DirtyDeeds/BAMuffler Summer Group Buy 2019
Discussion in 'Deals & Group Buys' started by dirtydeeds, Jul 26, 2019.
Thread Status:
Not open for further replies.
  1. Oct 23, 2019 at 1:13 PM
    #1381
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I used a jackstand to hold one end of my system up while i lifted the other side to the bolts.
    Istvank11 and Rica25 like this.
  2. Oct 23, 2019 at 1:14 PM
    #1382
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I may have to because I need to bend, or cut the tail-pipe so it will clear my lowered rear end.
    I have it on stand by... it will be the last thing I add - if needed.
    Rica25[QUOTED] likes this.
  3. Oct 23, 2019 at 1:33 PM
    #1383
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    Do you reuse the stock gasket on the end top the y’all pipe? Or leave off?
    Rica25 likes this.
  4. Oct 23, 2019 at 1:36 PM
    #1384
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    You should have gotten a new one from DD. If yours is in great shape you can reuse it. Mine was disintegrated
    Rica25 likes this.
  5. Oct 23, 2019 at 2:05 PM
    #1385
    danno266
    danno266 n00b
    2016 White CM SR5/TRD OR
    Where was said gasket, taped to the packet holding the U-bolts?
    Rica25 likes this.
  6. Oct 23, 2019 at 2:08 PM
    #1386
    paradizecityz
    Richmond, TX
    Yup. I found it. Thanks!
    Having some issues with putting tail pipe and exhaust together
    Rica25 likes this.
  7. Oct 23, 2019 at 2:12 PM
    #1387
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Put the tailpipe in hanger and twist it until it lines up
    Rica25 likes this.
  8. Oct 23, 2019 at 2:26 PM
    #1388
    paradizecityz
    Richmond, TX
    Just finished. Took me about an hour and half and man I’m tired. Did not do the resonator. Wanted to try without first but man...that first startup!!! :yes::yes::yes:
    GODZILLA, Rica25 and omgboost like this.
  9. Oct 23, 2019 at 2:28 PM
    #1389
    Openroad98
    Openroad98 New Member
    Abraham
    Loveland, CO
    2019 Cavalry Blue SR5 TRD
    Stock for now...
    Agreed. I installed the whole system, marked the tail pipe, then removed and cut the hole using a 2" Milwaukee Hole Hawg from Home Depot. All I added was a good pilot drill with tip designed for stainless. Keep your drill lower speed and use a little oil if needed on the teeth. Cut through like butter. Just make sure to NOT install the resonator before mounting the tail pipe, and keep it close to the spare tire (but not touching) and pointed up slightly to prevent water accumulating in the resonator and rusting it out.
  10. Oct 23, 2019 at 3:07 PM
    #1390
    Rex Kramer
    Georgia
    All that remains to install is the resonator... I'm about to take it on it's maiden voyage.
    Magnetic15, Rica25 and paradizecityz like this.
  11. Oct 23, 2019 at 3:59 PM
    #1391
    Lightning_Lad
    Lightning_Lad New Member
    Tom
    Orange CA
    2017 Silver Sky Platinum Pro
    Line x Bed liner Trifold Tonneau cover TRD PRO Dual exhaust TRD PRO sway bar TRD PRO air intake TRD PRO suspension TRD PRO LED 2019 Headlight conversion TRD 2020 Wireless charging tray TRD shift knob TRD PRO Grille TRD red anodized dust caps (+25 hp per wheel) Matt black mirror caps and door handles Tesla style Headunit KTJO 4x4 tail gate pop n lock upgrade Driver side grab handle Viper Remote start Viper alarm system 18” Method NV’s 33.5” Toyo R/T ESP Long box underseat storage 3M ceramic tint
    My box arrived Monday.
    Gonna install this weekend !
    Rica25 likes this.
  12. Oct 23, 2019 at 4:04 PM
    #1392
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The resonator install is a lot easier than it seems. It’s so worth it to install the resonator
    AZBoatHauler and Rica25 like this.
  13. Oct 23, 2019 at 5:19 PM
    #1393
    Stocky Balboa
    Stocky Balboa New Member
    OC , CA
    2018 Limited TRD 4x4 CM - Cement
    Minor stuff- Tint, rear sway bar , pedal commander, TRD drop in filter DD Exhaust, Bilstein 6112/5160, stealth 32” lightbar, Cali Raised Offroad fog light replacements.
    Yo @dirtydeeds , any updates on where we are at on the list?
    Thank you
    Rica25 likes this.
  14. Oct 23, 2019 at 8:33 PM
    #1394
    roy2015
    roy2015 Waterproof
    Houston
    Super White = Super Fast
    Does the 8 dump sound different than the 8?
    Rica25 likes this.
