Extremely Cheap! 5.29 gears. Motive gears OK?
Discussion in 'Performance and Tuning' started by Silver17, Oct 5, 2024.
  1. Oct 24, 2024 at 5:22 PM
    #181
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, DIY Traction Bars, Tuning by snivspeedshop.com
    I used it for my transmission and recently my transfer case swap.
    Vizsla[QUOTED] and FrenchToasty like this.
  2. Oct 24, 2024 at 5:25 PM
    #182
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I assume @Vizsla had to take his wheels off and drop the truck to get enough reach out of it hahah
    Vizsla[QUOTED] and TRDFerguson like this.
  3. Oct 24, 2024 at 5:26 PM
    #183
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Nice! I bench pressed that bitch in when I did my Auburn.
    Also the Auburn does not like corner burnouts or long ones. It was roasted after a year.
  4. Oct 24, 2024 at 5:27 PM
    #184
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    If you ever want to sell that powertrax lsd....auburn sucks.
    Vizsla likes this.
  5. Oct 24, 2024 at 5:52 PM
    #185
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax / 2024 Sequoia Capstone
    I will be taking you up on that! And yeah, Zuk for install is the plan.
  6. Oct 24, 2024 at 5:56 PM
    #186
    Silver17
    Silver17 [OP] Used, but returned and sold as new member
    Eastern PA
    2017 TRD 4x4 Harrop SC
    Anyone planning to REM polish them with the savings on the gears?
    TRDFerguson and FrenchToasty like this.
  7. Oct 24, 2024 at 5:57 PM
    #187
    FrenchToasty
    Mo
    Bone stock
    Are you planning on cores or just be down for a few weeks? I’ll come help too!
    Vizsla and TRDFerguson[QUOTED] like this.
  8. Oct 24, 2024 at 6:04 PM
    #188
    TRDFerguson
    Jake
    I’m going to look into it. Toasty mentioned a local shop for it at some point so I’ll see how much that sets me back if I go that route. This is going to be an expensive set of cheap gears…
    TBD haha. I can probably make a hard down for a couple weeks work, but if I can find cores, I know others in the Basin will use them.
  9. Oct 24, 2024 at 6:05 PM
    #189
    Vizsla
    Vizsla ☠️☠️☠️
    Let me know when!, I will definitely come help also.
  10. Oct 24, 2024 at 6:06 PM
    #190
    FrenchToasty
    Mo
    Bone stock
    Maybe even in the valley…….
    TRDFerguson[QUOTED] and Vizsla like this.
  11. Oct 24, 2024 at 6:10 PM
    #191
    FrenchToasty
    Mo
    Bone stock
    your protecting your investment, not only time and diff fluid change money, but the new bearings you just put in will never see lady glitter sparkles and last even longer!
  12. Oct 24, 2024 at 6:11 PM
    #192
    ARES35
    ARES35 New member for life
    Mile high
    Blown 2650 17 1794 Tundra 4x4 CM
    2650/750cc/76mm/SPD DP-DD exhaust/HP tuned
    Jesus just got truck back today, seen this thread and downhill from there. Now to find the install kits smh
    TRDFerguson, Mdl and Silver17[OP] like this.
  13. Oct 24, 2024 at 6:13 PM
    #193
    Vizsla
    Vizsla ☠️☠️☠️
    The problem with cores is the front, puts it in unknown territory for reusing the bearings. They are usually fine, but with an unknown core…
  14. Oct 24, 2024 at 6:17 PM
    #194
    Silver17
    Eastern PA
    I’m definitely interested if I can find a business that is somewhat local to do it. I suppose maybe shipping to somewhere that would do it is always a possibility since I didn’t exactly pay much up front. Is the break in procedure the same if they are REM polished?
    Mdl likes this.
  15. Oct 24, 2024 at 6:19 PM
    #195
    Silver17
    Eastern PA
  16. Oct 24, 2024 at 6:21 PM
    #196
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    Motive or whoever the company is like "whoa" theses gears are flying off the shelves.
    ARES35 and Silver17[OP] like this.
  17. Oct 24, 2024 at 6:27 PM
    #197
    Lemuel1
    Lemuel1 Enjoy
    Samuel
    2020 Tundra
    ToyTec Alumas 2.5,icon IT 2.5 rear,Wheelers superbumpstops, JBA UCA’s, 8 inch BA muffler kit,
    Y'all are bad people……… ordered. Anyone know of any installers around Augusta Ga?
