Easy 5 min anytime fog light relay mod DIY
Discussion in 'Lighting' started by xtyfighterx, Jan 16, 2018.
  1. Feb 20, 2018 at 10:28 PM
    #91
    Is there anyway to do fogs on anytime WITH fog switch... WITHOUT having to turn on parking lights??? INCLUDING hi/lol beams??? I did there other fog mod that is listed on here all wiring done in the kick panel drivers side
  2. Feb 25, 2018 at 8:29 AM
    #92
    xtyfighterx
    xtyfighterx [OP] New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    I think only way found so far is wiring up a separate switch
  3. Feb 25, 2018 at 8:45 AM
    #93
    Thanks!
  4. Apr 5, 2018 at 12:43 PM
    #94
    lttmddj7
    lttmddj7 New Member
    Larry
    2016 Orange Plati Tundra
    6" Pro Comp Lift 35x12.5 Mickey Thompson Baja MT TRD Dual Exhaust Winjet LED Tails Morimoto Xb LED Fogs Lund LED Bull Bar Thule Roof Basket Fold A Cover Tri-fold bed cover all accessory lights LED Pedal Commander Throttle Controller
    I just did mine. Super easy. Glad I found this forum! I too live in VA, so I just bought a spare relay to swap out at inspection time.
    xtyfighterx[OP] likes this.
  5. Apr 5, 2018 at 12:55 PM
    #95
    design311
    design311 Smoke Eater
    Brad
    Bentonville, AR
    2018 Tundra Inferno TSS
    Are you saying that you need to ground the other leg on the bottom of the relay for a 2018 instead? The one I circled in red?
  6. Apr 5, 2018 at 4:37 PM
    #96
    epa4wd
    epa4wd New Member
    Ed
    Would have to open my relay box to confirm which leg, but yeah if you check each pin of the relay box for the fog light relay you’ll see that the 12V is always there. The relay coil needs to be grounded when we want the fog lights to come on. I connected it to the headlight relay coil ground. So both relay coils are grounded when the headlights turn on, therefore turning the fog lights on too.
  7. Apr 6, 2018 at 10:59 AM
    #97
    design311
    Brad
    Bentonville, AR
    Thanks for the reply. If you don't mind, a picture of how you did it would be great. Thanks!
  8. Apr 6, 2018 at 1:18 PM
    #98
    epa4wd
    epa4wd New Member
    Ed
    No problem, I’ll post one when I get a chance.
  9. Apr 10, 2018 at 7:37 AM
    #99
    design311
    Brad
    Bentonville, AR
    Thank you!
  10. Apr 16, 2018 at 7:48 PM
    #100
    maharaj1
    maharaj1 New Member
    Justin
    2014 Tundra 1794 2WD
    Just did this mod this part weekend took me all of ten minutes, most of which was spent looking for the proper spade and ring terminals. I did not put a manual toggle switch and simply hooked the relay up to a ground.
    Truck is a 2014 1794 Edition Tundra and for me it works like this.
    Light switch in off position - Fog lights off
    Light switch in parking light position - Fog lights on
    Light switch in low beam position - Fog lights on
    Light switch in low beam position with high beams on - Fog lights on
    Light switch in automatic with headlights off - Headlights & Fog lights off
    Light switch in automatic with headlights on - Headlights & Fog lights on
    This works well for me because I can have my fogs and parking lights on. Is there a way that I can have the fogs on in the automatic mode regardless of whether the low beams are activated? Basically want to have the fogs on at all times unless the switch is in the off position.
  11. May 7, 2018 at 7:21 AM
    #101
    harrydunn
    harrydunn New Member
    Columbia, MO
    Because I was inverted.
    Call it, Friendo.
    First mod I did for my truck when I picked it up last December. 5 minutes if you're handy with a wire crimper.
    NewImprovedRon likes this.
  12. Aug 3, 2018 at 5:25 PM
    #102
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Did this today and you're right it takes 5 minutes thanks to your detailed write up. Wish they came on with the LED DRL in Auto mode but this is good enough for me. I like having them on with high beams.
  13. Aug 3, 2018 at 7:37 PM
    #103
    Pudge
    CT
    I used the method in this thread, bend the tab on the relay and ground it. Did something similar on my Tacoma and it worked for 8 years with no issues. The Tacoma mod was nicer because it allowed use of the fog light switch and the if you had them on they would be on 100% of the time no matter what the selection of headlights was, on, off, auto, parking, even off, they were like DRL almost.
