DIY: Footwell LED install
Discussion in 'Lighting' started by csuviper, May 19, 2015.
  1. Nov 2, 2016 at 7:00 PM
    TheBeast The Beach
    duh, the strip got disconnected from the socket..back to your regular schedule
  2. Nov 2, 2016 at 7:58 PM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  3. Nov 2, 2016 at 7:59 PM
    TheBeast The Beach
  4. Nov 2, 2016 at 9:52 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Didn't see a thing......
  5. Dec 2, 2016 at 3:02 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Let me ask a lame question. I have a '16 CM limited edition and I don't have any lights on my driver side footwell. Maybe a burned out bulb or do the limited's not come with footwell lighting?
  6. Dec 2, 2016 at 3:06 PM
    TheBeast The Beach
    you should have one. probably a burned out bulb.
  7. Dec 2, 2016 at 3:07 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
  8. Dec 2, 2016 at 3:09 PM
    TheBeast The Beach
    @TruckinIt vleds.com sells a kit already made. Easy install and looks great. You can do front and rear too. Very nice feature especially at night.
    040Tundra likes this.
  9. Dec 2, 2016 at 3:33 PM
    bsavoir
    bsavoir New Member
    Killeen, TX
    2016 Tundra Limited CM 4x4
    Gibson Metal Mulisha Exhaust, Replaced bulbs w/ LED's, AFe intake, Bullydog Tuner, Aftermarket Audio system, Rhino Bed Light sports bar, Tonneau Cover, Spyder Auto Headlights and Taillights, Recon 3rd Brake Light, Kensun HID's, Fender Flares, Custom Leather Interior, Heated Seats, 5% Tint on the Rear Windows, Pod light Foglights, 31" light bar behind the grille, linex spray bedliner, linex sprayed grille, ditch lights w/ dual 3in LED pods, 60" Tailgate LED strip.
    I have them in the footwell and under the driver and passenger seats with Velcro. I have white when the doors are opened and blue lights while driving. The blue lights are hooked up to a dimmer switch and had them hooked up for about a 2 years issues or no glare on the windows. These strips work good for those that don't have a soldering tool and fit perfectly under the seats and the footwells. Amazon has 4 30cm (11.8in) strips ($7 with free prime shipping) I also used 3M double sided tape ($6) and 18 or 20 AWG ($12).
  10. Dec 2, 2016 at 4:03 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Sweet!! Do you happen to have any pics at night with in the cab and from outside the cab with the doors open?
  11. Dec 2, 2016 at 4:08 PM
    bsavoir
    bsavoir New Member
    Killeen, TX
    I'll get some tonight
  12. Dec 3, 2016 at 7:44 PM
    tommyhus
    tommyhus New Member
    Thomas
    2012 Tundra
    I second the VLED kit. Looks great, and couldn't be easier to install. you can daisy chain them off of the outlet under the driver side.
    TheBeast likes this.
  13. Dec 4, 2016 at 11:41 AM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Thanks for the heads up brother. I'll check vleds.com out for the kit. My only question is do you just pull out the factory drivers side light from the back of the panel, unplug it and plug in the vleds.com kit?
  14. Dec 4, 2016 at 12:20 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Thanks @csuviper for your awesome write up! (nice pics too) Just placed an order on Amazon for all the material to do this sweet little project.
    csuviper[QUOTED][OP] likes this.
  15. Dec 4, 2016 at 1:34 PM
    TheBeast The Beach
    just replace factory bulb with vleds adapter. Very easy to do. If it doesn't lit up, switch side (polarity)
    @TruckinIt
  16. Dec 5, 2016 at 6:30 PM
    geno0506
    geno0506 New Member
    Michael
    Thanks for the great info,
    So the pic you show is that the OEM bulb and blue and white OEM wires that show the whole the footwell pull that popped out of the lower console.
    So I just splice into the blue and white wire with a red and black wire!
    Also would I splice it the same in the diagram if I buy the kit from
    http://www.vleds.com/all-products/universal-diy/rigid-bar/fwk-bar.html
    Also if I go your route could I even run some led steps you mention,
    https://www.amazon.com/dp/B00F01VRLU/ref=cm_sw_r_cp_api_WiAyxbJH487ED
    out to the right and left N-fab steps and would I just tie that to into the OEM blue and white footwell wires?
    Thanks
  17. Dec 7, 2016 at 3:37 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
  18. Dec 7, 2016 at 3:51 PM
    csuviper
    Broomfield, CO
    Awesome!
  19. Dec 7, 2016 at 3:58 PM
    #49
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I found it. It was such a freakin small a$$ bulb I didn't even see it.
    TheBeast[QUOTED] likes this.
  20. Dec 7, 2016 at 4:03 PM
    #50
    csuviper
    Broomfield, CO
    Supposedly the kit comes with a connector to where the bulb pulls out. If this kit is not the one that fits there then yes you will splice the wires in how i have shown them. Test the wires before you make it permanent to make sure you don't have to reverse.
    You can connect to these two wires and run them for lights on the steps.
    geno0506[QUOTED] likes this.
  21. Dec 7, 2016 at 8:37 PM
    #51
    MotoTundra
    MotoTundra The Ocho
    Don
    I know this is a bit belated, but nice write up!
  22. Dec 7, 2016 at 8:51 PM
    #52
    geno0506
    geno0506 New Member
    Michael
    So if I run the same wire to right and left N-fab steps, they will turn on and off automatically when door opened and closed, thanks
    Thanks for the response!
  23. Dec 7, 2016 at 9:44 PM
    #53
    csuviper
    Broomfield, CO
    Yes
  24. Dec 7, 2016 at 10:12 PM
    #54
    geno0506
    geno0506 New Member
    Michael
    You Da Man!
  25. Dec 7, 2016 at 11:05 PM
    #55
    geno0506
    geno0506 New Member
    Michael
    Sorry for dumb question,
    so would the 6000k mean its the brightest over the 4-5 K's~
  26. Dec 8, 2016 at 2:26 PM
    #56
    csuviper
    Broomfield, CO
    Not the brightest no. It is a color temp in the light spectrum. As Ron shows above the whitest white is actually 5000K. The 6000K has a slight blue tint to it.
    K = Kelvin = the SI base unit of thermodynamic temperature, equal in magnitude to the degree Celsius.
    Beesta and geno0506[QUOTED] like this.
  27. Dec 8, 2016 at 5:11 PM
    #57
    geno0506
    geno0506 New Member
    Michael
  28. Dec 8, 2016 at 10:50 PM
    #58
    geno0506
    geno0506 New Member
    Michael
    WOW, Thanks!
  29. Dec 9, 2016 at 8:09 PM
    #59
    Ericsopa
    Ericsopa Old man and the sea
    Well dang.....my '13 CM Ltd doesn't have any footwell lights. That's surprising. I'll be looking for the wiring, though. It should be there up under the dash somewhere.
  30. Dec 10, 2016 at 10:00 AM
    #60
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Are you sure there's no light under the driver's side footwell? That's what I thought about my '16 until I found it not under the footwell but where my left knee goes when driving the truck.
