Daily Tundra with off-road trips in mind
Discussion in '2.5 Gen Builds (2014-2021)' started by king.cong.1119, Jun 1, 2022.
  1. Aug 17, 2023 at 10:54 AM
    #121
    king.cong.1119
    king.cong.1119 [OP] New Member
    upper control arms are stock. not problem, feel free to ask anything, hope it helps.
  2. Oct 4, 2023 at 7:01 AM
    #122
    king.cong.1119
    Installed Decked drawer system this week, loving it so far.
    This is how my truck sits now.
    • bed rack: 80lbs
    • softopper: 40lbs
    • decked drawer system: 200lbs
    • spare tire carrier+spare tire: 200lbs
    2 inch front and 1inch rear lift (with the 520lbs in the back it probably is even lower than stock?) and 37s. So I think it could actually look proper with the L59-121-R option.
  3. Oct 13, 2023 at 6:44 AM
    #123
    king.cong.1119
    Just documenting the set up as of today.
    Front: 6112 on the 1.9inch lift notch (2nd from bottom)
    Rear: 5160 with stock leafs +2 Coachbuilder shackles (planning on replacing the stock leafs with dobinson's medium duty leafs 121)
    Stock UCA
    No BMC, removed the plastic parts behind wheel wells
    Tire: BFG KO2 37x12.5 r17 (load range C)
    Wheel: Method 705 17x8.5 +35mm offset
    Took my son camping, slept in the bed on top of the Decked drawers system, absolutely love it.
  4. Oct 20, 2023 at 11:50 AM
    #124
    king.cong.1119
    Dobinson L59-121-R rear leaf going in.
  5. Oct 21, 2023 at 6:05 PM
    #125
    TheTundra
    TheTundra New Member
    Christian
    Botetourt county, Virginia
    2014 dclb
    Bilstein 5100, toytec shackles, RC UCA, 33X11X18 yoko at-x
    Sorry if you've already covered this, but no BMC correct? 37s and no chop on stock UCA is crazy.
  6. Oct 22, 2023 at 5:35 AM
    #126
    king.cong.1119
    No bmc correct, daily on road driving is zero issues. However, under full compression up front, it does rub on body Mount.
  7. Dec 12, 2023 at 11:53 AM
    #127
    king.cong.1119
    3 year ownership update of my 2020 Toyota Tundra.
    B.Ross, CaptRussia253 and BillyB like this.
  8. Dec 13, 2023 at 10:17 AM
    #128
    Tracer1794
    Tracer1794 New Member
    Missouri
    2019 CM 1794
    Hey Cong, how is your truck tolerating the new tire size in regards to the speedometer readout and traction control performance. I figured a tire size increase like this could change how fast the truck engages the ATRaC
    king.cong.1119[OP] likes this.
  9. Dec 13, 2023 at 10:36 AM
    #129
    king.cong.1119
    great question, going up in tire size from 32 to 36.5 inch definitely delayed the ATRAC's reaction time a bit, but since I have added the rear locker, it was not much of a problem. I used to have a 4th gen 4runner and went from stock 31s to 34s and no rear locker, and found out that the ATRAC was much less aggressive compared to stock ish tire size. It still gets the job done but then I think the sweet spot (imo) for 2nd gen tundra is around 35 ish. Another thing I found out that could affect the decision making is the engine brake on lower gears. I realized that I am on the brake much more often during steep declines compared to stock size, that is also due to the larger tire which decrease the effectiveness of the engine torque put on the ground. A regear could help but I am okay with it for now. hope that helps. cheers.
  10. Dec 13, 2023 at 11:57 AM
    #130
    king.cong.1119
    oh and the speedo is about (36.5-32)/32 = 0.14 =14% off, so if the speedo says 60mph then its actually 60*1.14=68.4mph. but the speedo inaccuracy doesn't bother me too much since I drive slow anyways. one good trade off is that the speedo would have 14% less miles than the truck actually has lol.
  11. Dec 13, 2023 at 11:57 AM
    #131
    Tracer1794
    Missouri
    2019 CM 1794
    Thanks for the reply! I suppose lockers are probably a superior tool to ATRAC in a lot of off road situations. It’s interesting that you bring up engine breaking I never would have considered that.
    My next curiosity is how well the truck handles daily driving in winter/slick conditions. Is the stability control still fast enough to be effective?
  12. Dec 13, 2023 at 12:01 PM
    #132
    king.cong.1119
    no problem, and as far as onroad daily, it's been fine with rainy days and all, never had a chance to drive the 37s in snow/icy condition yet, but with the extra sluggishness (reduced effective torque output) its probably going to do just as fine if not better? and for the slick condition stability control I am not 100% sure, however, thinking about it in my head, the traction control would kick in when it detects rpm difference in wheels? its hard to say. but I will certainly find out when it snows here in the mid-atlantic region.
  13. Dec 13, 2023 at 5:15 PM
    #133
    Tracer1794
    Missouri
    2019 CM 1794
    Thanks for the reply! I’m slowly building my tundra into a more capable off roader. I’m enjoying the hobby more and more every time I hit the trails. I really appreciate your YouTube channel, it’s one of my favorites for off road content! Keep it up man!
  14. Dec 19, 2023 at 6:41 AM
    #134
    king.cong.1119
    Thank you for the kind words! Cheers!
  15. Dec 19, 2023 at 6:51 AM
    #135
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Checked out your build here and the truck is killer! Lots of good info too. Gonna check out the YouTube next. :thumbsup:
  16. Dec 19, 2023 at 7:25 AM
    #136
    InfernoTundra15
    InfernoTundra15 2015 TRD Pro
    I just watched your truck on Tinkerer’s Adventure this morning!
  17. Dec 19, 2023 at 7:42 AM
    #137
    king.cong.1119
    Thank you, hopefully my posts provide some helpful info
  18. Dec 19, 2023 at 7:58 AM
    #138
    king.cong.1119
    ah, yes that'd be me with the black tundra.
  19. Jan 25, 2024 at 10:11 AM
    #139
    king.cong.1119
  20. Jan 29, 2024 at 12:40 PM
    #140
    king.cong.1119
  21. Jan 31, 2024 at 2:04 PM
    #141
    CMTX 1794
    CMTX 1794 New Member
    Sheb
    2018 Silver 1794 edition 4x4
    Soon
    Oh no….
    Found this thread, AND your YouTube. My wallet will never forgive me. lol.
    Subscribed to your YT. Can’t wait to check out all the content.
    Thanks so much for your help in answering my questions on other threads. I will lean into you for knowledge and wisdom as I continue my build journey, IF you don’t mind.
    LOVE the rig. The look is near identical to what I have in mind for mine, and the application is certainly the same. My tundra is my daily, and our current only family vehicle. I want to be able to throw a cooler in the truck and go trail riding and camping at a moments notice.. again, thank you for the content and allowing us all to learn from it and enjoy!!!
  22. Feb 1, 2024 at 6:43 AM
    #142
    king.cong.1119
    Thank you for the kind words. I don't mind at all with any questions, as I am also learning together in this journey.
    CMTX 1794[QUOTED] likes this.
  23. Feb 9, 2024 at 9:48 AM
    #143
    king.cong.1119
    Sadly, Tundra life is soon to come to an end, recent life changes won't allow me to easily climb in and out of a lifted truck on 37s, but I am staying in the Toyota family.
    jmladdy likes this.
  24. Feb 9, 2024 at 10:27 AM
    #144
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Dang man. Sorry to hear that. Hope you’re ok
  25. Feb 9, 2024 at 10:29 AM
    #145
    king.cong.1119
    Thanks man, so far i am doing well, had a disc herniation (irreversible) late last year and it put me down for a solid 4 months. now climbing in to the beast has been not easy. a stock taco would be just fine.
    Terndrerrr[QUOTED] likes this.
  26. Feb 9, 2024 at 8:09 PM
    #146
    CMTX 1794
    Sheb
    Soon
    oof. That's rough, man. GLad you're doing the best you can, anyway!
  27. Mar 24, 2024 at 8:33 AM
    #147
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    Bummer to see you sold your Tundra. Always enjoyed watching your tests of products. And your collabs with Kai. Good luck with your new Taco!
  28. Mar 31, 2024 at 9:33 PM
    #148
    Seabass152
    Seabass152 New Member
    21 Double Cab SR 8ft bed
    Long shot, but do you remember how much space you had between tire and UCA? Thanks
  29. Apr 1, 2024 at 12:02 PM
    #149
    king.cong.1119
    Hi I did not measure but you can get a visualization of the gap in this video I have posted.
    https://youtu.be/c5-WO8CHCmQ
    CaptRussia253 likes this.
  30. Apr 1, 2024 at 12:20 PM
    #150
    Seabass152
    Thanks
