Correct Spicer Carrier Bearing for 1st gen tundra EXACT TOYOTA OEM
Discussion in '1st Gen Tundras (2000-2006)' started by 00TundraZ, Apr 30, 2019.
  1. Aug 17, 2020 at 4:06 PM
    #91
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Umm, that neither will fit my truck...
    Post 88 doesn't match either part number
  2. Aug 17, 2020 at 4:11 PM
    #92
    Professional Hand Model
    Hand Protectors
    How about post 64?
  3. Aug 18, 2020 at 8:59 AM
    #93
    rock climber
    Well, that's what drive train america says, but spicer says something different. Hence my confusion.
  4. Aug 19, 2020 at 3:34 PM
    #94
    az chip
    az chip New Member
    Craig
    Arizona
    2003 Tundra TRD
    Service from Drivetrain America is great. They got hit by a bad storm. The whole town is down no power. They sent mine out Thursday 2-day FedEx. I got it Saturday before 2pm. Put it in Saturday. They did not have to do that.
    FrenchToasty likes this.
  5. Aug 19, 2020 at 4:12 PM
    #95
    audibahn
    audibahn New Member
    Denver, CO
    2005 Tundra Limited Double Cab
    Ha, I went through the same number game so let me add to the confusion! I have an 05 4x4 Limited. I contacted Drivetrain America and purchased 5002334 per their recommendation but I don't think it's the correct one as it doesn't have the bearing seal. It's on the truck now and works, has identical dimensions to the 5002007 per the Spicer spec sheets, but does not have the bearing seal.
    Per the VIN lookup, I should be using 37230-34030 (5016911 Spicer) even though my truck came with 37235-35030 (5002007 Spicer).
    The 5016911 and 5002007 have similar dimensions, except that the Center to Mount distance on the 5016911 is 1.136". The Center to Mount distance on the 5002334 and 5002007 is 0.244" so they hang almost an inch higher.
    Per VIN and Dana, I should have bought the 5016911 bearing (https://www.danaaftermarket.com/spi...tr=5016911&cp=0&catalog=PIMS_NA&partType=PART) but I couldn't find a reputable place that sells it.
  6. Aug 20, 2020 at 8:27 AM
    #96
    rock climber
    Thank you, that helps a lot!
  7. Aug 30, 2020 at 7:25 AM
    #97
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Update...so installing this was fairly easy. There are several useful YouTube videos. And, once complete it did seem to improve the vibration somewhat, but did not eliminate it. I hate vibration problems!
    So...I have a vibration under my seat that starts at ~ 45 MPH and is very evident at 50 mph. I also have "shuddering" when braking sometimes, which I've come to learn is a common drive live problem on our trucks. In hindsight, I realize I've had the shuddering problem since day 1. I first though it was bad rear shocks (replaced), and rear brakes (on the list to do once I sort this problem out).
    The steering wheel is tight, with no vibration at all. This pretty much eliminates front wheel balance, etc. Maintaining speed at 50 MPH I can shift in and out of OD, and the vibration remains constant. I even tried neutral with the same result. I believe this eliminates the transmission, torque converter, etc. (Tranny and engine mounts look good, seem tight...nothing moves when I rev the engine or shift from D to R with the brakes on). So...
    I ordered new Spicer U-joints for the front (tranny) and rear (axle). After I removed the first u-joint I discovered that I had the wrong parts! (not sure if it's a RockAuto error or my own...I'll sort that out later). I chose to run to the nearest AutoZone to get some inferior parts rather than leave my truck in pieces for a week while replacements arrived. Neither joint was noticeably loose while on the truck or on the bench, but when disassembled the rear joint was badly worn on one journal, so I thought I may have found the culprit.
    I put it all back together and went for a test ride. While improved, the vibration is still present. The next suspect is the double Cardan joint. The Internet tells me that "Cardan" is French for "Don't Touch", and I'm inclined to agree. I'm fortunate to have a Drive Shaft Shop nearby, so the next exercise will be to have the Cardan joints replaced and the shaft checked for balance, effectively yielding a completely re-manufactured shaft assy.
    Did I mention that I hate vibration problems? Other suspects include the transfer case (bearing seems tight, no leakage) and the axle pinion (same deal...tight, no leakage). I'm receptive to any suggestions all y'all might have.
  8. Aug 30, 2020 at 4:03 PM
    #98
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    2006 Tundra 4X4 Limited Dbl Cab
    I may have missed it but are you running KO2's by chance?
    NomadicFrog likes this.
  9. Aug 31, 2020 at 2:27 AM
    #99
    w666
    Maryland
    Nope, just ordinary street tires...Goodyear in the front and Yokohama in the rear. This does not feel tire related at all, but I will rotate them and check the balance just to check the box. Stranger things have happened. A belt separation can sometimes cause similar symptoms.
  10. Sep 16, 2020 at 6:47 PM
    #100
    03Fundra
    03Fundra New Member
    2003 Toyota Tundra SR5
    Appreciate this post as well! I have an 03 Tundra, V8 4wd. It seems based on your post and the Dana site you linked that 5016911 is the carrier bearing I need. Where did you lookup your VIN to get 5016911 from?
    I have noticed 00-02 and 03-06 seem to have some slight suspension, steering, and apparently now driveline differences, so this would make sense.