  18. Oct 24, 2024 at 6:37 PM
    #198
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    Just ordered! Motive gears have a pretty good reputation
  19. Oct 24, 2024 at 6:42 PM
    #199
    FrenchToasty
    Mo
    Bone stock
    No break in prior required, none of the weird drive and stop to let cool, just run em. I did change my fluid at like 600miles just for S&G
    Nothing alarming or big shavings to be seen. Also with polishing you don’t need to run hi end synthetic oils, you can just do Dino lube and call it a day since all the friction has already been polished off.
    I like to post this link, and zuk basically agrees
    https://eastcoastgearsupply.com/ft-...0PnM2IIzySf4N8y1bqmK5qwm5Qv7fIpVgYwvhkDVTQqZv
    I paid 40$ each way for both sets to be shipped to the polisher, look up the address and get a quote from your area. 150$ per set for polish, but I’ve seen cheaper quotes as well
    Mdl, Vizsla and Silver17[QUOTED][OP] like this.
  20. Oct 24, 2024 at 7:10 PM
    #200
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    2021 Tundra DC
    Not sure at this point.
    Just ordered the rear 5.29. Waiting for the fronts to go back down to ~$50.
    Mdl, Silver17[OP] and FrenchToasty like this.
  21. Oct 24, 2024 at 7:35 PM
    #201
    BreyTundy
    BreyTundy Big 4Lo Guy
    Andrew
    Colorado Springs
    2016 White DC TRD
    This thread is such a great example of pier pressure
    ARES35, Silver17[OP], Lemuel1 and 2 others like this.
  22. Oct 24, 2024 at 7:40 PM
    #202
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    It is! And @Silver17 setting things in motion.
  23. Oct 25, 2024 at 4:50 AM
    #203
    Silver17
    Eastern PA
    There was definitely an inflection point somewhere in this thread where it went from “that’s a bad idea” to “hey I think these are legit.” Seem legit to me. :notsure:
    I have to wonder if Motive made a big batch of these things and then they never gained footing in the tundra market and sat around. Now after 6 years maybe they said, hey let’s just dump these things! I just hope they prove to work well in our trucks. Who will be the first guinea pig to have them installed?
  24. Oct 25, 2024 at 5:23 AM
    #204
    BreyTundy
    Andrew
    Colorado Springs
    2016 White DC TRD
    From the research I’ve done it seems that Motive has a pretty solid reputation in the general offroad community. I wish I was the first guinea pig to get them installed, but it’s going to be a while for me :anonymous:
    Mdl and Silver17[QUOTED][OP] like this.
  25. Oct 25, 2024 at 5:54 AM
    #205
    Js18tundra
    I’ve personally run motive gears on 3 of my previous trucks, never had an issue. As long as you break in gears and they are set up correctly there should be no issues.
  26. Oct 25, 2024 at 6:47 AM
    #206
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    Can’t be any worse than the old Genuine Fears that 4WP used to sell. With their lifetime warranty on the parts only, they helped a lot of people get really fast at replacing gears…
  27. Oct 25, 2024 at 8:15 AM
    #207
    Silver17
    Eastern PA
    I found a place within 45 minutes of my house for gear polishing. It’s in Quakertown @ZPhilip if that interests you. They charge 150/set for polishing and 7.75 per bearing if I did the bearings. I’m probably gonna go this route. What is the consensus on polishing the bearings, yay or nay?
    Mdl and pvn.beluga like this.
  28. Oct 25, 2024 at 8:31 AM
    #208
    pvn.beluga
    Phuc (Phooc)
    Connecticut
    2021 Tundra DC
    Sucks that ECGS is all the way down in NC.
  29. Oct 25, 2024 at 8:38 AM
    #209
    Ghost Rider
    Ghost Rider Mods wouldn't be an issue if money wasn't.
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    Price as of 10:40AM CST 10/25/2024
    Not sure what the deal with different "size"? 9"/9.5"/10"/10.5"
    But those prices are hella cheap for sure.
    Silver17[OP] likes this.
  30. Oct 25, 2024 at 9:52 AM
    #210
    Silver17
    Eastern PA
    Yeah you need the T10.5 for rear and T9 reverse for front.
    carn_dogg, Terndrerrr, Mdl and 5 others like this.
