Dealer cost to install lift
Discussion in 'Suspension' started by Lambeau, Feb 20, 2019.
  1. Feb 21, 2019 at 9:14 AM
    Faht Nocker
    Faht Nocker Platinum Member
    Woody
    Milky Way
    2016 Super Fast White Platinum 4x4 Faux PRO Tundra
    The only thing that I would take into consideration is the new technology on the 2019. I was told by a Toyota salesman that they have received internal letters from Toyota about NOT lifting the new Tundras. I know many people on here have done it successfully, but I would research that before you do anything. You have a Platinum and considering the extra cost from the dealer...it is not that much in the grand scheme of things. My $.02
    Lambeau[QUOTED][OP] likes this.
  2. Feb 21, 2019 at 9:45 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Every dealer is different which sucks. I have 3 by me. One will install lifts before you buy and warranty everything. Another will install after the fact and warranty everything as long as you bought it from them. The last one is anti-lift and if anything goes wrong the lift did it.
    Boerseun likes this.
  3. Feb 21, 2019 at 9:47 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    if the dealer can bill toyota for warranty work, why would they ever deny stuff...?
    Lambeau[OP] likes this.
  4. Feb 21, 2019 at 6:07 PM
    Lambeau
    Lambeau [OP] New Member
    2024 Black Tundra 1794 Limited Edition
    285/60/R20 BF Goodrich KO2’s
    Went to another Toyota dealer in town. They quoted $650 for installation of all parts and alignment.
    A friend recommended a local custom shop and they quoted $585. They also said they doubted any calibration required for any sensors on a 3” lift, but we will see.
    Obviously I’m undecided on doing it myself vs having a shop do it. I would be interested to know if any of you guys lifted a ‘19 without sensor problems.
    Probably going to let this dealer do it for the peace of mind. I’ll post the results.
    Boerseun and Faht Nocker like this.
  5. Feb 22, 2019 at 4:16 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    No problems with my 18’. I didn’t have any issues prior to the lift either though.
    The install is not that bad. The trick is to mark your cam bolts position and then loosen them a bit. This will free up the LCA enough to drop it low enough to get the coil assembly out and new in. Just tighten back to the marks as best you can after. It will get you good enough to drive to get the alignment
  6. Feb 22, 2019 at 4:30 AM
    Steve6
    Steve6 New Member
    Tucson
    Not an option for me since my dealer will not install a lift on a 2018 due to possible TSS issues (their claim, not mine).
  7. Apr 2, 2019 at 6:18 AM
    LastCanadianExit
    LastCanadianExit The dude abides...
    Bucks County, PA
    2018 Platinum
    ReadyLift 8" Lift Fuel Trophy Wheels Yokohama 37s
    So what is the deal with the TSS issues? Are they real? I want to put on an 8" lift and a little concerned.
  8. Apr 2, 2019 at 6:39 AM
    Danman34
    Danman34 New Member
    Danny
    Yes they are real for some. The sensors aren’t designed to be adjusted past 3-4” from stock height. It’s luck of the draw on whether you’ll have issues or not with 8”.
  9. Apr 2, 2019 at 6:45 AM
    LastCanadianExit
    Bucks County, PA
    2018 Platinum
    Then what happens? Just live with the issue?
  10. Apr 2, 2019 at 6:50 AM
    Danman34
    Danman34 New Member
    Danny
    Yea. Pretty much. Toyota won’t touch it or help if you have issues after an 8” lift.
  11. Apr 2, 2019 at 7:05 AM
    Norfolk757
    Norfolk757 עַם יִשְׂרָאֵל חַי
    Tom
    Norfolk, VA
    2015 White Tundra- CrewMax TRD Off Road
    Those prices are insanely low! In my area, I wouldn't trust the dealers(Checkered Flag or Priority) to remove a lug nut off my truck let alone do a lift install. The local Toyota dealers are completely incompetent, they do not understand the first things about mechanics and logical thinking. My experience is 2018 4RUNNER and my Tundra, where I had to get back to each dealer (more than 5 times) for simple services that they could not perform (such as oil change, tire rotation, maint light reset). I am afraid to even go anywhere near a lift work on my truck or my 4Runner that is performed by any local Toyota dealer. The price for a 6112/5160 2" lift with shackles at a local off-road shop was around $1500 not including alignment. Furthermore, none of the local off-road shops will even talk to you if you don't buy the part from them at a higher price. So overall, your prices at the dealer or local shop are super cheap based on my area price and competencies.
  12. Apr 2, 2019 at 8:06 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Toyota says you can lift up to 3” without issue. So if something goes wrong they will fix it. Anything past that then they will say the 8” lift caused the issue.
    Basically they need to prove that the lift caused it or you need to prove it didn’t. Most dealerships play nice. But some hide behind everything.
  13. Apr 6, 2019 at 5:12 PM
    thornjude89
    thornjude89 New Member
    South Louisiana
    2019 Tundra Black SR5 Crewmax 4x4
    Stock
    So leveling would be ok? what about 3/1? Im just a little skiddish and don't want to void warranty.... i just paid for **8yr bumper to bumper 125000 warranty**.. my dealer is a no go.. they are anti life/ level dealer.
