DESK TO GLORY TUNDRA HOUSE ON WHEELS
Discussion in '2nd Gen Builds (2007-2013)' started by TOTAL CHAOS, Apr 17, 2024.
  1. Apr 17, 2024 at 4:49 PM
    TOTAL CHAOS
    TOTAL CHAOS [OP] WWW.CHAOSFAB.COM Vendor
    Corona, CA
    Text and images by Richard Giordano of Desk to Glory.
    There are many reasons why long term international travelers generally shy away from aftermarket parts, but over the years we have found that there are just as many reasons to select a few high-quality components that will help us stay out longer, increase the overall durability of our vehicle, and allow us to maintain or repair our vehicle in the field – all with fewer spare parts on hand. In our case, we’re shipping our North American designed and built Tundra to Europe. From there we expect to find ourselves in Northern Africa and beyond. Sure, this Second Gen Tundra shares a plethora of parts with the venerable 200 Series Land Cruiser, but it does have plenty of proprietary components that may be harder to find overseas. Using a selection of TOTAL CHAOS Fabrication parts we’ve increased overall strength and performance of our suspension and made it easier to service worldwide at the same time.
    REINFORCING KNOWN WEAK LINKS
    When the factory suspension was removed we installed cam tab gussets and spindle gussets to increase the strength of the weak OEM pieces. The tall and skinny Tundra spindle is prone to bending under stress, so reinforcing them with TOTAL CHAOS spindle gussets was a no-brainer. As noted in Toyota Cam Tab Gussets: Do I Need Them?, cam tab gussets replace the weak factory plates that are vulnerable to deflection or shearing under high impacts. This can throw the alignment off and wear out tires prematurely.
    TOTAL CHAOS cam tab gussets help ensure your vehicle retains its alignment specifications.
    TOTAL CHAOS Cam Tab Gussets replace the weak factory alignment cam tab plates that bend during bottom outs or hard front impacts.
    The intention when installing these pieces was not because we regularly abuse our home-on-wheels when traveling, but for those unforeseen instances when inadvertently hit a Mexican topé, monstrous pothole in Houston, or G-out in Morocco. If these instances occur, and all that’s necessary is to rearrange some things in the camper or field-align the truck, that’s a lot better than having to deal with a sheared off cam tab, or a bent spindle.
    TOTAL CHAOS SERVICEABLE CONTROL ARMS
    The second generation Tundra’s control arms are unique to the truck, so adding stronger and rebuildable TOTAL CHAOS upper and lower control arms made perfect sense instead of sourcing complete replacement OEM control arms. Urethane bushings reduce deflection, lower control arms retain sway bar mounts, and the upper control arm’s inherent design provides an additional one-inch of wheel travel when paired with longer shocks. This, combined with the ability to retain factory alignment specs when lifted, means that our heavily laden Tundra continues to perform well on and off-pavement.
    TOTAL CHAOS Upper Control Arms are one of the first upgrades we recommend to any Toyota owner.
    Factory lower control arms are not rebuildable. Why replace when you can upgrade?
    Regular lubrication keeps the noise down, and the zerk fittings make this process super simple.
    After installation and an alignment we marked each cam bolt with a paint pen. At a glance we can now see if anything has moved. There is still the potential for these bolts to rotate under very hard impacts, but with gussets and paint marks in place we can reset the alignment in the field.
    TOTAL CHAOS UCAs can be paired with any brand coilover, assuming they have the appropriate amount of travel.
    The sway bar provision on TOTAL CHAOS LCAs means you don’t have to make any compromises.
    REPLACEMENT PARTS AND TOOLS
    To ensure that we have the parts necessary to maintain the control arms when abroad we packed the following items in the truck:
    The sealed replacement parts take up minimal space in our Tundra.
    Each of the upper/lower uniballs are the same, so instead of carrying four, we decided on two. We have found that the lower uniballs wear out sooner than the uppers (perhaps due to their lower location being abused by sand and salt, combined with being more difficult to access for regular cleaning), so once those need replacement, we’ll track down or make an order for a second kit. Bushings are unlikely to need replacement, but they’re lightweight and make for an easy swap if the uniballs are being replaced. In our case, the uppers have been installed longer than the lowers, so we have a full set of upper bushings on hand just in case.
    We have seen TOTAL CHAOS equipped trucks around the world including Peru, Saudi Arabia and Iceland. If we require replacement or service parts there seems to be at least one specialty off-road shop in each region that has access to bushing kits and uniballs. Otherwise, it’s always nice to have an excuse to call Pat and kindly to ask him to ship some parts via DHL.
    The current configuration was shaken down in Utah prior to being shipped to Europe.
    This Tundra isn’t only our vehicle, it is our home!
    TOTAL CHAOS FABRICATION PARTS INSTALLED
  2. Apr 17, 2024 at 5:07 PM
    Bailey
    Bailey Enjoy Every Sandwich
    CO
    2011 DCSB Limited 4x4 “Clifford”
    That flatbed setup looks great. I remember when they had a GFC
    TOTAL CHAOS[OP] likes this.
  3. Apr 17, 2024 at 6:36 PM
    TOTAL CHAOS
    Corona, CA
    Here are a few more pics of Richard and Ashley's build:
    Some @Baja Designs lights :cool:
    429941304_18425165101051298_498010614735_b586a0a0197662406b193d0d6516cb7aead2b13c.jpg
    430686019_18425165113051298_187884340060_d7da7435f84b6dad8a965f466f0a32c0b8454b31.jpg
    430091984_18421099504051298_147755959323_02f070644e0c664a9c3c25b0751ebed2b5cdf9fc.jpg
    430092003_18420719557051298_830163274079_afb029a30f05290fe81e7df1a92d20351c51b89c.jpg
    429779728_18420529306051298_447506230461_d50faadff9b3fa922b3a2fad844a23d451f617ac.jpg
  4. Apr 17, 2024 at 7:59 PM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD Praux
    Awesome setup!
