"Fancy" climate control knobs for Gen 1?
Discussion in '1st Gen Tundras (2000-2006)' started by 2truckornot2truck, Aug 30, 2020.
  1. Mar 21, 2022 at 11:53 PM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Thought experiment!
    FirstGenVol and alb1k[QUOTED] like this.
  2. Mar 22, 2022 at 12:22 AM
    des2mtn
    des2mtn On the scenery looking at the road
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I agree with you too, that looks too aggressive and doesn't match the rest of the truck's styling. I'll keep sticking with the OEM style linked at the bottom.
    Tundra2 likes this.
  3. Mar 22, 2022 at 1:31 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Cool, but.....naw.
  4. Mar 22, 2022 at 6:10 AM
    No need, I'm pretty sure I have one last spare knob. Gimme a shout.
    I know I sent a spring to @abcinv and I sent a full knob to another member I don't remember. I should have one remaining.
  5. Mar 22, 2022 at 6:14 AM
    I would say ... there is a way, just not any time-affordable way to do it in bulk. For example...
    But I also agree. Those are hideous. They look like they have a felt face and too angular/chunky for how smooth and linear the center dash is. But I feel like the red backlighting is also pretty hideous so ...
  6. Apr 16, 2022 at 6:33 PM
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    South of ATL
    2006 Tundra 4X4 Limited Dbl Cab
    I just got around to installing this clip / spring you sent me. I pulled it out of the bag and was like where the frack does this go. I bet I looked at the knob for two minutes before I saw the slot for it...
    Anyway it was exactly what I needed, thanks again!
    shifty`[QUOTED] likes this.
  7. Apr 16, 2022 at 7:16 PM
    Killer! Glad it helped. I think I sent my last remaining OEM knob to @KK6PD a few months back. My clock is all out of whack the last two years, hell if I could nail down the date!
    KK6PD and abcinv[QUOTED] like this.
  8. Apr 16, 2022 at 7:44 PM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
    While we’re on the topic of climate control knobs, is the a how to or anything showing what all needs to be cleaned/greased? Mine are stuck:bananadead:
    plus do the replacement knobs come with the little metal clips?
  9. Apr 16, 2022 at 7:52 PM
    abcinv and Cummins3500[QUOTED] like this.
  10. Apr 16, 2022 at 7:56 PM
    Cummins3500
    Logan
    abcinv and shifty`[QUOTED] like this.
  11. Apr 17, 2022 at 6:14 AM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Can't speak for OEM from dealer but would hope they did. As for most of the Amazoom links on first page of this thread, if you hover over the pics in those links, they show a pic of clips, so assume they do ?
    Cummins3500[QUOTED] likes this.
  12. Apr 17, 2022 at 9:56 AM
    Cummins3500
    Logan
    @BubbaW sweet I appreciate it , I’ve got 2 outta 3 of clips. That 3rd one pulled a Houdini. I’m trying to talk myself outta of the OCD4WD nobs lol I kinda like em .
    BubbaW likes this.
  13. Oct 11, 2024 at 1:28 PM
    Gharb
    Gharb New Member
    Gavin
    2003 Tundra 4.7L RWD SR5 Access Cab
    I’m missing one after updating my bulbs - any chance you still have this?
  14. Oct 12, 2024 at 12:48 AM
    Possibly. I gave the one I referenced to @abcinv. I definitely still have a spare knob left, I’m pretty sure. But it may be the cracked one. That said, if the clip popped out on you, it’s probably because your original is cracked. What it’d cost for me to ship a replacement knob is on par with what you’d pay for a replacement knob, though. And this may be a good time to update to the new style round knobs many are using from scAmazon. Specifically the JDMCAR knobs.
    https://www.amazon.com/dp/B0D1CDTZLR
    Hooptytrix and Fieldnstreamer like this.
  15. Oct 12, 2024 at 4:08 AM
    Gharb
    Gharb New Member
    Gavin
    thanks Shifty, I’ll do that. Lost it when I removed the panel to update to LED’s, appreciate the quick response!
