Elka owner long term feedback
Discussion in 'Suspension' started by Snowcat4360, May 3, 2020.
  1. Mar 11, 2021 at 7:50 PM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    That's good to know, I assumed they could get rebuilt when the times comes around.
    Another 3 years my truck would be past 400k I'd probably do a full suspension rebuild then I sorta am right now. At this point I'm gonna run this thing into the ground.
  2. Mar 11, 2021 at 7:58 PM
    Bustedandrusted
    Bustedandrusted New Member
    I would think the same. It’s not rocket science.
    BOBONTUESDAY[QUOTED] likes this.
  3. Mar 12, 2021 at 6:41 AM
    fishmando
    fishmando New Member
    I wouldn't say the bodies themselves die, it's the seals and valving that need to be rebuilt.
  4. Mar 12, 2021 at 7:24 AM
    Bustedandrusted
    Which would be the same as any steel bodied shock as well.
  5. Mar 14, 2021 at 3:07 AM
    abominable_tundra
    abominable_tundra New Member
    Elkasuspension 2-3” adjustable reservoir shocks, Icon RXT Leaf Pack, Coachbuilder +1 shackles, Camburg Racing Moog tubular upper control arms, Timbren industries Front/Rear off-road bump stops, method race wheels MR309 Grid +18, 295/70/18 Ridge Grapplers, Leer 100XL Canopy, Decked Drawer system, Diode Dynamics Stage Series 3 fog lights , sdhq Battery Terminals, @tundra452 ARB Compressor mount, scangauge, gorhino RB20 steps coated with linex, AFE power Drop in air filter, Bulletproof bumpers Kickback mudflaps, husky liners X-Act contour liners, bedrug Drop in liner
    I’ve been running Elkas since May 2019 with zero issues. I’m thinking it’s time for a rebuild this year as I have about 75000km on them now. I live in Alberta, we get salt and calcium chloride (which destroys everything) on our roads. The only corrosion I have is on the stainless fittings and chipped parts of the coil. The shock bodies are spotless. Disregard the rubbing on the reservoirs. I didn’t check the clearance with my winters... and with the stock offset I had some rubbing...
  6. Mar 14, 2021 at 6:34 AM
    Bustedandrusted
    That’s really positive feedback. Good to hear you’ve had that many kms without issue.
  7. Mar 17, 2021 at 6:01 PM
    COTundra23
    COTundra23 New Member
    Not too familiar with Elka but good to see positive feedback.
    do they require the same rebuilding after certain mileages like icon / kings?
  8. Mar 17, 2021 at 7:20 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    All coilovers will need a rebuild eventually and the Elkas are no exception. No specific mileage recommendations are given by Elka (that I know at least).
    However, Elkas have only been available for Tundras for about 3 years so data on time and mileage is still growing. Here in Alberta Canada there are lots of Tundras and Tacoma’s running them with generally very few rebuilds according to the local dealer. Last time I asked they mentioned one or two warranty replacements but that’s it.
    COTundra23[QUOTED] likes this.
  9. Mar 17, 2021 at 7:40 PM
    COTundra23
    Good to know. I'm torn between running something like OME / bilstein that is maintenance free.. I was quoted $2500 to rebuild my icons and that seems crazy to me given its half the price of the kit itself....
  10. Mar 17, 2021 at 7:57 PM
    abominable_tundra
    I second this. I spoke with a local dealer last week regarding rebuilds. The impression I got from them is I don't "need" a rebuild but it wouldn't be a bad idea as my mileage is getting up there on the shocks. I should really reach out to Elka to inquire what they recommend, but at this time I have no leaks or anything that would lead me to push to get them rebuilt. Just a feeling that preventative maintenance is better for the shock longevity.
    I believe the rebuild kits for both front/rear are about $400 CDN. Then you are looking at about a day give or take to pull the shocks, rebuild and reinstall. My understanding is because they corrode less, you don't have to overhaul as much.
  11. Oct 15, 2021 at 11:13 PM
    BCTRD
    BCTRD New Member
    B.C.
    2021 MGM Tundra TRD Sport
    18"BBS Forged wheels, factory running boards, VLED's, Rigid Pro Led mod (D2 SAE), diff breather mod, Husky mats, DIY Cquartz UK 3.0, Husky liners, OCD organizers,
    Considering Elka 2.5's. Did you go directly through Elka or a dealer for the best price?
  12. Oct 16, 2021 at 7:20 AM
    mountainpete
    When I bought there weren’t as many dealers so the choice was less. But I still recommend Krave in Calgary. Even the Elka website uses pics of trucks they build.
  13. Oct 16, 2021 at 9:11 AM
    BOBONTUESDAY
    2016 Limited Trd
    I bought mine from toytec it took a while for them to show up but they showed up and they're in I'm about 12 to 15 thousand miles on them.
  14. Oct 16, 2021 at 9:14 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    sweet. what corrosion protection are you running under there?
  15. Oct 17, 2021 at 10:04 AM
    BCTRD
    BCTRD New Member
    B.C.
    Thanks I'll check out Krave when it's time to pull the trigger. I've had Fox 2.0's on other trucks and they were ok, definitely better than stock.
    For the Tundra I'm considering 6120's, vs Fox 2.5 non resi, vs Elka 2.5 non resi. Ran Elka shocks on a Grizzly 700 and they performed great and took a pounding well.
  16. Oct 17, 2021 at 12:48 PM
    mountainpete
    If you’re closer to Vancouver Overland Outfitters is a dealer too.
    Sleeper16plat and BCTRD[QUOTED] like this.
  17. Apr 22, 2023 at 8:36 PM
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    Good feedback. I’m torn between fox and Elka and have been thinking the aluminum body would be better in the long run.
    Are new UCA’s required for the elka resi’s? Or, do you know if I could run stock UCA’s.
  18. Apr 10, 2024 at 7:33 AM
    Swan
    Swan New Member
    Daniel
    2023 Tundra Platinum
    Hey folks, Any recent updates on the Elka over the last year? I’m considering the 2.5s with res and clickers, 0-2” for my 23. Would love any feedback!
    Thanks!
  19. Apr 10, 2024 at 11:04 AM
    #49
    mountainpete
    My feelings from 3 years ago are still the same. Zero issues. Solid performance. Still recommend.
    CanuckTRD likes this.
  20. Apr 23, 2024 at 7:24 PM
    #50
    BOBONTUESDAY
    2016 Limited Trd
    80k miles on mine 0 issues no leaks. They haven't really faded either still look pretty good.
