Differential fluid change fair price?
Discussion in '2.5 Gen Tundras (2014-2021)' started by OTX, Sep 10, 2020.
  1. Sep 14, 2020 at 4:31 PM
    OTX
    OTX [OP] 2018 Tundra SR5 Off-road Crewmax 4x4
    Eddy
    North Chicago, Illinois
    I think I know what you mean. Draining and refilling about 3 times?. That way pretty much all the fluid is new. Shall I tell them to do that?. I’m sure the labor will be a lot more. I’m just surprised they did not mention that to me?. They are a Toyota dedicated mechanic out of Houston named Duggys garage. I thought they would know better??
    08TXTundra likes this.
  2. Sep 14, 2020 at 8:48 PM
    kevine0001
    kevine0001 New Member
    Kevin
    I think it took me a little over an hour and a half to do all three
    OTX[OP] likes this.
  3. Sep 14, 2020 at 9:44 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I believe the manual/maintenance workbook says to change differential fluid every 30k miles. Lower interval if you tow. Also, you should engage 4hi once a month and drive 10 miles to keep parts lubricated.
    kevine0001 likes this.
  4. Sep 14, 2020 at 9:54 PM
    pilsnerpopper
    pilsnerpopper New Member
    2010 Tundra 5.7 4x4 Double Cab
    Is this true for 2nd gens too or just 3rd?
  5. Sep 14, 2020 at 10:01 PM
    AZBoatHauler
    So.Arizona
    Just 3rd. 2nd gen has a different t case.
    welcome to the group.
    pilsnerpopper[QUOTED] likes this.
  6. Sep 14, 2020 at 10:15 PM
    KayakTundra707
    KayakTundra707 New Member
    Thanks for that info. But aren’t dealership service supposed to use OEM/Toyota brand fluids in the first place. We’re they using something else?
  7. Sep 14, 2020 at 10:27 PM
    Blue Thunder
    Washington
    Dude, that reply wins the internet today. Holy shit
  8. Sep 15, 2020 at 6:30 AM
    Porkchop Express
    Porkchop Express Its all in the reflexes
    Cody
    2017 Tundra CM
    Lift , tires , stereo , TRD headlights , Rolling tonneau
    Yep ,I bought it with 14 miles on the odometer. There was some metal "sludge" on the magnetic plugs but way less than i was expecting.
    Ive road tripped through Yellowstone and done a few thousand miles offroad in 4WD , so you can see why i was disappointed...
    AZBoatHauler[QUOTED] likes this.
  9. Sep 15, 2020 at 11:41 AM
    YotaBro
    Calvin
    FL
    Lots of shenanigans.
    For what it's worth... I just purchased my 2017 Tundra TRD PRO and after looking at a couple of vids online I am gonna change out the front, rear diff, and transfer case oil this weekend. My owners manual said to use 75W-85 for the front and rear diff, and SAE 75W for the transfer case. After doing some research I decided to use Valvoline 75W-90. I plan on doing all of this once the hurricane passes. It doesn't seem too difficult. So far I have spent a little over 100 bucks in oil and crush washer gaskets. I was also gonna lube up the prop shaft.
  10. Sep 15, 2020 at 11:47 AM
    Porkchop Express
    Cody
    2017 Tundra CM
    Not hard at all, just takes time. I used the same weight in all 3 spots 75w90 Lucas synthetic .
    YotaBro[QUOTED] likes this.
  11. Sep 15, 2020 at 12:34 PM
    BeauGentry4
    BeauGentry4 New Member
    Beau
    CA
    2018 Platinum Tundra Crewmax 4x4
    Not sure if your 2017 is the same as my 2018, but there aren't any grease fittings on the 2018 drive shafts!
    TWJLee and YotaBro[QUOTED] like this.
  12. Sep 15, 2020 at 1:11 PM
    YotaBro
    Calvin
    FL
    I'll let you know whenever I lift the truck. Thanks for the info!
