Comparison between GMC 1500 Sierra Denali and my 1794
Discussion in '3rd Gen Tundras (2022+)' started by Lou1947, Aug 19, 2024.
  1. Dec 28, 2024 at 6:18 PM
    Breathing Borla
    Northern Illinois
    enjoy your new rig, congrats
    and ya I mean at some point gm has to fix the lifter bs, it’s been forever so maybe that’s it now
    interesting you found the gm trans better than the aisin, not too many ever say that
  2. Dec 29, 2024 at 5:16 AM
    TundraMoe
    TundraMoe New Member
    2023 GMC Sierra Denali 3.0 Duramax
    After having driven both the ‘22 Tundra and the ‘23 Sierra for thousands of miles I’d say the transmissions are very comparable. I do wonder if a turbocharged engine makes a transmission smoother. It doesn’t always have to hunt for a gear with a little whoosh utilized.
  3. Dec 29, 2024 at 5:25 AM
    BoulderGT3
    BoulderGT3 New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    I'm looking at new trucks and drove a gmc Denali 3.0 duramax last week. I like the truck part better than my tundra but try as I might, I just can't connect on the baby duramax. Fine around town. Gutless on up hill on ramps and passing at 70MPH. 6.2 is ok but the 24G tank with it is still a deal killer for me. Transmission seemed fine.
  4. Dec 29, 2024 at 5:32 AM
    TundraMoe
    The diesel pull is different than the twin turbo. It’s just a smooth pull, diesel style. I miss the tundra’s zip but my 50+ year old brain is good with it.
    The 24 gallon tank is just fine with the 3.0. I’ve seen DTE ranges over 700 miles.
    I’d say the trucks pulled my 7000lb camper equally well.
  5. Dec 29, 2024 at 5:32 AM
    Polo08816
    Polo08816 New Member
    2014 BMW 335i
    The 24 gallon gas tank was a deal breaker for us until this aftermarket solution was on its way:
    https://longrangeamerica.com/produc...cabcrew-cab-short-bed---50-gallon-replacement
  6. Dec 29, 2024 at 5:33 AM
    BoulderGT3
    Glen
  7. Dec 29, 2024 at 5:37 AM
    Polo08816
    2014 BMW 335i
    I think the gas gauge problem will be there with almost all makes and aftermarket solutions. The problem being it’ll say Full for a long time until it starts moving. It’ll move down to Empty at a similar rate as the factory gas tank. Then it’ll have a much larger “reserve capacity” at empty than the factory solution.
  8. Dec 29, 2024 at 5:39 AM
    BoulderGT3
    Glen
    To me, it's horseshit to have a $75K truck with a Rube Goldberg gas gauge and non functional DTE. Doesn't matter in the 3.0 as it has plenty of range
  9. Dec 29, 2024 at 5:42 AM
    BoulderGT3
    Glen
    Meh, I've had many diesels and drive a 6.6 often. I've never complained about passing power. There's just not much there, there with the 3.0 at highway speeds. Could I live with it? Maybe. Would I sacrifice some fuel economy for more go? Absolutely.
  10. Dec 29, 2024 at 5:53 AM
    Polo08816
    2014 BMW 335i
    The 3.0 Duramax does have its own set of problems and is significantly more complicated. Just watch DemonWork's video on that coolant control valve on how complicated the cooling system is.
    What I've observed on the forums is that when these design issues and flaws are brought up, most of those that do have the Baby Duramax say they're only keeping the vehicle for 3-5 years.
    At least with the GM lifter issue, you can remove the head and camshaft without needing to remove the engine from the vehicle. Everything else in is easily accessible in the engine bay of a naturally aspirated V8. This would be similar to the F150 Lariat with the 5.0 Coyote. All of our current vehicles are turbocharged and we DIY almost all of our repairs and maintenance. I'm done dealing with that turbocharged nonsense.
    Same. We test drove the LZ0 and didn't have an issue with the passing power.