  14. Aug 4, 2018 at 6:22 AM
    #104
    Pudge
    CT
    Just when headlights are on and I think parking lights. So hi or low beam for sure. They do not come on with DRL
    Bassmonkey67 likes this.
  15. Aug 4, 2018 at 6:23 AM
    #105
    Bassmonkey67
    Bassmonkey67 New Member
    Lyman S.C.
    2013 crewmax 4X4
    I just did this and it works perfectly! I’m diggin it!
    xtyfighterx[OP] and Pudge like this.
  16. Aug 4, 2018 at 6:58 AM
    #106
    Pudge
    CT
    I've always disliked how the fog lights turn off when high beams are on. Cant see a good reason why. If there's other traffic they obviously get turned off. Plus high beams project so far, its nice to have some light in the foreground
  17. Aug 4, 2018 at 10:00 AM
    #107
    Pudge
    CT
    This is a super easy mod Ron. Takes maybe 5 minutes
  18. Aug 7, 2018 at 9:43 PM
    #108
    Challenger1
    Challenger1 Gramping
    Andy
    Southern California /Tustin
    Thanks Op! Went to the auto store and grabbed a Duralast relay.
    Saved one in glove box.
    Works like a charm!
    Took all of 3 min to install lol.
    Loving it!!
  19. Aug 14, 2018 at 7:38 PM
    #109
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Anyone know if it is possible for this mod to work in my 2017 sequoia? Coukdnt find any info on it when searching.
    TIA
    Pudge likes this.
  20. Sep 12, 2018 at 11:48 AM
    #110
    Challenger1
    Andy
    I assume it would be the same thing..
    locate the relay for fog lights and ground it out..
  21. Sep 12, 2018 at 11:59 AM
    #111
    BrandonL812
    Brandon
    It actually is the same. I took a dive and it works perfectly. Bought an extra relay just in case.
    Challenger1[QUOTED] likes this.
  22. Sep 16, 2018 at 11:29 AM
    #112
    Ikonrat
    Ikonrat New Member
    2018 MGM DC TRD OFF ROAD
    I too have 2018 and would love to see pics. I'm curious about exact leg you connected both on the fog relay and headlight relay. Also, what is the position of the headlight relay and what is it called on the diagram? I tried fog relay direct to ground and the fogs turned on permanently, not good. I also have a 12volt_solutions remote starter that might be causing this condition now. Hoping I can connect fog to headlight relay as the right mod for my setup.
    Thanks in advance!
  23. Sep 20, 2018 at 3:04 PM
    #113
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Well that was easy..took 5 mintues..thank you @xtyfighterx
  24. Oct 16, 2018 at 9:33 AM
    #114
    myk1013
    myk1013 New Member
    Myk
    2017 CM * MGM * TRD
    Finished product
    Thanks for this. This is exactly the look I'm going for. 2018 LED's with amber park lights and with fogs on.
  25. Oct 16, 2018 at 10:26 AM
    #115
    SouthWestGA
    SouthWestGA New Member
    What harness? Can you share?
    dead phish likes this.
  26. Oct 16, 2018 at 12:04 PM
    #116
    bfd300
    bfd300 New Member
    My relay is not in that location on my 19
  27. Oct 16, 2018 at 1:56 PM
    #117
    darkknight2014
    darkknight2014 Mods mods and more mods!!
    Phil
    New york
    2014 tundra sr5
    20" Cooper STT Pros on md rims, quadfire lights, pro grille, leather interior, navi, retrofitted headlights, blacked out chrome, TRD sway bar, hypertech interceptor, k&n air intake, Banks exhaust
    I ordered it a while ago to make my rigids pnp to the stock harness for the fogs. Ill try to look it up and send u the link
  28. Oct 28, 2018 at 4:40 AM
    #118
    ToyotaMan
    ToyotaMan New Member
  29. Oct 28, 2018 at 4:41 AM
    #119
    ToyotaMan
    will the fog lights turned on with the Auto mode headlight on? thanks
  30. Oct 30, 2018 at 6:12 PM
    #120
    phabej
    phabej New Member
    NO LONGER HAVE A TUNDRA... Waiting
    I can dig it, .. can you dig it?
