Entune Firmware Update for 2016-2019
Discussion in 'Audio & Video' started by jbcrewmax, Jan 19, 2022.
  1. Jan 23, 2022 at 6:03 PM
    eRockAZ
    eRockAZ Toyota Tundra Enthusiast
    Mesa Arizona
    2018 White CM Sport
    Can confirm. Wouldn't work with USB3 thumbdrive (identifiable by blue connector). Switched to USB2 TD, and it detected it immediately. Even with other files/folders on the TD (MP3s)
    adamreinhardt likes this.
  2. Feb 14, 2022 at 7:36 PM
    trevorklat
    trevorklat Don't Mess with Texas!
    The Lone Star State
    2018 Super White Platinum Tundra 4WD CM
    Linex bed liner, Retrax roll-top bedcover, Ranch Hand Summit brush guard, SDHC ABS sensor guards, Interior LEDs, Cargo lamp LEDs, Reverse Light LEDs, Rear TRD sway bar, Valhalla's Shield Cat plates, Husky floormats
    I'm with bfunke. How do you update the Gracenote database file?
  3. Feb 14, 2022 at 9:03 PM
    CampRig
    CampRig New Member
    Big Pine, Ca
    2016 SR5
    Kings w Adjusters Etc
    Thanks for this OP! Updated mine over the weekend.
  4. Feb 19, 2022 at 10:31 AM
    DanTundra
    DanTundra Danny
    Wilmington, NC
    2015 Ribbon Blue Tundra SR5 4x4
    TRD sway bar, airbag kit, Diamondback HD, LED headlights, Pedal Commander, Bilsteins 6112's up front with shims (2.5 inch lift), 5160s in the rear with CB +2 shackles (1.5 inch lift), Falken Wildpeak AT3W 285/75/18, TRD Pro Grill insert, MattGecko under hood and bed light kit,
    Has anyone tried this on a 2015? I know the Update is for 2016-2019, but my HU from my 2015 randomly reboots sometimes as well.
  5. Aug 3, 2022 at 5:49 AM
    1794TexTako
    1794TexTako New Member
    2018 Tundra CrewMax 4x4 1794 edition
    Tonneau Cover, Bed Extender and OEM BedMat.
    Having issues when I’m listening music connected to mi iPhone and using Pandora or Spotify, and it suddenly music is interrupted, every time more frequently since last few months, so almost couldn’t listen music anymore. Also signal dropped off and streaming was always erratic causing frequently interruptions of music.
    Finally did the firmware update yesterday, and now for the first time -since long ago- I can listen a song without “cuts”… After the update, not single time that streaming was drop/interrupted. Great. Thanks!
    jbcrewmax[OP] likes this.
  6. Aug 3, 2022 at 6:10 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    Great info! I am tempted to flash the update, but my 2016 HU has never exhibited any issues. So I'm gonna stick with the old technician motto, "If it ain't broke, don't fix it".
    jbcrewmax[OP], RobertD and SMTundra like this.
  7. Aug 3, 2022 at 7:19 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Thanks OP - just did the update on my 2016. Only took a couple minutes.
  8. Aug 3, 2022 at 7:45 AM
    purplenova
    Tom
    Ohio
    What he said - any info for Gracenote database?
  9. Aug 14, 2022 at 11:59 AM
    nuffbass
    nuffbass New Member
    2018 Tundra Platinum
    Thank you so much! This worked on my 2018 Platinum. Fingers crossed my bluetooth disconnects don't return. So far so good!
  10. Dec 10, 2022 at 2:24 PM
    Paradox
    Paradox New Member
    Might be a stupid question but I’m trying to update my 2019 highlander. The Toyota site has no firmware available in their drop-down for this model. Searching for the model id (13TDANNA-DA21) brings me to a bunch of Tundra forums. Would I be able to use the v165 firmware listed or will I have issues?
  11. Dec 10, 2022 at 3:03 PM
    Paradox
    Paradox New Member
    I believe I actually found the answer to my question. Haven’t been able to actually find a copy of the kwi file for any 2019 vehicles except in this forum, but the Toyota documentation implies that it is ok to install.
  12. Dec 10, 2022 at 3:14 PM
    centex
    centex New Member
    Anyone run into a situation where you plug in the USB and the radio says it sees new software, it recognizes the new version (and I have verified it's newer than what's currently running), and then you hit update and it starts for a second and then it says no new software found or media not plugged in? Is there a separate USB port somewhere I'm not aware of?
  13. Jan 27, 2024 at 12:10 PM
    TXBrit
    TXBrit New Member
    Weatherford TX
    2019 MGM Platinum
    Without the knowledge and help from this forum I doubt I would have ever found out why my 2019 Platinum suddenly started the shut down and reboot of the radio.
    Applied the software update listed by the OP and there are now things working on my radio that never worked properly in the last 4 years.
    Thank you all for this information.
  14. Feb 14, 2024 at 7:36 AM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    NTSB Website now showing these versions as current. Anyone know where to find them?
  15. Feb 14, 2024 at 7:42 AM
    JohnWhicker
    JohnWhicker New Member
  16. Feb 14, 2024 at 8:15 AM
    bfunke
    South Carolina
  17. Feb 14, 2024 at 8:19 AM
    JohnWhicker
  18. Feb 14, 2024 at 8:27 AM
    agrestic1
    agrestic1 New Member
    2016 CrewMax
    AMP Research PowerStep, AMP BedStep Bumper Step, BedRug Carpet Bed Mat, Bazooka Powered Subwoofer Tube
    No issues here either but will save this ..
  19. Feb 14, 2024 at 9:51 AM
    #49
    centex
    centex New Member
    For my truck, this says 0127 is the latest.
    The website says it will update it to 0106E but the software download is 0110.
    This has 0127.