  13. Sep 15, 2020 at 1:19 PM
    YotaBro
    Calvin
    FL
    This may be a dumb question, but if there aren't any grease fittings on your driveshaft do you have to lube it still? If so, how?
  14. Sep 15, 2020 at 1:24 PM
    AZBoatHauler
    So.Arizona
    My 2017 has zerks - 3 in the back and 2 in front. I think they were phased out during the 2018 model year.
    There is no practical way to grease a non-serviceable driveshaft.
  15. Sep 15, 2020 at 1:26 PM
    YotaBro
    Calvin
    FL
    Let me know if I am tracking this correct.... so if I have zerks I need to grease it, and if it doesn't have any zerks then I am good to go and don't need to conduct any sort of maintenance on it?
  16. Sep 15, 2020 at 1:27 PM
    BeauGentry4
    Beau
    CA
    10-4. You got it. I only mentioned it because I had planned to grease mine and was surprised when I crawled under and realized that there weren't any fittings on the '18 drive shaft!
    AZBoatHauler and YotaBro[QUOTED] like this.
  17. Sep 15, 2020 at 1:28 PM
    YotaBro
    Calvin
    FL
    Thank you thank you!!
  18. Sep 15, 2020 at 2:19 PM
    08TXTundra
    08TXTundra New Member
    David
    Houston
    2008 Tundra 5.7 2WD
    Stock. No tow package, 4:10 gears
    This is why I'm skeptical in general when it comes to mechanics, even with Toyota dedicated garages recommended on forums. There's a shop called Javier's that is dedicated to 4x4s and I had them re boot my CV's on my tacoma along with other things. The CV's were still seeping and when I asked the response I got was "its normal" like its excess coming out. Well after cleaning them once or twice and still seeing seepage, I was able to conclude it's not normal. Check the retainers and some were loose. I was fairly new to 4x4s when I had them do it. Now I'm looking to reboot as I don't know how much grease is left. :mad:
    I've also used Duggys to install my suspension and change out the output shaft seal on the transfer case on my tacoma. No issues
  19. Sep 15, 2020 at 2:33 PM
    #49
    OTX
    Eddy
    I’m extremely skeptical too as I can’t tell if they did the job properly or not like what happened with you at Javiers. I would leave a review if I was you as they screwed you really. I would ask for a refund.
    I spoke to Duggys garage today and I asked why the 3 drain and refill cycles were not mentioned and he said that it really doesn’t make much of a difference if I drain and refill once vs 3 times. That doesn’t sound right but then again I’m no expert. They have 5 star reviews on google and Facebook so I guess they know!. I would appreciate if someone who knows about this stuff would weigh in. Thanks
  20. Sep 15, 2020 at 2:43 PM
    #50
    08TXTundra
    David
    Houston
    2008 Tundra 5.7 2WD
    This was done back in December 2017 so I
    the best I can do at this point is leave a review.
  21. Sep 15, 2020 at 2:49 PM
    #51
    OTX
    Eddy
    It’s been a while for sure but I would definitely leave a review for that. They should be held accountable and trust me, those google reviews make a difference!. I’ve had companies ignore a problem and then once I leave a review, they’ll call and offer a solution.
    Once I had a company put brand new brakes that made a very loud whistling noise. I called and said they were faulty but they said there is nothing they could do about it and that it was the wheel bearing that was causing the noise. After I left the review, they called and replaced the pads and guess what...no more noise lol
    08TXTundra[QUOTED] likes this.
  22. Sep 15, 2020 at 6:23 PM
    #52
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    If there's a shortcut/excuse, it will be done/used...if you can, or are willing to learn, always do your own maintenance...especially with YouTube, anything is possible...within reason of course...
  23. Sep 16, 2020 at 6:11 AM
    #53
    BeauGentry4
    Beau
    CA
    I had a buddy who worked in a lube shop when he was in high school. He told me that they had a fake part # that they'd call out when the oil filter was in a PITA location or when they just didn't feel like changing it. That story convinced me to continue to do my own maintainence :eek2:
