Cooper AT3 XLT
Discussion in 'Wheels & Tires' started by CaptTyler, Jul 25, 2018.
  1. Aug 2, 2021 at 5:07 PM
    #751
    jr1016
    jr1016 New Member
    Ric
    Sacramento, CA
    2020 CM TRD Sport
    I'm sure they are.
    nhw544[QUOTED] likes this.
  2. Aug 2, 2021 at 8:03 PM
    #752
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    That's weird. Maybe because your truck is heavier. I am at about 56,000 miles on my Coopers and there is still a lot of miles left. And I actually work them hard.
  3. Aug 2, 2021 at 8:18 PM
    #753
    Thats probably it. My truck is 2k lbs heavier and most likely tow a bit more miles with mine (I don’t daily drive mine, Tow or snow only).
  4. Aug 4, 2021 at 5:19 PM
    #754
    JackWagon
    JackWagon Dr. Wookiee
    16 Tundra DC TRD Pro MGM
    Anyone running these in 305/65R18? I'm considering dropping down in size from 295/70R18 STT Pro's. I do alot of towing (7500 lbs TT) andwant some low end grunt back but want to keep a some what aggressive look.
  5. Aug 5, 2021 at 5:24 AM
    #755
    Boerseun
    Ferdie
    Sarasota Florida
    The 305/65 is only 2% smaller than the 295/70 but 3.4% wider. I am not sure if there will be significant low end grunt increase, maybe a little, but the wider tire will have more resistance canceling that out, and increase fuel consumption. That being said, I think the wider tire will actually look better.
    JackWagon[QUOTED] likes this.
  6. Aug 5, 2021 at 5:37 AM
    #756
    Pillslinger
    Pillslinger New Member
    Rollin
    SWMO
    2018 Cement TRD CrewMax
    Bed light kit Jerry can mount Badge overlays (removed 2021) Pin stripe / TRD decal / pillar vinyl removal Raised tailgate lettering Center console badge/tray/divider Interior/exterior LED upgrade VLED footwells TVD Vinyl TRD Offroad wheels Icon 17x8 rebound titanium Bubbas Garage grab handles WeatherTech floor mats (Eagle Klaw added) Rough country front shackles (removed 2021) DD SS3 yellow fogs MESO map light replacement Softopper MESO Chrome delete
    Not exactly, but I'm running a 305/70 17 so overall the same dimensions or very very close to what you are talking about. 20210622_071119.jpg
  7. Aug 5, 2021 at 6:15 AM
    #757
    JackWagon
    Thanks for the breakdown Boerseun.
    Pillslinger... Do you tow with them? How do the tires perform for you? What are your thoughts because I'm on the fence.
  8. Aug 5, 2021 at 6:35 AM
    #758
    Pillslinger
    Rollin
    SWMO
    I have towed with them but literally it was a 14' utility trailer, maybe 100lbs on the tongue empty and a load of under 1000lbs for 20 miles. Keeping that in mind I love these tires. E load is stiff but I keep them at 40psi and I'm happy. Only complaint i have is the flat spotting issue discussed in this thread. Most mornings I have a steering wheel wobble for the first mile or two then all good. As others have said these are really quiet for ATs. I have to roll down my window or turn off the radio and climate control on a quiet stretch of road to hear them. Disclaimer: I've only got 2500 miles on these. So take that for what it's worth.
    JackWagon[QUOTED] and jmdaniel like this.
  9. Aug 5, 2021 at 7:14 AM
    #759
    jmdaniel
    jmdaniel Spending too much time here...
    Leander, TX
    2018 Tundra CrewMax SR5, 1977 FJ40
    DSI Conversion, including 6" ProComp lift, Fuel Assault Rims, ProComp tires, SunTek protective film, BAK Revolver X2 tonneau cover, Bedrug bedmat, OEM Audio+ Reference 500Q
    That's my main issue as well. I don't drive every day, and when I do, the steering wheel wobble between 55-60 is a PITA, and goes on for awhile.