  5. Apr 18, 2024 at 6:48 AM
    TOTAL CHAOS
    Corona, CA
    We will be sharing some more pics today including some travel pics and inside pics of the rig. Stay tuned
    They have a great setup :D
    jmladdy likes this.
  6. Apr 18, 2024 at 6:52 AM
    jmladdy
    jmladdy New Member
    Oklahoma
    2020 Tundra TRD Pro
    Unreal. Can't wait to follow along.
  7. Apr 18, 2024 at 8:28 AM
    TOTAL CHAOS
    Corona, CA
    Some interior pics of the camper when Desk to Glory got it:
    jmladdy, Bailey, The Dude and 3 others like this.
  8. Apr 18, 2024 at 8:33 AM
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Washington
    Such a badass build!
  9. Apr 18, 2024 at 8:38 AM
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    Bill
    San Marcos, CA
    There Rig is dialed!
    Best,
    Bill
    Bill Sonevongxay | Forum Sales & Support 
    Email: Bill@bajadesigns.com Phone: (760)560-2252
  10. Apr 18, 2024 at 8:53 AM
    TOTAL CHAOS
    Corona, CA
    :bowdown::bowdown:
    Definitely!
  11. Apr 18, 2024 at 10:08 AM
    AZEric
    AZEric New Member
    Eric
    2010 Rock Warrior
    Bilstein 6112’s & 5160’s
    Very nice Tundra!
    When lower control arm bushings need to be greased via the zerk fittings, do you have to loosen the cam bolts to do so? If so, does that require an alignment afterward?
  12. Apr 18, 2024 at 10:46 AM
    TOTAL CHAOS
    Corona, CA
    You do not have to loosen the Lower Control Arm bolt. Here is a quick video regarding greasing the LCA bushings
    https://www.youtube.com/watch?v=r4wLDoFuANQ
    AZEric[QUOTED] and CaptRussia253 like this.
  13. Apr 18, 2024 at 11:17 AM
    SD Surfer
    Bruce
    So Cal
  14. Apr 18, 2024 at 11:38 AM
    AZEric
    AZEric New Member
    Eric
    2010 Rock Warrior
  15. Apr 18, 2024 at 12:12 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    That is absolutely fabulous.
  16. Apr 18, 2024 at 12:22 PM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Very nice, I dig it :thumbsup:
  17. Apr 18, 2024 at 1:03 PM
    TOTAL CHAOS
    Corona, CA
    Some travel photos and info from @Desktoglory and @Desktoglory_ash
    " Wandering the dark maze of alleys through the Marrakesh souks is such a treat for the senses. Start walking and then choose your own adventure. Left will take you towards the spices and right will take you to the lamps — or is it a right to the leather goods? Regardless, you’ll find something new around every corner.
    Scooters are buzzing past constantly — deftly missing you by mere inches (more room would only increase risk to pedestrians on the other side of the street). "
    434391901_18430093900051298_101165766706_490023b61c7fa3b03b28fcf2d86518867245cfba.jpg
    434393618_18430093918051298_308985215501_f435f982a45f62eda0146387450deb8757cad1b3.jpg
    434379586_18430093891051298_454034845650_3268ab5397c9774b867a20840236dd3cdf086462.jpg
    434390030_18430093861051298_249275275614_007002cdb2d1b2e6de7015d7c0a2f1e3d4137b00.jpg
    434385275_18430093852051298_102945802259_77a0970390e3a09bc7c592f804595f35149681fa.jpg 434374599_18430093834051298_726797651392_eda7a6fd347b23ce69bfaa55bebe4db8d9b479ea.jpg
    434385823_18430093870051298_765705497256_3017b18a7468a6baeb3e98f810ddad55ac5f5419.jpg
    ZappBrannigan and CaptRussia253 like this.
  18. Apr 18, 2024 at 4:28 PM
    Bailey
    CO
    Great pics! Would be great to get out of the country some day
  19. Apr 18, 2024 at 4:52 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Sorry, the nerd in me can’t help it.
    ZappBrannigan and AZEric like this.
  20. Apr 18, 2024 at 5:19 PM
    Florida AF
    Logan
    North Florida
    Not sure what I love more, the photos or the writing... great work and detail!
  21. Apr 18, 2024 at 5:48 PM
    TOTAL CHAOS
    Corona, CA
    "A stop in Marrakesh wouldn’t be complete without a stop at the Jemaa El-Fna night market.
    Of all the places we ate, Mohamed’s little stand serving spiced tea and a scoop of ginger cake was by far the most memorable. I don’t think Mohamed ever stopped smiling the entire time we were there — I didn’t either after the first sip of that tea! "
    434385967_18430299241051298_245614816370_921b1d208727b0f640f281b7f84fb164d2d0fa88.jpg
    434376205_18430299250051298_574752564974_f40a2cd074eeb3f70cb71b4a28219cee21e57888.jpg
    434394747_18430299259051298_386679872506_5dad6d5610a089f75e8471ad76052b2d35040f5a.jpg
    434382800_18430299271051298_517396835624_56c177fb4e4e584e602cf7c601529d2824da3464.jpg 434388395_18430299280051298_146716997582_996d8742ffa3fdac9292fc9da3a4bbc2ac99f779.jpg
    https://www.instagram.com/desktoglory/
    -Team TC
    info@chaosfab.com
    ZappBrannigan likes this.
  22. Apr 19, 2024 at 8:48 AM
    TOTAL CHAOS
    Corona, CA
    We’d recommend it! Certainly a great experience
    All good! Cheers :cheers:
    They do a great job with their content!