  11. Dec 29, 2024 at 5:58 AM
    msubullyfan
    msubullyfan New Member
    Robert
    2024 Tundra i-FORCE MAX 1794 Edition
    I traded my 2023 Sierra SLT for a 2024 1794 Tundra and couldn’t be happier. I had driven GMC trucks for 18 years and was brand loyal, but I HATED my 2023. Electronics issues, infotainment system always causing problems, cracked transfer case housing, no real way to add bigger tires without a full 5”+ of lift, having to put premium fuel in that 6.2L and only getting 16-17 mpg…
    GMC just didn’t get it right with this latest refresh.
    Tundrastruck91 and 22whatwedo like this.
  12. Dec 29, 2024 at 6:03 AM
    Polo08816
    2014 BMW 335i
    I think with modern transmissions, it comes down to programming/shift algorithm. Ford and GM have a near identical 10 speed transmission in their light duty vehicles. There's very minor hardware variations, but those can't explain why Ford can't program the 10R80 (with the 5.0L) to be as smooth as the GM 10L80.
    The best automatic transmission on the market right now is still the ZF 8HPXX series. When manufacturers get the programming of that just right, it's a downright beast of a transmission. I believe BMW's actual race cars use the exact same unit as their street vehicles - no modification required.
  13. Dec 29, 2024 at 6:22 AM
    Polo08816
    2014 BMW 335i
    One thing about the Tundra that I (and especially my SO) couldn't get around is the Remote Start behavior of the Tundra. The pickup would have needed to stay outside since we have already have cars in our 3 car garage. The truck needing to shut off the engine when you opened the door was just a non-starter. The Tundra's refresh is too far away (with Toyota Safety Sense 4.0) that we don't think we would have been able to wait that long.
    What is the biggest tire you could have fit on the SLT without needing any level/lift? Would you have been able to fit a 275/65/20?
  14. Dec 29, 2024 at 10:57 AM
    Breathing Borla
    Northern Illinois
    i had one of the first ram zf 8 which a that time was imported from the factory in Germany
    it was outstanding and so was the programming
    the ford and gm 10s when I tested were clunky compared to the aisin 10 tundra
  15. Dec 29, 2024 at 1:03 PM
    Polo08816
    2014 BMW 335i
    I have no problem with the Aisin transmission. I've test driven it in both the 2024 Tundra as well as the GX550. The GM's 10L80 in the 2024 Sierra SLT with the LZ0 and L87 were very smooth and the shift strategy seemed flawless.
    When we test drove at least two 2024 F150 Lariats with the 5.0, the transmission shift strategy needed refinement.
    I think there's far more of a difference in drivability between the Ford and GM transmission programming - despite being theoretically the same hardware design - than there was between the GM and Aisin.
    GM's 10L80 runs ice cold compared to Ford's 10R80 and the Aisin. Probably because GM implements both a liquid to liquid and air to liquid cooler for their transmission relative to Ford. Ford only implements both a liquid to liquid and air to liquid cooler in their Raptor and Police Responder versions.
  16. Dec 29, 2024 at 5:34 PM
    DimSum07
    DimSum07 New Member
    Steven
    Annandale VA
    2024 Silverado 1500 LZ0
    I've seen my 10 speed in the LZ0 eventually get up to 200 degrees when driving. PPE has a bypass valve, larger air to liquid cooler, and larger trans oil pan, but I've been holding off b/c I don't understand the ramifications of running the trans below expected operating temperatures.
    Its quite obvious GM wants this LZ0 to run warm (210* F oil temperatures).
    I only have 5k on this truck, so its way to early to say its any good. I do know that I think the GM truck is a well executed truck....a bit better than the Toyota...assuming nothing breaks. I did buy GM's extended warranty.
  17. Dec 29, 2024 at 6:39 PM
    msubullyfan
    Robert
    You'd likely need a level to get a 275/65. I kept the 275/60 size when I put Cooper Rugged Treks on it and even the AT tread made them VERY tight. That almost-vertical rear wall on the front fender well is HORRIBLE when it comes to upsizing tires.
    Polo08816[QUOTED] likes this.
  18. Dec 29, 2024 at 8:55 PM
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    My wife has a 2024 Yukon with the 6.2 engine-10 speed trans and I don’t think I’ve seen the trans temp get to 160 yet, even driving for 6 hours straight. I don’t know GMs much so not sure how yours differs.
