Crewmax rolldown back window and camper shell?
Discussion in 'Tonneau Covers, Caps and Shells' started by DTL8686, Jul 7, 2017.
  1. Jun 16, 2021 at 10:17 PM
    #61
    Booney
    Booney New Member
    Northern Colorado Mountains
    Smoked Mesquite 2021 1794 Off Road TRD
    A.R.E offers a "compression gasket" option with some of their shells.
    The A.R.E. catalogue in PDF:
    https://www.google.com/url?sa=t&rct...cat_0209.pdf&usg=AOvVaw1zJGDZBhhdoGxIwrW8zFoX
  2. Jun 16, 2021 at 11:31 PM
    #62
    TygerTundra
    TygerTundra New Member
    '07 Limited DC
    A temporary solution I've seen is to inflate a bicycle inner-tube between the cab and topper.
    Admittedly, I've only seen it done on DC's where the tube went completely around the sliding window, but I imagine something similar could be worked out as a temporary solution for the power window as well. You would have to glue more than 1 inner-tube together, but it might work.
    2undra likes this.
  3. Jun 17, 2021 at 7:50 AM
    #63
    Fyshhead
    Fyshhead New Member
    Mark
    Folsom
    2021 Tundra Limited MGM TRD Off Road DC
    Vehicle Modifications:
    If you run a boot, get the 3M clear film to put on the cab where the boot seats. I had one in the 80’s, and if you don’t run the film your paint will get rubbed off from boot vibration.
  4. Jun 17, 2021 at 10:10 AM
    #64
    BlancaLaGordita
    BlancaLaGordita New Member
    Blanca
    2021 Tundra TRD Sport
  5. Jun 23, 2021 at 10:34 PM
    #65
    1genjunky
    1genjunky New Member
    04 tundra DC
    So I actually took this approach and used two fat tire bike tubes and gorilla glue. I need to make it a bit smaller circumference but it works better than foam. And I am very happy with it.
  6. Jun 24, 2021 at 9:45 PM
    #66
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    You where able to glue the tubes together and get them to hold air?
  7. Jun 25, 2021 at 12:03 AM
    #67
    1genjunky
    04 tundra DC
    Yes, gorilla glue. let sit for 24hr+. doesn't take much pressure for a good seal. held up on my last camping trip in 90+ weather.
    Joe333x[QUOTED] likes this.
  8. Sep 2, 2021 at 10:11 PM
    #68
    Joe333x
    Joe333x Member
    Boston
    After a 1000 mile trip with the foam tubes I think Im ready to try this approach. Are they still holding air for you? I was thinking about using vulcanizing cement.
  9. Dec 7, 2021 at 3:18 AM
    #69
    jhardy1979
    jhardy1979 New Member
    Justin
    MGM 2015 Tundra Crewmax Limited 4x4
    I just ordered a couple of fat tire bike tubes and going to try this out.
    1genjunky[QUOTED] likes this.
  10. Mar 11, 2022 at 3:31 PM
    #70
    WillTunBlack20
    WillTunBlack20 New Member
    William
    Houston, Tx.
    2020 Tundra TRD PRO Midnight Black
    Grille Lights, Bumper Lights, Front Facing Camera, Interior Upgrade, Leer Topper
    Interesting, I was able to get the X-tra large, accordion boot installed, My TRD PRO, Crewmax, rear window, is down, and I have no leaks, from rain, car wash, or pressure wash sprayers, I will be posting pictures, with additional information soon
  11. Mar 11, 2022 at 4:00 PM
    #71
    Joe333x
    Joe333x Member
    Boston
    Definitely interested!
  12. Mar 11, 2022 at 4:48 PM
    #72
    jhardy1979
    Justin
    Following
  13. Mar 11, 2022 at 6:20 PM
    #73
    jhardy1979
    Justin
    Do you have any pictures and can you post a link to what you got?
  14. Mar 11, 2022 at 6:52 PM
    #74
    WillTunBlack20
    William
    Houston, Tx.