  15. Oct 24, 2019 at 5:32 AM
    #1395
    prerunnerseth
    prerunnerseth New Member
    Apex, NC
    2015 MGM Limited 4x4
    Hopefully mine will ship tomorrow, but I did get my sounds system upgrades in and enjoying the heck out of it before i have to turn it down for a while to listen to my new exhaust.
    Stocky Balboa, Bama and Rica25 like this.
  16. Oct 24, 2019 at 8:52 AM
    #1396
    Stocky Balboa
    OC , CA
    Congrats on a new system :headbang: Keep us updated on your shipping notification. I’ve tried to contact Keith for an update but no dice yet. I’m sure he’s busy.
    Rica25 likes this.
  17. Oct 24, 2019 at 9:05 AM
    #1397
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    Installed everything. Dropped the spare and did the resonator with tailpipe in-place. Using a 2" hole saw worked great. Loving the sound and no low end torque loss. Pulls nice at 4k-6k.
    Rica25, paradizecityz and Rex Kramer like this.
  18. Oct 24, 2019 at 9:06 AM
    #1398
    Rex Kramer
    Georgia
    The sound is intoxicating...
  19. Oct 24, 2019 at 9:28 AM
    #1399
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    So is it safe to say, you are love it?
    Rica25 and Rex Kramer[QUOTED] like this.
  20. Oct 24, 2019 at 9:48 AM
    #1400
    paradizecityz
    Richmond, TX
    How long did it take you to do the resonator part?
    Will something like this be able to do the cut?
    https://www.amazon.com/Rannb-Cuttin...1_1?keywords=rannb+53mm&qid=1571935665&sr=8-1
    Rica25 likes this.
  21. Oct 24, 2019 at 10:36 AM
    #1401
    Rex Kramer
    Georgia
    So far - so good, but I have not done any Interstate driving yet. I also haven't done any acceleration test from a dead stop yet, I am allowing the DAP tune to adjust to the change before performing that test.
    Rica25 and Larmand[QUOTED] like this.
  22. Oct 24, 2019 at 11:20 AM
    #1402
    gonefishing
    gonefishing New Member
    North Texas
    2018 Black TRD Sport Crew Max 4x4
    paradizecityz[QUOTED] likes this.
  23. Oct 24, 2019 at 1:26 PM
    #1403
    BeachyTundra
    BeachyTundra New Member
    Brandon
    Spokane
    2017 MGM 5.7L DC, Bilstein 5100s
    Guess who has a big ole box sitting in his garage....:D
    Rica25, Angry Gunny and Bama like this.
  24. Oct 24, 2019 at 1:55 PM
    #1404
    Gilby1
    Gilby1 New Member
    David
    ‘16 Blazing Blue Platinum - SOLD, '20 Super White Platinum
    Well, I haven’t received my exhaust yet.
    Nor, for that matter, notice that it’s been shipped or even made yet.
    Buuuuut...
    Look what did show up!
  25. Oct 24, 2019 at 3:20 PM
    #1405
    Kylerasanen
    Kylerasanen New Member
    Looks like I'll be cutting the flange bolts off
    Rica25 likes this.
  26. Oct 24, 2019 at 4:59 PM
    #1406
    Kylerasanen
    Anybody know what I should do for flange repair?
    Rica25 likes this.
  27. Oct 25, 2019 at 4:36 AM
    #1407
    prerunnerseth
    Apex, NC
    It's shipping day!!!!
    Bama, Rica25 and GODZILLA like this.
  28. Oct 25, 2019 at 7:56 AM
    #1408
    Tundradrenalin
    Virginia Beach, VA
    about an hour: mocking up the resi, chalking the pipe, dropping the tire, realign the resi and re-chalk, drill the pilot hole, drill the hole saw slowly, mount the resi with the U-bolts, reinstall the spare tire.
    I presume most 2" hole saws will do the work. I have a Milwaukee ice set or whatever. Just go slow to not break your wrists when it catches.
    paradizecityz[QUOTED] and Rica25 like this.
  29. Oct 25, 2019 at 7:58 AM
    #1409
    Tundradrenalin
    Virginia Beach, VA
    I had to cut my bolts off my 1Gen a long time ago, rusted to hell. Angle grinder to the flange side with the nut, once that's off, the flange will pop open and you're free. I then used a few stainless 3/8"-16 hex bolts, washers, and nuts to close it back up. Nothing fancy welded on, just a bolt & nut.
    Rica25 likes this.
  30. Oct 25, 2019 at 8:18 AM
    #1410
    Civiceg94
    Civiceg94 New Member
    NYC
    2007 Toyota Tundra Crewmax 5.7 Limited
    Horn baffle delete Fox 2.5 DSC Setup DAP TUNED RW WHEELS 285/75/17 AT3 LTX
    I had my flange break apart. So i welded new ones in place of it and i still had leaks. Bought new flange gasket still leaks i got fed up and put red rtv all over for now.
Thread Status:
