventable on our part. Very sorry about that! And we will get you a matching right side out ASAP
  3. Jun 24, 2019 at 7:14 PM
    #2313
    rocksolid
    rocksolid New Member
    Kyle
    2019 Calvary Blue Tundra
    4" Lift, 20" Fuels, Katzkin Leather
    Is it too late to get in on a group buy? I want the front and rear for my '19 in paintable.
  4. Jun 24, 2019 at 9:50 PM
    #2314
    MAK
    MAK Searching for Gnarnia
    San Diego
    2014 SilverSky DC TRD Limited
    FRAC, Console safe, Amazon special-console organizer, Rhino liner, Pace Edwards retractable tonneau cover, Drivers side swing case, AJT shift knob and matching key fob!, Interior trim De-chrome with Faux carbon wrap, color matched door handles and mirror covers, Maxpider 3D Floor mats, Custom Dog bed in DC area, BFG Radial TA KO tires, 18 x9 +20 Fuel Shok wheels, Toytec Boss 3:1(shackles), White Knuckle offroad sliders w/diamond plate step, Bumper skins, Blackout badges, Firestone airbags, RCI skid,
    FOR THOSE WITH SENSORS:
    On my 2014, once you remove the retaining clip on the inside of the bumper to free up the sensor. You can not pull the sensor out of the hole as explained in the instructions. The hole in the bumper is not large enough for the connector to fit through. So as @CCLJ03 wrote, you need to fit your fingers and do some wrist contortion in order to remove the clip.
    THERE IS AN EASIER WAY!!!
    Step 1: Remove the "white" (mine is black) retaining clip from the back of the bumper.
    Step 2: Gently pull the sensor out of the hole as far as you can. It will be prevented from coming out by the female connector, don't worry. (see first pic below, This is about the amount of the sensor assembly that you can pull out).
    Step 3: Look at sensor. The outer ring of the sensor is basically a plastic flange retainer ring with 4 clips around the barrel of the sensor.
    Step 4: While gently pulling with constant pressure, use a small screw driver on each of the 4 clips. (see green arrows. Lift up the clips right where the arrows show.) The outer flange retainer ring will easily come off (see photo 2, The photo 2 is a pic of a Lexus retainer ring but the '14 Tundra is very similar. ) and the sensor assembly and wire can be pushed loosely back into the bumper. Put the outer flange ring aside.
    Step 5: Install your bumper shells
    Step 6: Reach back behind the bumper and locate the sensor and push it back out through the hole.
    Step 7: Snap the outer flange retainer ring back over the barrel of the sensor. ( there an index notch so it will only go back on one way..).
    Step 8: Place the sensor back where it belongs and reach behind the bumper and reinstall the clip.
    Hope this helps save some scratched knuckles, contorting, and cussin'.
    sbbrown333, g6t9ed, Spitfire and 4 others like this.
  5. Jun 25, 2019 at 4:15 AM
    #2315
    allstar617
    allstar617 New Member
    Sy
    Boston,Ma
    2014 sunset bronze 1794
    Thule areoblade roof racks,Full Led conversion, rackarod lockable rod holders,Led bed lights,Lock'er down safe, 42" led light bar.......6112/5160 suspension lift Coachbuilder +3 shackles, shims and bushing set. Toyo open county AT2’s 295/65/20’s on stock black painted wheels..........
    Sunset bronze in the mix?
    woah62 likes this.
  6. Jun 25, 2019 at 5:54 AM
    #2316
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    Nice!!
    EC1[OP] likes this.
  7. Jun 25, 2019 at 7:46 AM
    #2317
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Thanks.
    MAK[QUOTED] and EC1[OP] like this.
  8. Jun 25, 2019 at 8:55 AM
    #2318
    Spitfire
    Spitfire New Member
    Long Island
    2018 Cement Limited Trd off road
    mine was able to come out.. getting it back it was more difficult..
  9. Jun 25, 2019 at 1:39 PM
    #2319
    david91680
    david91680 2019 Cement SR5 4X4 Crew Cab
    David
    Hickory, NC
    2019 SR5 4X4 Cement Crew Cab
    Please let us know when the second run happens. I'd love to get a front and back set of cement colored.
    EC1[OP] likes this.
  10. Jun 25, 2019 at 5:38 PM
    #2320
    EC1
    Rocklin, CA
    BumperShellz
    Where were you when we were hiring product developers? lol
    MAK[QUOTED] likes this.
  11. Jun 25, 2019 at 5:39 PM
    #2321
    EC1
    Rocklin, CA
    BumperShellz
    We didn't get that many requests for it, unfortunately. So, for now, it's probably not a color we are going to run.
  12. Jun 25, 2019 at 5:40 PM
    #2322
    EC1
    Rocklin, CA
    BumperShellz
    This group buy is closed, but we'll be opening them back up for sale after we finish getting the last OE color matched orders out.
