DIY: Fog Light Mod
Discussion in '2nd Gen Tundras (2007-2013)' started by csuviper, Mar 13, 2014.
  1. Oct 31, 2016 at 8:54 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    No issues on '16 after the anytime mod. I also deleted the factory amber drl.
  2. Oct 31, 2016 at 6:07 PM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    Hmm. Well I'll get back to it tomorrow during the day. Must be user error.
  3. Nov 1, 2016 at 9:01 AM
    Bear
    Bear
    Custer, SD
    Ok. So my connector has 2 pink wires.
    See pic. #1 is where I originally spliced. That "worked" except I could not independently turn off the fogs and there is a little byproduct of the lights come by on by themselves after 21 min. This that have done this...is it the OTHER pink wire? (#2)?
  4. Nov 1, 2016 at 9:14 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I think you want grey wire. But don't take my work for it. Here's what someone else wrote up and that I followed. thttp://tundrageeks.com/forum/showthread.php?t=9760he
  5. Nov 1, 2016 at 9:23 AM
    Bear
    Bear
    Custer, SD
    Nope. This is definitely pink wire territory. Lol. Only problem wth the original write up is nonpic if the no kidding pink wire...and apparently I have 2. Bah!!! Well it's back to stock now.
  6. Nov 1, 2016 at 9:51 AM
    PR_02
    PR_02 New Member
    Paul
    Wauconda, WA
    2016 CrewMax Platinum
    I believe #2 is the wire you want... I am color blind(pink=gray)lol. However the write up I followed said it was 3rd wire up from the bottom left... as you look at it plugged in. Not sure if you wanna give it another go, but you had it half right...fogs were coming on, I imagine that pink wire has something to do with something else the truck turns on after it's been off for a while... anti theft maybe? Either way, use the gray wire 3rd up from bottom left and you'll be solid.
  7. Nov 1, 2016 at 10:26 AM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Only Pics from when i did it:
  8. Nov 1, 2016 at 12:20 PM
    Bear
    Bear
    Custer, SD
    Csuviper, do you have a pic of the "other" connector? The one up on the ECU
  9. Nov 1, 2016 at 1:05 PM
    csuviper
    Broomfield, CO
    No, sorry
  10. Nov 1, 2016 at 5:05 PM
    PR_02
    PR_02 New Member
    Paul
    Wauconda, WA
    Bear, sorry in your pic it look like the #2 was pointing to the gray in front, but I see the you are pointing to the pink in the back. In your pic the gray wire on the bottom left, third from the bottom is the wire you want. It's the wire I used anyway. Hope that helps.
  11. Nov 11, 2016 at 8:03 AM
    Bear
    Bear
    Custer, SD
    Ok. For clarification's sake for the 2016 guys...
    The 2014 write up in original post is correct! However, it wasn't very clear, photographically, as to which pink wire in the ECU connector, was the correct wire. It's pin #28...This is the connector that is under the dash panels, NOT the connector under the kick panel. IMG_3145.jpg I've drawn a green arrow to the correct wire. Many thanks to the members that took time out of their day to provide me the specific info! Great site!!
  12. Nov 11, 2016 at 8:07 AM
    TTU19
    TTU19 Wreck 'Em
    Wes
    Tx
    2021 TRD Sport
    I need to go back and re-read this thread, ha. Having the fogs on sounds like a good thing to me. So it's just cut and splice a couple wires. Sounds easy enough.
  13. Nov 19, 2016 at 7:42 AM
    Oper8r
    Oper8r New Member
    Stuttgart
    Sold my 2016 TRD PRO - Currently in BMW 535d Wagon
    I just switched out my fogs for Baja designs. Now I feel they will work better in fog or snow without the headlights (because the fogs are wrapped in amber laminix).
    Is this the reason everyone else is doing this mod?