  19. Dec 30, 2024 at 5:23 AM
    #49
    TundraMoe
    I have not seen high transmission temps even when pulling. Now I’m curious and will monitor that more.
  20. Dec 30, 2024 at 8:42 AM
    #50
    Zedsled
    Zedsled New Member
    Been following this thread for a bit...Currently a VERY happy owner of a '20 Ram Limited EcoDiesel. Truck has every option/ i put 22x10 Fuels on it to make it mine....Truck has been flawless for the 5 years I have driven it. Government incents small business to flip vehicles every 5 years or so, so I have been looking. So far, nothing, I mean nothing, compares to the quality of materials, ride or drive of my Ram, including the new Rams (no more Eco), RHO sounds like a sick cow. The five year old side of me is pushing for a Raptor R, but I have been down the loud/performance road too many times and it always ends the same....So it is down to an Ultimate Sierra diesel or a 1794 Iforce Max. While the features of the Toyota are borderline impressive, there are some really s#itty interior pieces (center console doors, glovebox door) that are just begging to be annoying.
    GMC side...22 gallon tank?!?! Running a 33 in my Ram now...Interior seems ok, but the seats seem small and the sunroof size just makes no sense in a '25 vehicle. Not sure what to consider next...?!?!?
  21. Dec 30, 2024 at 9:58 AM
    #51
    TundraMoe
    Just got back from a 550 mile trip for a family Christmas. Got 31.0 MPG cruising between 65-75 with 5 adults and a bed full of clothes, presents, food, etc. Still have 150 miles showing forDTE. And this is WI weather with warm ups and winter fuel. The 24 gallon tank is just fine for the diesel.
  22. Dec 30, 2024 at 10:07 AM
    #52
    Polo08816
    2014 BMW 335i
    Isn't the GM diesel gas tank capacity the same as the gas tank capacity - 24 gallons?
  23. Dec 30, 2024 at 10:10 AM
    #53
    TundraMoe
    Sorry, mistyped that. Yes, 24.
  24. Dec 30, 2024 at 10:24 AM
    #54
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    Same. Last GM car I owned was a Saturn Sky. The passenger presence seat sensor (PPS) for the airbag went bad (poor design). The Pontiac Solstice and Saturn Sky community had to petition the NHTSA to do an investigation after GM said they weren't going to. We gathered thousands of instances where owners' PPSs failed. GM, under pressure from the NHTSA, finally did an investigation. Guess what? They issued a recall for the same PPS in the Cadillac, but said since Pontiac and Saturn were discontinued brands, they weren't going to issue a recall for them. Total BS...
    Tundrastruck91 likes this.
  25. Dec 30, 2024 at 6:30 PM
    #55
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    First post on Tundras.com ..you KNOW what you want :)
    RadixRyder and Zedsled[QUOTED] like this.
  26. Jan 1, 2025 at 4:47 PM
    #56
    DimSum07
    DimSum07 New Member
    Steven
    Annandale VA
    These were from today. 51 *F out and windy. I was moving pretty fast for the east coast, but on a road trip, its not uncommon to see trans temps in the 190-200 *F range. I never see those temps in my commute, but that's just due to the fact that its only 20ish miles long.
  27. Jan 21, 2025 at 12:48 PM
    #57
    Johnb0311
    Johnb0311 New Member
    Hi Country
  28. Jan 21, 2025 at 12:54 PM
    #58
    Johnb0311
    Hi Country
    I've been shopping around for a new truck since my Hi Country Silverado blew a couple lifters. GM was no help yet they wanted their mechanics to do the job. I paid a great mechanic shop to do the job using all gm parts. I wasn't looking for money because I was out of warranty. 61000 miles. I asked for their power components consumer letter to get an extended warranty. No way the answer. I did go look at the Tundras. I'm partial to the 1794 editions. After four new GM products, I'm ready to ditch GM.
    BoulderGT3 likes this.
  29. Jan 21, 2025 at 1:07 PM
    #59
    Breathing Borla
    Northern Illinois
    they would not good will repair that at only 1K miles over the Powertrain Warranty?
    no way, really?
  30. Jan 21, 2025 at 1:14 PM
    #60
    BoulderGT3
    Glen
    So much for doing the right thing.