  10. Aug 5, 2021 at 7:31 AM
    #760
    JackWagon
    My truck sits alot because my daily commute is 80 miles and I've got a little Matrix for that duty. The flat spotting was a concern of mine based off what I read in the thread. Seems like the general consensus is they are great tires other than the flat spotting. Plus, these are basically the only E rated tire in 305/65 that doesn't weight a ton. My 295's are 70lbs each and I'm trying to save some rolling weight.
  11. Aug 5, 2021 at 7:46 AM
    #761
    PermaFrostTRD
    Northern NY
    Toyo ATIII's are comparably low weight for their size (similar to Cooper AT3 XLT). Not all Cooper sizes are 3 peak rated, where the Toyo's are (if you need that, or are interested in that).
    JackWagon[QUOTED] and Badknees like this.
  12. Aug 5, 2021 at 8:18 AM
    #762
    Badknees
    Badknees New Member
    South Carolina
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    Do you know if the Toyo's ATIIIs have any flat-spotting issues? I assume it is a common problem on most AT tires as I had the same thing on my KO2s ('07 4runner).
    PermaFrostTRD[QUOTED] likes this.
  13. Aug 5, 2021 at 8:36 AM
    #763
    PermaFrostTRD
    Northern NY
    My wife has them on her 4R. It's a daily for her, but I haven't noticed any issues when we took it down to vacation and it would sit for a couple of days at a time. I will likely put them on my Tundra this fall in a 295/70 18.
    As a side, while we were on Vacation, my Tundra sat for 10 days roughly. I didn't notice a wobble or anything when driving it (maxed at 55mph on my 3mi commute to work when we returned). 275/70 18 KO2s with 50K on them. So, maybe I'm just not as tuned-in to flat spots, if there were any. My Grandad gave me his 79 Coupe DeVille (last of the big blocks). Nothing on the road floats like that. So I just assume everything else has a bump or shake in it.
    Tileguy and Badknees[QUOTED] like this.
  14. Aug 5, 2021 at 8:43 AM
    #764
    Badknees
    Badknees New Member
    South Carolina
    Thanks for the feedback. I have the Cooper AT3 XLT 295/70 R18s on my Tundra and I'm not looking at changing anytime soon. However, I am thinking about the Toyo ATIIIs as my next set of tires. I'm not crazy about Goodyear buying Cooper so I will be a little hesitant to buy the Coopers next go round.
  15. Aug 5, 2021 at 9:48 AM
    #765
    PermaFrostTRD
    Northern NY
    You're welcome. and with respect to the BOLD:
    Are they 3 peak snowflake rated in that size? I cant seem to find a definitive answer on that.
    Badknees[QUOTED] likes this.
  16. Aug 5, 2021 at 9:50 AM
    #766
    Pillslinger
    Rollin
    SWMO
    This 100%. I'm glad I got the coopers when I did. I've already accepted that they won't be an option next time or quality will suffer significantly. It's the reason I'm still tuned into this thread, watching for feedback. Based on reviews I was torn between the Toyos and the Coopers. I assume I will be going with the Toyos next go around too.
  17. Aug 5, 2021 at 10:00 AM
    #767
    Badknees
    Badknees New Member
    South Carolina
    I remember when I researched these that they are not 3 Peak rated but the Toyos ATIIIs are...that really wasn't a decision factor for my use though.
  18. Aug 5, 2021 at 1:54 PM
    #768
    Boerseun
    Ferdie
    Sarasota Florida
    I have 56,000 miles on my Coopers and have never experienced flat-spotting.
  19. Aug 5, 2021 at 2:13 PM
    #769
    nhw544
    nhw544 Food fight!
    RVA
    2019 Black Tundra 4x4 Sport
    For you guys that are concerned about them being bought by Goodyear, any idea when we might start seeing Goodyear Cooper’s? I’m getting tires this month and these have been at the top of my list. Now y’all are making me second guess myself!
  20. Aug 5, 2021 at 4:03 PM
    #770
    Badknees
    Badknees New Member
    South Carolina
    I run 18” wheels. Aren’t yours 20”? Maybe more sidewall rubber makes a difference…don’t know.
  21. Aug 5, 2021 at 4:18 PM
    #771
    Boerseun
    Ferdie
    Sarasota Florida
    Yes, I have 20" with 65 sidewall. I run about 40 psi.