  14. Nov 22, 2016 at 9:51 PM
    swede78
    swede78 Not so new member
    Lars
    westminster co
    2019 tundra platinum mgm crew max
    Nothing yet
    i have a 08 sr5 that did not have fogs on it. i bought a pair off craigs list but for some reason they cut the plug off the back. any way i just wired them to the battery and spliced into the drl wire by the headlight. drl on=fogs off, park lights on = fog lights on, headlights on low beam=fogs on, headlights on high beam=fog lights on. i need to wire them up correctly to the factory harness, but need to get the fog light relay, push button switch and find the plug under the dash for the switch
  15. Nov 22, 2016 at 11:23 PM
    swede78
    Lars
    westminster co
    Nothing yet
    i should rephrase this comment, i spliced into the parking light wire not the drl wire. on the harness that goes to the drl,turn signal,park light, i think it was the purple wire
  16. Dec 26, 2016 at 5:06 PM
    FumundaTundra
    FumundaTundra Director of civil unrest
    Wayne
    Central WA.
    2009 5.7 Tundra Double cab
    Many to come.
    Prolly gonna do this mod. tomorrow.
  17. Jan 2, 2017 at 7:50 AM
    MrTipps
    MrTipps New Member
    Joe
    2016 Tundra Double Cab
    I found the pink wire under the dash with no problem, but I can't find the gray wire where the Kick Panel is. Where it should be is a White Wire and that does not work. I tried it and all sorts of dash lights came on... so that's not it. Any help from the 2016 guys that got this working??
    Thanks
  18. Apr 20, 2017 at 10:02 PM
    GnSnwb
    GnSnwb New Member
    2011 Tundra Rockwarrior
    Just did FogLightsEddieV1 on my 2011 Tundra TRD rockwarrior. Works perfectly!
    Thanks for the info!
    Bear likes this.
  19. May 19, 2017 at 1:07 PM
    #49
    1BadTundra
    1BadTundra New Member
    Clinton
    2010 TRD Rock Warrior Crewmax
    Too Much to List
    Which one is this?
  20. May 19, 2017 at 4:34 PM
    #50
    GnSnwb
    GnSnwb New Member
    It is one of the two mods listed at the top of the thread. There are additional pictures on the second page of the thread to help decifier which wires you need to splice together. All together, took about 20-30 minutes to complete.
    AbunaiTaco likes this.
  21. Oct 26, 2017 at 3:31 PM
    #51
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    does this work for a 2017 ?? interested in doing this
  22. Oct 26, 2017 at 5:40 PM
    #52
    1BadTundra
    Clinton
    Too Much to List
    I did it this weekend, awesome. Took all of about an hour, from getting up and putting my shoes on,to getting my fat ass back in the house and cleaned up.
  23. Oct 27, 2017 at 11:35 AM
    #53
    GnSnwb
    GnSnwb New Member
    I wouldn't think that this would work for models beyound 2013, but I could be wrong. I'd definitely do more research for your model year before cutting into anything. Best of luck friend.
  24. Oct 28, 2017 at 9:45 PM
    #54
    Justincase7007
    Justincase7007 New Member
    2015 Tundra xp SR5
    What are the 2 wires going to my fog lights on my 2015 Toyota Tundra? Can i tap into these to power new 12v accessory fog lights?
  25. Nov 9, 2017 at 5:23 PM
    #55
    Tomcat
    Tomcat Ever see a motorcycle outside a shrinks office?
    2010 SR5 4X4 5.7 20" wheels Metallic Gray
    Bakflip
  26. Nov 9, 2017 at 7:50 PM
    #56
    fisherman951
    Tony
    2017 crewmax 4x4
    Hmm any1 try this?
  27. Nov 9, 2017 at 8:07 PM
    #57
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Lots! I done it on my 16. Works like a charm.
  28. Nov 9, 2017 at 9:00 PM
    #58
    fisherman951
    Tony
    2017 crewmax 4x4
    I see 2 pdfs. Wich 1 did u use?
  29. Dec 15, 2017 at 9:08 AM
    #59
    myk1013
    myk1013 New Member
    Myk
    2017 CM * MGM * TRD
    I see the PDF is for earlier model Tundras. Will this work as well for a 2017? Are the wires to connect all in the same locations and same colors as the PDF?
  30. Dec 15, 2017 at 9:12 AM
    #60
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2019 SC TRD Pro CM 040 2020 Sequoia TRD Pro 040
    It'll work just fine. Just keep in mind there are 2 gray wires. Don't snip the wrong gray wire. I just did this mod last weekend. Works like a charm.
    myk1013[QUOTED] likes this.
