Does this truck use blinker fluid?
Discussion in '3rd Gen Tundras (2022+)' started by TundraDan723, Aug 27, 2023.
  1. Dec 6, 2023 at 1:28 PM
    DRP
    DRP Old Member
    Dave
    LOL. Next time you see that kid tell him you need a water pump for a '65 Volkswagen beetle.
  2. Dec 6, 2023 at 2:36 PM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    My past f150 you couldn't fill the bottle full because once you used it the front camera sprayer would siphon the bottle down below half. STUPID FORD
    This was the norm at the dealership after service. * example pic* so maybe the emblem was crying lol
  3. Dec 6, 2023 at 2:42 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    There’s a rubber grommet that seals the fill neck to the main reservoir. Most likely everyone’s leak issue it the washer fluid slowly seeping past that grommet. Because it isn’t a very tight fit whatsoever.
  4. Dec 6, 2023 at 2:45 PM
    Sunnier
    Sunny
    San Diego, CA
    Are you friends with George Clooney?
    Seriously, I expected more entertainment from a thread with 'blinker fluid' in the title. Page 2, let's go!
    bulldog93 likes this.
  5. Dec 6, 2023 at 2:59 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    I put up with this on another vehicle for years. Replaced the pump and grommet and fixed it.
  6. Dec 6, 2023 at 3:00 PM
    bfunke
    South Carolina
    Check grommets at neck, pump and level sensor.
  7. Dec 6, 2023 at 6:26 PM
    smileytn1
    smileytn1 New Member
    replace the muffler bearing while you are at it ..
  8. Dec 6, 2023 at 6:53 PM
    TundraDan723
    TundraDan723 [OP] Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    This is my experience. I can only get enough fluid in to fill the neck and it won’t take any more. They a few days later it’s gone and I can fill the neck up again. There is ZERO fluid leaking out of the truck. No evidence in the engine bay and nothing on the floor of my garage.
    This is why I swear a hidden feature of this truck, with it’s progressive blinkers, actually uses blinker fluid.
  9. Dec 6, 2023 at 7:44 PM
    luwig
    luwig New Member
    For what it's worth, I use my washer quite often and also uses the exact same RainX fluid you use. When the truck indicates that the wiper fluid is lower, I am able to dump an entire bottle in there and it comes up just to the bottom of the neck.
  10. Dec 6, 2023 at 7:50 PM
  11. Dec 6, 2023 at 7:51 PM
  12. Dec 6, 2023 at 9:53 PM
    mass-hole
    mass-hole New Member
    My F150 washer fluid was always empty. Always. It became a joke to my wife because every time I would try to use it nothing would spray.
    Turned out there was a slow leak where the pump attached to the tank. It was slow enough that it would drip onto the wheel well liner and evaporate before ever hitting the ground.
  13. Dec 7, 2023 at 4:55 AM
    Soupbean77
    Soupbean77 New Member
    2023 Mag Grey Tundra Limited Crewmax 4x4
    Don’t forget the spark plugs for your Tesla….
    Piki likes this.
  14. Dec 7, 2023 at 6:00 AM
    pwpblue
    Greensburg,PA
    Wiper blade for the sun roof!
    mayan and SWB Tundra like this.
  15. Dec 7, 2023 at 11:20 AM
    DRP
    DRP Old Member
    Dave
    OK. I'm going to stick with the air bubble theory on this. I've topped off the tank 3 times now without using the washer. Each time I've poured less fluid in than the time before and this last time the level was still up in the neck where I could see it. I even crawled under the truck and see no evidence of a leak. I'm sure it's a possibility the fluid is getting past the grommet but doesn't seem likely in my case. Hope this helps.
    TundraDan723[OP] likes this.
  16. Dec 7, 2023 at 11:46 AM
    pwpblue
    Greensburg,PA
    Prob a expansion void Incase of freezing.
  17. Dec 7, 2023 at 1:08 PM
    Adventurer
    Adventurer New Member
    2023 1794 TRD 6.5 Celestial Siver
    Does level drop if it isn't driven? Reason I ask is I had a Ford Lightning that would dribble fluid out nozzles on acceleration, much like an uncle with prostate issues.
    Retired...finally likes this.
  18. Dec 7, 2023 at 1:38 PM
    DRP
    DRP Old Member
    Dave
    Mine only got lower after driving it which is why I think it's an air bubble at the top. If I fill it to the top and don't drive it, the level doesn't change.
  19. Dec 7, 2023 at 5:12 PM
    #49
    TundraDan723
    EXACTLY what happened to me!!!!!!!
  20. Dec 23, 2023 at 9:56 AM
    #50
    smileytn1
    While you're at it i need a muffler bearing that is out on mine!
  21. Dec 23, 2023 at 10:51 AM
    #51
    rx3
    rx3 New Member
    Is it possible to stick a coat hanger or something in there to break up a possible air bubble?
  22. Dec 23, 2023 at 10:57 AM
    #52
    pwpblue
    Greensburg,PA
    DRP, Retired...finally and Nm6300'asl like this.
  23. Dec 23, 2023 at 9:52 PM
    #53
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    Fan Pan gasket leak
  24. Dec 24, 2023 at 10:46 AM
    #54
    rx3
    rx3 New Member
    LOL! What is so WTF about what I said? If an air bubble is blocking the fluid when you're filling it, why not break up the air bubble to let you fill it all the way? I've done that before in other situations. What am I missing that is so "WTF"?
    pwpblue[QUOTED] likes this.
  25. Dec 24, 2023 at 11:16 AM
    #55
    DRP
    DRP Old Member
    Dave
    There was no air bubble blocking the ability to fill. What we noticed is that after it was "full", the level went down after driving but not using the washer. So the air bubble was in the top of the tank just waiting for us to think there was a leak but there isn't. Not sure you deserved a WTF but these threads can be brutal sometimes.
  26. Dec 24, 2023 at 11:20 AM
    #56
    rx3
    rx3 New Member
    Ah ok. I have thick skin, so I just laughed.
    pwpblue and DRP[QUOTED] like this.
  27. Dec 24, 2023 at 11:24 AM
    #57
    TheHansen
    TheHansen New Member
    19 MGM TRD off-road Limited
    Why do you need this reservoir filled to the top of the neck? If you don't use it, why are you checking and topping it up?
    As for finding leaks i recommend to take a rag and tear it into strips, tie them around possible leak points. the rag should end up wet where its leaking. In this case use a white rag it should end up with some color on it.
  28. Dec 24, 2023 at 11:24 AM
    #58
    GilFavor
    GilFavor New Member
    2023 silver tundra 1794
    Maybe run it all the way dry, fill it up with a known quantity, let it sit over night, and then run it dry again while capturing the fluid (that might be a challenge) and see what the volume difference is if any.
    Mattedfred likes this.
  29. Dec 24, 2023 at 11:40 AM
    #59
    pwpblue
    Greensburg,PA
    Jamming a coat hanger into the washer fluid bottle? First thing I thought of was Benny hill!
    Like that scab we all kept picking sometimes mom has to come over and slap your hand! Stop just stop it. So maybe a WTH not a WTF.
    I was trying to be funny not a dick so I will say I'm sorry. Sometime we're taken the wrong way
  30. Dec 24, 2023 at 12:01 PM
    #60
    DRP
    DRP Old Member
    Dave
    Did you read the entire thread?
