CompuStar remote start/control
Discussion in '2.5 Gen Tundras (2014-2021)' started by Shadowfax1, May 12, 2023.
  1. Nov 30, 2024 at 11:51 AM
    Kona_boy
    Kona_boy New Member
    Jeff
    Kent, WA
    2023 white tundra 1794 TRD
    Can you elaborate on reliability? I had it on my wrx in the past and loved it. What alternative would you recommend?
  2. Nov 30, 2024 at 1:38 PM
    Shadowfax1
    Shadowfax1 [OP] New Member
    San Francisco Bay Area
    2018 Toyota Tundra 1794 Edition w/ TRD Off-Road Package
    I don’t have an alternative. I didn’t like the other options on the market and this is better than not having it at all. That said, my remote control’s battery lasts days on a charge. Either it’s faulty or it sat on the dealer’s shelf for a very very long time. The proximity unlock has never worked. And on a handful of occasions, the system has triggered unexplainable vehicle alarms and starts or stops.
  3. Nov 30, 2024 at 1:46 PM
    Ace96
    Ace96 New Member
    Western KY
    2021 Voodoo Blue TRD Sport
    Hate to say it but sounds like install issue. You may want to try a different installer.
  4. Nov 30, 2024 at 3:23 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Definitely install issue. I have the same system compustar dc3 brain with dronemobile. I even have the 2way remote but decided not to connect it since i have dronemobile.
    Unlock proximity works just like normal. Nothing out of the ordinary. Yes, you need to flash it correctly for your truck using a pc. Change the settings accordingly to your needs.
    Yes, i did the install myself. I had this exact system on our previous 2017 sequoia, then took it off and put it in this truck. Works great for me.
    Shadowfax1[OP] likes this.
  5. Nov 30, 2024 at 3:27 PM
    BrandonL812
    Brandon
    The lcd remotes are batteries hogger for sure. They never last long at all.
  6. Nov 30, 2024 at 4:42 PM
    Shadowfax1
    The installer has looked at it twice and insists it's wired correctly. I plan to try one other installer, but I have my doubts it's an installer problem. This was also a CompuStar Pro-certified installer.
    Ace96[QUOTED] likes this.
  7. Dec 1, 2024 at 4:59 AM
    BrandonL812
    Brandon
  8. Dec 1, 2024 at 8:44 AM
    Ace96
    Ace96 New Member
    Western KY
    I definitely take it to another installer. I’ve had mine installed with DroneMobile and had no issues with it other than when Compustar had errors with firmware that they fixed. Proximity locks work as they should. Had mine for almost 2 years.
    BrandonL812 likes this.