  13. Jun 26, 2019 at 2:44 PM
    #2323
    Quicksand20
    Quicksand20 New Member
    Ryan
    2019 Quicksand Tundra SR5 TRD Off Road
    Definitely getting a quicksand set next go round
  14. Jun 27, 2019 at 7:40 AM
    #2324
    daven
    daven New Member
    2019 Tundra Double Cab Limited
    I'm in for MGM if you do another run.
    EC1[OP] likes this.
  15. Jun 27, 2019 at 11:38 PM
    #2325
    NorAZ
    NorAZ New Member
    Brandon
    2019 Cement CM
    9259806F-E8B2-447E-81F9-7BD590055810.jpg Color matched up good. Thanks guys for helping me dechrome. I did break one parking sensor- ran out of patients because it was really hot when I installed. I just couldn’t wait till morningE9B48917-D2A6-42F7-8187-5DBC7988BD06.jpg
    Ostrich, EC1[OP] and Spitfire like this.
  16. Jun 28, 2019 at 5:16 AM
    #2326
    david91680
    David
    Hickory, NC
    Awesome, where did you get the cement molding around the grill and hood from?
    schosports likes this.
  17. Jun 28, 2019 at 7:14 AM
    #2327
    NorAZ
    NorAZ New Member
    Brandon
    2019 Cement CM
    Sparks parts. There a vendor here
  18. Jun 28, 2019 at 7:50 AM
    #2328
    david91680
    David
    Hickory, NC
    I've seen their website but can't find that part.
  19. Jun 28, 2019 at 8:13 AM
    #2329
    AZTundra
    Paul
    Phoenix, AZ
    DustinP5 likes this.
  20. Jun 28, 2019 at 8:50 AM
    #2330
    NorAZ
    NorAZ New Member
    Brandon
    2019 Cement CM
    Yeah you have to order a Pro model part. It will come with the pro insert- I didn’t use the pro insert yet but I may in the future if I get the relocation bracket for the radar.
  21. Jun 28, 2019 at 9:38 AM
    #2331
    scgrab21
    scgrab21 New Member
    Maryland
    Tundra CM | Limited | TRD | Cement
    Finally had time this morning... thanks to @EC1 for the awesome product. The color match is on point. And thanks to @CCLJ03 for the talk-on installation. The sensor going back in was definitely a finesse over force operation. Luckily I had enough patience not to break any...
    8823AA74-2213-460C-B088-880404826109.jpg 7BD23C90-370A-4C55-81CC-AAE2FD3B11FA.jpg
    Now I need to hit up sparks parts like @NorAZ to finish out the chrome delete. Thanks again everyone
  22. Jun 28, 2019 at 11:04 AM
    #2332
    david91680
    David
    Hickory, NC
    Gotcha, thx for the info.....It makes sense. I like your honeycomb grill, mines the same way. Just love that cement trim around it.
  23. Jun 28, 2019 at 11:26 AM
    #2333
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Everyone still waiting for theirs in super white?
  24. Jun 28, 2019 at 12:12 PM
    #2334
    Spitfire
    Spitfire New Member
    Long Island
    Did this last week.. pro grill going to paint shop :yes:
    scgrab21[QUOTED] likes this.
  25. Jun 28, 2019 at 12:19 PM
    #2335
    EC1
    Rocklin, CA
    BumperShellz
    Those started shipping on Wednesday. We had to send a few back for repaiting for various issues that only happen because we're dealing with white. If your tracking isn't showing any movement, then it's one of those. We'll be picking them up this afternoon. They're using a fast drying clear coat so hopefully we can get them out today, but if they're not fully cured we'll be sending the rest out Monday.
    Flyinryank[QUOTED] likes this.
  26. Jun 28, 2019 at 1:16 PM
    #2336
    Pigglet222
    Pigglet222 New Member
    All that I need is a rear set in Quicksand, so anyone needing front set only, holler at me!
    316Tundra likes this.
  27. Jun 28, 2019 at 2:46 PM
    #2337
    Lift Gate Gus
    Lift Gate Gus New Member
    Beaverton, OR
    2018 CM
    Vehicle Modifications:
    @EC1 how are the silver sky units comn along?
  28. Jun 28, 2019 at 3:17 PM
    #2338
    EC1
    Rocklin, CA
    BumperShellz
    Pretty sure yours shipped out yesterday. I saw a set on it's way to Beaverton, so either that was you, or you have a kindred spirit in OR. Most of the rest will be on their way today.
    Lift Gate Gus[QUOTED] likes this.
  29. Jun 28, 2019 at 3:48 PM
    #2339
    ricsha
    ricsha One is none, two is one.
    Rich
    Oregon Coast
    2019 Tundra Limited TRD
    My Superwhites arrived yesterday. Hope to get them on this weekend!
    EC1[OP] likes this.
  30. Jun 28, 2019 at 4:17 PM
    #2340
    Lift Gate Gus
    Beaverton, OR
    2018 CM
    That looks to be the set I ordered. Via ups website should be delivered on Monday!!!:oldglory:
    EC1[QUOTED][OP] and 4x4_Angel like this.