  11. Sep 16, 2020 at 8:36 PM
    #101
    Shuddering in the seat is likely rear end, like driveline, wheel balance or rear brake issues.
  12. Nov 22, 2020 at 9:55 AM
    #102
    912
    912 @best_gen_tundra
    Fulltime RV traveler
    2005 DC 4x4
    Replaced my carrier bearing this morning on my 05 DC 4x4 with the Spicer 5002007 thanks to this thread. :thumbsup:
    2029A60D-73EC-42E9-9049-70A529CAD3E3.jpg 314D7179-154B-481E-A4A8-C4B0F3302BE1.jpg
  13. Jan 28, 2021 at 5:18 PM
    #103
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
    Bring this thread back. Looking for a carrier bearing for my 2WD Double Cab. Toyota 37230-34030 says this is for a 4WD, does it matter or do I need to find a 2WD carrier?
    mcharfauros likes this.
  14. Jan 28, 2021 at 5:50 PM
    #104
    2006Tundra
    Lou
    Long Beach, CA
    After some digging, I found this cool website. You enter your VIN and it'll bring up your vehicles info with every single part that you need. My truck is asking for Toyota Part #:37230-35120. Not sure what the difference is between the 37230-34030 and mine.
    https://www.toyodiy.com/parts/
  15. Jan 28, 2021 at 5:57 PM
    #105
    Have you crawled underneath the truck and read the number on your existing bearing?
  16. Jan 28, 2021 at 6:01 PM
    #106
    2006Tundra
    Lou
    Long Beach, CA
    No, but I cross reference ToyotaPartsDeal.com and I called my local Toyota dealer to confirm.
  17. Jan 28, 2021 at 6:37 PM
    #107
    MS22
    MS22 New Member
    02 Tundra 4x4
    2006Tundra[QUOTED] likes this.
  18. Apr 22, 2021 at 2:47 PM
    #108
    01tunder
    01tunder New Member
    Ca
    2010 4x4 trd tundra
    Hey I'm from west Sacramento also. I got the precision but it doesn't spin
  19. Aug 23, 2021 at 10:39 AM
    #109
    mbreed2
    mbreed2 Is not right
    Allentown PA
    2001 Tundra 4x4
    Was under the truck greasing the drive shaft. Had to Google how much play this thing is supposed to have. It's supposed to have zero. Mine is resting on the bottom of the bracket.
    So ordered mine, 5%off still works. Came out to $71 for me.
    Thank you for this find. Also, resurrecting for visibility.
    bmf4069 and mcharfauros like this.
  20. Aug 24, 2021 at 4:10 AM
    #110
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Resurrection you say?
  21. Aug 24, 2021 at 4:53 PM
    #111
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    DaWhiteTundra and bmf4069 like this.
  22. Oct 21, 2021 at 11:52 AM
    #112
    TRUBGR
    TRUBGR New Member
    Which way do the arrows on the casing face, forward or aft?
  23. Oct 22, 2021 at 3:01 AM
    #113
    912
    2005 DC 4x4
    Pretty sure the arrow points fore.
  24. Oct 23, 2021 at 11:57 AM
    #114
    TRUBGR
    TRUBGR New Member
    Yeah, that's how I put it in yesterday and what a difference! My original bearing went after 170,000 miles. I paid over $100 for a Timken bearing and after I installed it, I gave the driveshaft a shake and it was actually looser than the shot one.
    Took a drive and it vibrated worse than the shot one. I immediately contacted the seller and they wanted me to buy another one, wait for it to get to me, change it out and then return the bad one.
    I told them I can’t have my truck down for a wee and a half so I said I was going elsewhere and they did issue me a pre-paid label to ship the bad one back…we’ll see if they give me credit without some BS.
    So glad I found this forum and the post about the correct bearing. The Spicer was only $78 with shipping and it did say Toyota in the rubber.
    Playfast12 and 912[QUOTED] like this.
  25. Oct 23, 2021 at 2:49 PM
    #115
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    04 Tundra AC, 2014 Tundra 1794 Crew Max
    Whole truck Raptor liner in olive green, leer camper cap, 5100 with OME, Wheelers AAL and Firestone Air bags.
    Just placed an order for Spicer 5002007 from Autoplicity in which supposedly they have 10 in-stock. I couldn't find nobody that had it in stock. For reference I have a 04AC 4x4 with bearing part number 37235-35030. Hopefully I ordered the correct one snice these part numbers are confusing.
  26. Oct 25, 2021 at 8:15 AM
    #116
    Teutonics
    Teutonics BestGen Member
    2005 DC SR5 4WD
    Yeah, this is hard to find at the moment. Just a heads up that I was able to find it (of all places!) via the Walmart site. $75.05 (+tax) with free shipping (and free returns just in case).
  27. Oct 25, 2021 at 9:36 AM
    #117
    Dave8699
    Dave8699 Trackrat
    David
    NJ
    Just called Autoplicity to confirm my order. They have 5 in-stock incase anyone needs one. Shipped it was $80.23
  28. Feb 26, 2022 at 5:51 PM
    #118
    Playfast12
    Playfast12 New Member
  29. Feb 26, 2022 at 5:52 PM
    #119
    Playfast12
    Where did you get it at?
  30. Feb 27, 2022 at 2:55 PM
    #120
    User was last seen 5ish months ago, you may or may not get a response.
    Playfast12[QUOTED] likes this.
