Collapsed oil filter cartridge
Discussion in '2.5 Gen Tundras (2014-2021)' started by gizardlizard, Apr 14, 2023.
  1. May 2, 2023 at 3:41 AM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    That's for damn sure.
    BillyB likes this.
  2. May 2, 2023 at 5:03 AM
    TRDWarrior11
    TRDWarrior11 New Member
    2011 TRD Rock Warrior
    I dented the crap out of it when I pulled it out. It was round on both ends. Back to engineering...
  3. May 2, 2023 at 7:38 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Bypass valve should've opened well before there was enough psi to do that to the tube.
    GODZILLA, TRDWarrior11 and 2mchfun like this.
  4. May 2, 2023 at 8:09 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    So you switched to the aluminum filter housing - but did you change out the tube in the center when you did so? The one that comes installed in the housing is shorter for the Highlander's filter. The filter for the Tundra is taller, and from your pic the tube looks too short (though with it crushed it's tough to say).
  5. May 2, 2023 at 9:36 AM
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    There is no psi that would do that to the tube. It's full of holes, so inside and outside pressure would be the same.
  6. May 2, 2023 at 10:08 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    If what you say is true then the ubiquitous bypass valve is rendered moot.
    TRDWarrior11 and AZBoatHauler like this.
  7. May 2, 2023 at 10:37 AM
    rruff
    rruff New Member
    The bypass valve is for filter restriction. The center tube doesn't restrict anything.
    TTund16 likes this.
  8. May 2, 2023 at 5:22 PM
    TRDWarrior11
    If the filter is compromised, the tube could be rendered as progressive damage. I agree with the PLV comments. It is the longer of the two tubes provided.
    My intent is to pick up a new OEM housing and filters. No more Mobil 1. Going to check into that PLV too.
  9. May 2, 2023 at 5:24 PM
    joesTundra
    joesTundra New Member
    Joe
    2018, Toyota Tundra Limited, TRD 4x4 off road
    Has anyone gone to get oil changed and they didn't change the filter?
  10. May 3, 2023 at 7:11 AM
    Jack_A_Lope
    Jack_A_Lope New Member
    Aaron
    Santa Barbara County, CA.
    2019 Tundra 4X4 SR5 TRD Sport
    Pro Comp Lift, Tires & Wheels, Steel front bumper with LED lighting, Cross bed tool box, bed rails, custom aftermarket sound system
    All I know is that isn't caused by purple oil or any other color oil. There is a serious problem and I would be figuring out what it is before I would go jamming on a new filter thinking it won't happen again. That would take a tremendous amount of pressure to crush the center tube like that so you need to figure out what is causing it before you end up destroying your motor.
    coldcanuk and AZBoatHauler like this.
  11. May 3, 2023 at 7:16 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I once serviced wife's bike she used for commute and forgot to reinstall both brakes cables. She figured it out on the go and did an emergency brake against a boulder or something, with flipping over the bar.
  12. May 3, 2023 at 1:37 PM
    HOKIES
    HOKIES New Member
    Western Virginia
    2021 B Red Crew Max
    Been there
    Done that
    thought”that’s odd the oil is red”
    Then %#^*?!!!!
  13. May 3, 2023 at 5:11 PM
    mgrs
    mgrs New Member
    '20 OR
    Since it was not answered, going to go ahead and guess "no" to toyota OE housing and center pipe.
    BillyB likes this.
  14. May 3, 2023 at 9:41 PM
    Luvrv8
    Luvrv8 New Member
    Camarillo, California
    Kind of. On my ‘15 I had a rear main seal leaking. Dealer also resealed my oil pan all under warranty. I said I would pay for the filter and a few dollars labor since they were replacing the oil at no charge. Well, tech didn’t replace the oil filter.
  15. May 3, 2023 at 10:39 PM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    I agree, it's got to be that purple oil! I mean seriously, what else could it be?
    Sarcasm by the way
    TRDFerguson and GODZILLA like this.
  16. May 4, 2023 at 12:47 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Dorman aluminium housing? They’re the only ones I’ve seen do this
    the oem centre tubes are thicker metal and rolled edges.
  17. May 4, 2023 at 5:01 AM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    With modern oils I'd be more inclined to change the filter and keep running the oil, vs change the oil and keep the filter. Not that I suggest either.
    BillyB likes this.
