Disable TPMS - I am fed up with the dashlight
Discussion in 'Wheels & Tires' started by TRXTER, Mar 23, 2022.
  1. Nov 12, 2022 at 3:28 PM
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    yup i used the 2 side by side .checked 10x to be sure
  2. Nov 12, 2022 at 3:37 PM
    TRXTER
    TRXTER [OP] New Member
    Allan
    Ontario, Canada
    2015 5.7L Silver Sky Metallic Tundra 1794
    Just getting started.... Start X remote starter.
    All I can think is that it's not punctured with the pin on positap or wire got bunched up on the end where it goes in. I am attaching a sketch, I did 2 positaps, 1 into L green, 1 into yellow. Then used a piece of wire in between. I have fat fingers and arthritis and had trouble getting the L green end in good. What I actually did the piece of wire between the 2 positaps is a bit heavier guage. But I carefully fit the wire in before hand and got it molded I to each end good and carefully took apart then tapped the yellow, then tap light green then gently fit the jumper in between. Just have to remember to put the end pieces on the jumper. Jez man I feel for ya. I hope this works.
  3. Nov 12, 2022 at 3:39 PM
    Rob's Inferno
    Thanks.Maybe ill try that way with 2 taps and see if i can make it work .Out of patience at the moment
  4. Nov 12, 2022 at 3:43 PM
    TRXTER
    Allan
    Ontario, Canada
    I know it's so small of wire. Can you see if it actually poked it. I found holding wire tight and then piercing so it doesn't bunch up. I know easier said than done !!!
  5. Nov 12, 2022 at 3:48 PM
    TRXTER
    Allan
    Ontario, Canada
    Also you will see in my pic fan the copper strands out a bit for when they go into connector they go evenly around the connection point.
  6. Nov 12, 2022 at 4:24 PM
    Rob's Inferno
    Just went out and hooked it up with the small jumper and 2 posi taps .still flashing light . Yellow wire is going to break soon if i keep taping it anymore it looks.
  7. Nov 12, 2022 at 4:47 PM
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
    I think the wiring changed for the 2018+ tundras. Maybe @Jeff_5_7 knows for sure
  8. Nov 12, 2022 at 4:48 PM
    TRXTER
    Allan
    Ontario, Canada
    Hmmm, sorry this isn't working for you. I am stumped as to why it's not going out. I am out of ideas, maybe some others may add.some comments. All I can think is.mayne.the yellow.wire.doesnt.have.5V when vehicle is running. If you happen to tap the yellow again, put a volt meter on it to see if it has.voltage.
  9. Nov 12, 2022 at 4:50 PM
    TRXTER
    Allan
    Ontario, Canada
    Yes in 18 it did, but this one is a 17..... unless it got the 18 wiring at the switch over. Not sure.
  10. Nov 12, 2022 at 5:01 PM
    TRXTER
    Allan
    Ontario, Canada
    Please forgive this question..... after you tapped it, you plugged the harness back into the the module where it came from. I know it's a given,.but I have to ask
  11. Nov 12, 2022 at 5:03 PM
    Rob's Inferno
    Yes sir.
  12. Nov 12, 2022 at 5:03 PM
    Musicmasterd12
    Southern Louisiana
    Looks like the wiring is different
    do you have 2 pink wires instead of 2 yellows?
    2015
    2017
  13. Nov 12, 2022 at 5:06 PM
    Rob's Inferno
    i have 2 PINKS and 1 YELLOW
  14. Nov 12, 2022 at 5:06 PM
    TRXTER
    Allan
    Ontario, Canada
    Okay, I thought back to 2 weeks ago when I changed a buddies headlight switch on a hyundai velocter cause he only had high beams and low beams....... after the repair it was no better. Hmmmm both bulbs had the low beams burnt out. What are the odds
  15. Nov 12, 2022 at 5:06 PM
    Musicmasterd12
    Southern Louisiana
    Try green wire to pink wire in spot 12
  16. Nov 12, 2022 at 5:07 PM
    TRXTER
    Allan
    Ontario, Canada
    Sorry, only high beams NO low beams
  17. Nov 12, 2022 at 5:09 PM
    Rob's Inferno
    ok ill give that a try tomorrow
  18. Nov 12, 2022 at 5:11 PM
    Rob's Inferno
  19. Nov 12, 2022 at 5:15 PM
    #49
    TRXTER
    Allan
    Ontario, Canada
    Shit..... I do now remember reading that somewhere back in the long chain of posts..... I would try that before random.wire hook ups.