    Yes sir, getting information together, and will be posting pictures, want to make sure all is accurate, it was interesting, but I was hoping it worked well, so far, things are good, now ready to add to our forum, @abomb60, a little more information, any more questions, don’t hesitate to ask.
    Joe333x and jhardy1979 like this.
  15. Mar 12, 2022 at 4:01 PM
    #75
    WillTunBlack20
    William
    Houston, Tx.
    Sorry for the delay, finally some sunshine, not too cold in H-Town, the accordion boot was purchased 1-18-21, from Mediatunes Inc., google search, located in California, I’ll try to answer any, and all questions
  16. Mar 12, 2022 at 4:03 PM
    #76
    trucknut
    trucknut New Member
    2021 Cav blue SR5 TRD Off Road
    Can you still roll up the rear cab window?
  17. Mar 12, 2022 at 4:04 PM
    #77
    WillTunBlack20
    William
    Houston, Tx.
    The boot is not on the painted area of the truck, it is attached to the lip of the rear window, I used pliers to go completely around to make sure the seal was tight, and so far no issues.
  18. Mar 12, 2022 at 4:08 PM
    #78
    WillTunBlack20
    William
    Houston, Tx.
    @trucknut, yes I can, but the seal is complete, so no need to put my window up, the boot attaches to the lip on the Camper, and with the flexibility of the boot, no problem’s to report.
    jhardy1979 and trucknut like this.
  19. Mar 12, 2022 at 4:13 PM
    #79
    WillTunBlack20
    William
    Houston, Tx.
    At the bottom of the window, I manipulated, the boot, used some sealant, and we were good to go.
    trucknut likes this.
  20. Mar 12, 2022 at 4:57 PM
    #80
    jhardy1979
    Justin
    So which one did you order and how long?
  21. Mar 12, 2022 at 5:06 PM
    #81
    WillTunBlack20
    William
    Houston, Tx.
    It was the ultra wide Item #544, 12 foot long, it gave me plenty of maneuverability, to keep it off the painted area of the truck, and the lip of the camper, I did some cutting, and was still able to get a overlap.
    jhardy1979 likes this.
  22. Mar 12, 2022 at 6:35 PM
    #82
    jhardy1979
    Justin
    Do you think the Extra wide would work? Looks like its all bunched up in your picture.
  23. Mar 12, 2022 at 6:55 PM
    #83
    WillTunBlack20
    William
    Houston, Tx.
    You have to decide yourself, mines is bunched up, that’s the manipulation, it’s wide enough, but you have to get it to curve, following the contour of the window, but being attached to the lip of the camper, camper window, is small than the truck window.
  24. Mar 13, 2022 at 4:27 AM
    #84
    thedonn
    thedonn New Member
    great looking truck ! what cap is this and how long did it take to show up?
  25. Mar 13, 2022 at 11:10 AM
    #85
    WillTunBlack20
    William
    Houston, Tx.
    @thedonn, it is a Leer 100XQ, it was ordered, and not purchased, so I stopped in to order, and received a nice deal, and it was installed 3hrs later.
  26. Mar 13, 2022 at 11:32 AM
    #86
    jhardy1979
    Justin
    Wow thats pretty lucky
  27. Mar 13, 2022 at 11:59 AM
    #87
    WillTunBlack20
    William
    Houston, Tx.
    Yes sir, was a place on my delivery route, stopped in, and yes it was waiting for me, right after adding my bed rug.
  28. Jun 5, 2022 at 8:04 AM
    #88
    CarlsSenior303
    CarlsSenior303 New Member
    Carl
    2022 Tundra Limited TRD Offroad Army Green (hopefully)
    Does this still hold up for you?? Love this approach to use temporarily for camping.
    WillTunBlack20 likes this.
  29. Jun 5, 2022 at 12:34 PM
    #89
    1genjunky
    04 tundra DC
    It is working very well. Fill it with N2 if you can.