  16. Oct 12, 2024 at 6:14 AM
    Fieldnstreamer
    Fieldnstreamer Cold Researcher
    Sam
    East Tn
    2006 DC Limited 4x4 Phantom Gray Pearl, 2000 AC Limited 4x4 (R.I.P.)
    Brute force bumpers/sliders, OME 3" lift, SCS ray 10 wheels, ARB onboard air compressor, GX460 big brake upgrade, JBA UCA's, siberian Bushings, RCV high clearance axles, 333 Billet steering rack clamp, TMR customs 10" front limit straps, 1" diff drop, agility customs dual battery setup/battery isolater with heavy duty wiring/ grounding cable upgrade, F-er battery tray, HFW spindle gussets, remote oil catch can,
    My lights are burned out. How do I go about getting that panel popped off? You didn't happen to snag any pics did you? I've wondered for a while where do I even start taking the dash apart.
  17. Oct 12, 2024 at 6:44 AM
    khooiii
    khooiii 80HD
    DK
    DFW, TX
    03 Tundra AC 4WD
    3 screws behind each of the knobs. 2 up top just aim the vents upward and you’ll see them. Then pop the panel out.
  18. Oct 12, 2024 at 7:22 AM
    Gharb
    Gharb New Member
    Gavin
    No problem - there are screws behind the vents and behind the control knobs.
    There’s a good video on YouTube that will walk you through it. Recommend upgrading to LEDs, really makes a difference. The description on his video also provides links to the LEDs on Amazon.
    https://youtu.be/H1MKCgnfCu4?si=tioulgsdR1Z3S90W
    While you’re at it, might as well update the dashboard LEDs, door panels, overhead, cargo bay and license plate. It’s not that much $$$ and makes a world of difference.
    If you put in one of the LEDs and they don’t work pop it back out and rotate it, they are specific in some cases.
    shifty` likes this.
  19. Oct 12, 2024 at 8:31 AM
    #49
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 SR5 Tundra TRD Off Road
    Dirt Deeds injectors, Addco rear sway, AEM dry flow air filter, last ever set of Stan's Try-Y headers, Borla full custom exhaust, front level, wheel spacers, and lots of electronics.
    Correct, LEDs are polarity sensitive due to the D in LED, meaning diode. They only flow voltage in one direction unlike incandescent.
    Best to check your LED converted gauge cluster or HVAC controls by plugging the harness in real quick to make sure everything illuminates before full reassembly.
    Just like mentioned above, if it doesn't illuminate, remove and rotate 180*.
  20. Oct 12, 2024 at 8:50 AM
    #50
    Two points here:
    1. Not all LED are polarized. For example, the lifetime warrant ZEVO bulbs from Sylvania I installed in my dash are not polarized. They work every direction and cost a lot, but again, lifetime guarantee.
    2. Be sure to save the green jelly condoms some over the OEM bulbs in case you want green output back some day. And note: Those condoms dumb down the brightness a bit, so when you switch, expect it to be 4x brighter light. 2x because you remove the condoms. 2x because you upgraded to LED.
    Fieldnstreamer likes this.
  21. Oct 12, 2024 at 9:23 AM
    #51
    Gharb
    Gharb New Member
    Gavin
    You are both correct - all LEDs are polarized and current flows in one direction, however many, especially in resi lighting, have reverse polarity protection built in. Some that I purchased did not, and had to be flipped for a couple.
    Left out that you should NOT replace the bottom dashboard lights with LEDs ie check engine light etc. doing so is reported to have them illuminate constantly instead of when triggered.
  22. Oct 12, 2024 at 11:46 AM
    #52
    Spike77777
    Spike77777 New Member
    2000 Limited Bilstein shocks, mild lift 1" front and 3/4" block rear. 17" Stock wheels from later model Tundra with 275/70/17
    I went with these, I like them but during the day it's hard to tell where the pointer is. I got some white nail polish and put a small dot behind the led indicator. All good now.
  23. Oct 12, 2024 at 1:58 PM
    #53
    Gharb
    Gharb New Member
    Gavin
    I can’t tell from the imagery - do they come with the retainer clips?
  24. Oct 12, 2024 at 2:18 PM
    #54
    They have everything you need. It’s plug and play.
    Gharb[QUOTED] likes this.
  25. Oct 12, 2024 at 4:28 PM
    #55
    Spike77777
    They do, I just pulled the original one's when I installed a new head unit and pressed these on when putting it back together.
    I like the way it gives it an updated look.