  20. Nov 12, 2022 at 5:15 PM
    #50
    Musicmasterd12
    Southern Louisiana
    I was def looking at the diagram wrong. The 2017 does have some different color wires, but the yellow is still 5v so it should be pin 5 to 6
  21. Nov 12, 2022 at 5:30 PM
    #51
    TRXTER
    Allan
    Ontario, Canada
    This is so weird..... light green/minty green needs 5V of power to trick the system to turn off light. The yellow wire has 5V..... so why is it.not working for him....
  22. Nov 12, 2022 at 5:34 PM
    #52
    Rob's Inferno
    my connector
  23. Nov 12, 2022 at 5:37 PM
    #53
    TRXTER
    Allan
    Ontario, Canada
    Is the positap damaged ???? Like the little pin that pokes the wire....is.it.bent, broke, missing... we are missing something obvious here. It shouldn't be this hard. So many have had success with this....
  24. Nov 12, 2022 at 5:38 PM
    #54
    Rob's Inferno
    both brand new taps.no way they can be damaged with that tiny wire. im at a loss
  25. Nov 12, 2022 at 6:12 PM
    #55
    TRXTER
    Allan
    Ontario, Canada
    Disconnect battery, do the tap, reconnect battery, start truck ????? F.me. I dont have a clue but I wanna solve this. Keep.us posted.
  26. Nov 13, 2022 at 10:47 AM
    #56
    Rob's Inferno
    Well after going back in with a volt meter and checking all connections for 12v ,i found zero at green wire.So with the sun out and being able to see way better,the pin wasnt poking thru the plastic into the copper it seems,so i stripped some off to expose some copper and reattached the posi tap on that spot and it worked. I guess that wire being such a tiny gauge,that the pin just didnt pierce thru all the way.Also i took glove box out and airbag and it makes it WAYYYY easier to see and work on.So anyone that cant fit or get under ,just take 5 mins and remove those pieces and make it a less frustrating job.View with glovebox and airbag removed .THANKS again to all of you who helped me out much appreciated .:thumbsup:DASH.jpg GOOD riddance damn orange light
    Jeff_5_7 and Musicmasterd12 like this.
  27. Nov 13, 2022 at 11:46 AM
    #57
    TRXTER
    Allan
    Ontario, Canada
    Hey that's awesome, yep those little pins sometimes don't pierce the wire, especially 22ga. Enjoy the no light on the dash !!! Glad you solved it. Cheers and Beers !!!!
    Rob's Inferno[QUOTED] likes this.
  28. Nov 13, 2022 at 12:30 PM
    #58
    Rob's Inferno
    Thanks again for the help.
  29. Mar 9, 2024 at 10:55 AM
    #59
    escknx
    escknx New Member
    Eugene
    2018 Tundra SR5
    It definitely changed in 2018. I have no 12 pin connector at all. I wonder if there's an info on how to disable it in 2018+
  30. Mar 9, 2024 at 12:31 PM
    #60
    TRXTER
    Allan
    Ontario, Canada
    Yes, it did change and I have yet to find anyone who did find it. I guess you could go 2
    Different ways that some others have done with success. Pull the 4 tpms sensors and toss inside the spare tire loose, not the best especially if yiu need to use it. Create a sealed pipe cannister (PVC) with a air valve on it , place the tpms sensors inside glue shut, and air it up to proper psi and just leave it in the truck under the seat. I feel for you that light is ANNOYING as hell. Or just good old black tape on the dash screen. I wish I could be more help. Good luck !!!
    escknx[QUOTED] likes this.
