Dasaita Android Head Unit
Discussion in 'Audio & Video' started by 916tundra, Apr 27, 2019.
  1. Jun 12, 2020 at 6:25 PM
    #1291
    buckrub71
    buckrub71 Like Father, Like Son--Semper Fi
    2016 Bronze 1794 CM
    Thanks...really appreciate it!
  2. Jun 13, 2020 at 1:07 AM
    #1292
    PLTNM808
    PLTNM808 New Member
    Has anyone successfully added after market amps to Dasaita 10.2 unit? Prior to install, both aftermarket amps worked, connected to kenwood double din. After dasaita install, amps remote turn on wire was connected to "amp det" wire located on harness that has audio out " sub, mid, left and right audio output". Amps dont turn on and i only have audio from dash speakers which are still connected to jbl amp.
  3. Jun 13, 2020 at 5:27 AM
    #1293
    buckrub71
    2016 Bronze 1794 CM
    Yes, just finished 2 days ago...JL amp. I tapped into the light blue wire from the harness under the passenger seat. It puts out 11 volts and triggers the amp.
  4. Jun 14, 2020 at 12:11 AM
    #1294
    PLTNM808
    PLTNM808 New Member
    Aloha,
    anyone lose their door chimes and alarm chirp after installing this unit? I checked every setting and there is nothing that comes close to turning it back on. The only selection was enabling or disabling the flashing parking lights.
  5. Jun 14, 2020 at 3:49 AM
    #1295
    buckrub71
    2016 Bronze 1794 CM
    This didn't happen to me. However, I'd recommend you do a search for this topic. There were a number of folks who I recall posting this same issue. I also recall some folks using techstream to reactivate the chimes.
  6. Jun 14, 2020 at 7:39 AM
    #1296
    kameleon
    kameleon New Member
    Jackson, MS
    2015 Crewmax Limited 5.7 MGM
    Your best bet is to put the factory unit back in and reset the setting or either find a friend with techstream and get them to reset it. Alternatively if you don't want to do either you can take it to the dealer and have them reset the setting. Mine did it and I used my techstream to reset it. I've also lost all interior lights after the tire shop reset my tpms before so my techstream has more than paid for itself.
  7. Jun 14, 2020 at 12:30 PM
    #1297
    PLTNM808
    PLTNM808 New Member
    Thank you for the quick responses, I have the techstream software and cable just need to find a laptop.
  8. Jun 14, 2020 at 1:04 PM
    #1298
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Hey guys. I’m finally thinking of ordering a head unit. This seems to meet all my criteria. I’m thinking the 10.2 9” 2nd gen version. I’ve read 22 pages of the thread and am still left with one question.
    My 2008 limited is a jbl non-nav, non-rearview cam truck. Does my truck k have factory rear view wiring, if so, can I use it? Is this cam wiring? Tia
    edit: also is there a aftermarket Amazon special tailgate handle cam that ties into factory?
  9. Jun 14, 2020 at 2:00 PM
    #1299
    kameleon
    kameleon New Member
    Jackson, MS
    You will probably be better off just getting an aftermarket camera. That way you have better picture quality. The stock one is a little grainy.
    You could get a handle with the camera hole and find a camera that will fit. Like this: https://amzn.to/3fo3p6L
    Mountun Goat[QUOTED] likes this.
  10. Jun 14, 2020 at 2:07 PM
    #1300
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Great info, thanks.
  11. Jun 18, 2020 at 8:17 AM
    #1301
    supermotobobby
    supermotobobby New Member
    Bobby
    2022 Tundra Platinum 4x4
    Help! Dasaita 10.1 WiFi won't turn on anymore.
  12. Jun 19, 2020 at 3:40 AM
    #1302
    PLTNM808
    PLTNM808 New Member
    So, I was asked by Iris from Dasaita to update my unit. Apparently they sent me a new MAX10 (Android 10) instead of the 9.0 that i ordered. After said update was complete, I noticed that some apps that where on my screen are now hidden. When i go into Settings-Apps they are are there, but I can't select them to put/move to my main screens. If i want to use for example the AVIN input app i have to go into settings and then apps and then select it to open. Any suggestions?
    Instructions:
    If you have any software issue, here is the link for you to download the file, and format the usb(or just make sure it only has zip file at the usb) ONLY put update.zip file to the usb, and plug that usb via the usb cable to our stereo.
    HA3_rk3399_10.0_ota(20200609) https://www.sendspace.com/pro/dl/6nuqq5
  13. Jun 19, 2020 at 5:21 AM
    #1303
    kameleon
    kameleon New Member
    Jackson, MS
    Where did you order the unit from? When did you order it?
    As for the icons, the default launcher might not have the ability to put more icons on but a 3rd party one should.
  14. Jun 19, 2020 at 8:07 AM
    #1304
    PLTNM808
    PLTNM808 New Member
    Bought it on Amazon within the last month. Apparently, the update is flawed. I tried going into settings-apps- default apps, it wont let me select the car launcher 3 its stuck on chrome.
  15. Jun 23, 2020 at 11:08 AM
    #1305
    sjanz
    sjanz New Member
    Tappen, BC
    2008 Tundra CM Limited
    2" lift, Airaid cold air intake, aftermarket wheels, tonneau cover...
  16. Jun 23, 2020 at 11:23 AM
    #1306
    kameleon
    kameleon New Member
    Jackson, MS
    sjanz[QUOTED] likes this.
  17. Jun 23, 2020 at 3:51 PM
    #1307
    sjanz
    sjanz New Member
    Tappen, BC
    I tried one of those too but no go... it’s an older one, so maybe I need a newer one.
  18. Jun 25, 2020 at 11:50 PM
    #1308
    Thattundradude
    Thattundradude New Member
    Platinum Tundra
    Lifted
    I have the 10.2 installed and there's a buzzing that is driving me crazy. Its so bad that it gives me a headache. I can't figure out whats causing it. It comes from the unit and only stops when I turn the unit off. Anyone experience this?
  19. Jun 25, 2020 at 11:56 PM
    #1309
    buckrub71
    2016 Bronze 1794 CM
    Yeah, I had it too (I have an aftermarket amp added). But I went back and reread this post to find others who had it. Did you run the ground to the chasis? That worked for me!
  20. Jun 25, 2020 at 11:59 PM
    #1310
    Thattundradude
    Platinum Tundra
    Lifted
    No, the ground cable is very short, where did you ground it?
  21. Jun 26, 2020 at 12:03 AM
    #1311
    buckrub71
    2016 Bronze 1794 CM
    I used a posi-lock to run additional wire to the ground location under the front passenger seat.
  22. Jun 26, 2020 at 12:06 AM
    #1312
    Thattundradude
    Platinum Tundra
    Lifted
    Going to try that. Thanks.
  23. Jun 26, 2020 at 12:32 AM
    #1313
    buckrub71
    2016 Bronze 1794 CM
    NP. Good luck!
  24. Jun 26, 2020 at 6:45 PM
    #1314
    TundraRed
    TundraRed New Member
    Hello all,
    I have a 2018 crewmax platinum (with JBL/NAV), interested and trying to replace the oem head unit with the latest version of Dasaita that comes w/ apple/android auto carplay pre built.
    couple of questions.
    1) aliexpress links for head unit and canbus? i tried to figure this out, but no luck
    2) is the required harness all comes with the unit order? is it PnP with my truck's existing harness?
    Thanks for your help.
  25. Jun 26, 2020 at 7:01 PM
    #1315
    kameleon
    kameleon New Member
    Jackson, MS
    Try this: https://www.aliexpress.com/item/33058388173.html?spm=2114.12010612.8148356.22.6f587ea75muSPn
    Select DYX004 w/ Carplay
    Then for the harness/canbus you'll need this: https://www.aliexpress.com/item/32911401218.html?spm=2114.12010612.8148356.1.63201227XGc4h9
    You can always message them and let them know what you have and they should get you the right things.
  26. Jun 26, 2020 at 7:46 PM
    #1316
    TundraRed
  27. Jul 1, 2020 at 12:07 PM
    #1317
    kameleon
    kameleon New Member
    Jackson, MS
    Those that have an aftermarket TPMS with this unit, which one did you use? Looking for one that I can put on my truck and a separate one for my travel trailer. The TT one will be a separate device though and not go through the head unit.
    Mountun Goat likes this.
  28. Jul 4, 2020 at 8:47 AM
    #1318
    Kturner23
    Kturner23 New Member
    Keith
    2018 Tundra Crewmax Limited
    Any body get an srs airbag malfunction installing theirs?
  29. Jul 5, 2020 at 7:26 AM
    #1319
    Kturner23
    Keith
    Got it figured out
  30. Jul 9, 2020 at 6:01 AM
    #1320
    ruiner
    ruiner New Member
    2017 Tundra CM 4x4
    Some advice for people ordering as I just went through this, myself:
    DO NOT use prime and do not have it fulfilled by the Amazon store. Before you select 'add to cart', go to the bottom right and select from the "New (2) from..." option or whatever is there. THEN, select the one from the Dasaita Official Store that pops up (they misspelled 'Offical' below). You can tell because it has the extra shipping charge (China shipping I guess). That is the only way to get the proper cables installed into the box before it ships. You select that option and THEN message the seller (Iris will get back to you). Otherwise, it will come from a local warehouse in the US and you will be missing things. Also, note that they have multiple listings for the same thing. In my case, they have (2) listings (both are the same according to Iris) for the 4GB RAM/64GB ROM version with the square edges (not a fan of the curved-edge one with the Dasaita logo).
    For now, I wait for the package to come from China. :)