  22. Aug 5, 2021 at 6:28 PM
    #772
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    My truck sits quite a bit since I fly for work, never had the slightest vibration from them - would get flat spots quite often in the stock Michelins from those times sitting. I just have the regular ATIII's, not the LT one's though.
    Badknees[QUOTED] and Boerseun like this.
  23. Aug 5, 2021 at 7:43 PM
    #773
    Muleycrazy13
    Muleycrazy13 New Member
    Buckeye, AZ
    2024 Chevy Silverado 2500HD Duramax
    It’s getting close to time for new tires for myself. I currently have Toyo AT2 and am right at 50k miles right now. They have been a great tire. I was considering the Wildpeaks until I looked up the weight. Like you mentioned they are a heavy tire. I may end up going with the new Toyo AT3 but only draw back is they are spendy!
  24. Aug 5, 2021 at 7:51 PM
    #774
    No kidding right? Order them early due to delays (from what I’ve heard).
    Muleycrazy13[QUOTED] likes this.
  25. Aug 6, 2021 at 4:45 AM
    #775
    jmdaniel
    Leander, TX
    I'm running 20s.
  26. Aug 7, 2021 at 3:44 AM
    #776
    Boerseun
    Ferdie
    Sarasota Florida
    I think they will be okay for now. Goodyear bought Cooper but will run the Cooper brand as a subsidiary, rather than just absorbing them into the Goodyear line. I don't think they will mess with rubber compound, tread pattern etc. that will make the Coopers inferior.
  27. Aug 31, 2021 at 4:50 PM
    #777
    nhw544
    nhw544 Food fight!
    RVA
    Alright guys, I need some help/opinions. I’m about to pull the trigger on some tires and these have been at the top of my list. But here’s my hesitation…on all the trucks I’ve owned, I’ve never gone above stock tire size or an E rated tire. Right now it looks like the closest to stock size I can find these in is 275/70/18, up from stock 275/65/18. I’m on completely stock 17 TRD OR. The service manager at my buddy’s shop is trying to talk me out of these because he says the E rated tire will be terrible since I don’t tow. Can’t I just air down some to soften the ride?
    My other concern is that these are 17 pounds heavier than the stock Michelin’s. Is that going to be hugely noticeable?
    Thanks for any input. I’m not a tire guru at all, so just wanna make the right decision. I’ve always had good luck with Coopers and I’ve read great reviews about these. My backup plan is to just go stock size in the Wildpeaks.
  28. Aug 31, 2021 at 5:54 PM
    #778
    Badknees
    Badknees New Member
    South Carolina
    I guess my obvious question is why do you want to go with larger tires? Appearance? How do you use your truck…mostly street?…off road?…snow?
    For sure comparing E rated tires to stock they will be heavier, reduce gas mileage, ride worse, cost more, and I doubt you can reasonably air down enough to match a stock ride without dramatically affecting the tire’s performance, safety, and life.
    If you have been happy with stock appearance, ride, and performance then that seems the most logical direction…then again, what the heck do I know as I can’t follow my own advice? I went with Cooper Discoverer XLT AT3, 295/70 R18s. To each his own and best of luck.
    nhw544 likes this.
  29. Aug 31, 2021 at 6:02 PM
    #779
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Love mine but the flat spot thing drove me nuts played with the air pressure and went down to 32 psi no more wobbling steering wheel in the mornings
    jmdaniel and nhw544 like this.
  30. Aug 31, 2021 at 6:33 PM
    #780
    nhw544
    nhw544 Food fight!
    RVA
    Appreciate the reply. I don’t necessarily want to go larger or E rated, but these don’t come in stock size. My driving is 99% pavement. I do very little off road, but that may change soon as I want to start taking my kids camping.
    I’d be lying if I didn’t say part of the reason for wanting these tires is the look. I’m getting my stock OR wheels powder coated black and I think these tires would look awesome with those.
    The stock Michelins are ok. They’re worn out and I need new tires anyway, but the one snowstorm we had last year they weren’t that good. And I did have some traction problems on the gravel road we have to take to get to the cabin we rent frequently.
    Like I said, I’ve always liked Coopers and since I need tires anyway, figured I’d give these a look. Plus the reviews I’ve read have been very positive.
