Finally got the ok for a Supercharger
Discussion in 'Performance and Tuning' started by 19PlatinumCrew, Aug 10, 2023.
  1. Aug 18, 2023 at 3:58 PM
    #181
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Yea the issue is where the tube lands on the panel out front. With that landing high it puts the tube above into the lid area. Maggy box with the SABM mod is where it’s at if running that box. No need for the stillen tube since they maggy box seals well and sees super low IAT.
    Update from my morning coffee run. Now seeing 9-10 above ambient. Before 12-14 and with no sealing or anything it was 70+ . Good enough for now until this whole box gets removed ahah
  2. Aug 18, 2023 at 5:04 PM
    #182
    Saltyhero13
    Saltyhero13 Throbbing Member
    Sure. I don't have a Maggie box so I am sure some tweaks would have to be made. Those parts can be rotated to navigate around things and accommodate the correct position to the deflector. Also possible none of that shit I listed fits at all in the space confines of the bay.
    "No" isn't part of my vocabulary. However, I don't disagree about SABM as you see in my other comments. I'm just trying to make the dream happen since it sounds like he may still be interested in using the Stillen tube. I would play around and test fit those parts if I were working with that air box and trying to affix the Stillen tube.
    Seeing your numbers now I want to do a SABM to get those sweet IATs as low as possible without an ice box. Aside from dust having both wont hurt anything.
    reywcms[QUOTED] likes this.
  3. Aug 18, 2023 at 5:32 PM
    #183
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I don't know if there is a difference with the Sequoia but I'm seeing 3-6 above ambient with the SCOL & SABM.
  4. Aug 18, 2023 at 5:54 PM
    #184
    Silver17
    Eastern PA
    2017 TRD 4x4 Harrop SC
    If only all of the supercharger kits measured IAT after the intercooler like the Harrop, then we could really compare all this talk of efficiency and intercoolers in reference to IATs more accurately.
    Also I noticed something interesting today. The ambient temp readout on my dash read 70, but the ambient temp according to my scangauge 3 read 73. I would have thought they were referencing the same sensor, why would they read differently? Is the scangauge just reading the data wrong it could it be looking at a different sensor?
  5. Aug 18, 2023 at 6:19 PM
    #185
    Saltyhero13
    It would be nice to see an even comparison between the designs and their capacities.
    From what I've read and seen presented your external heat exchanger's capacity and the highest pump volume/speed you can run before reaching cavitation will make the most difference as does the coolant medium such as pure distilled or water wetter (which not all can run).
    When I first got SG3 there used to be two ambient sensor monitors and there was a slight difference in what the two presented. I went looking for the second one recently and I don't think they are both available anymore.
    I've had an occasional issue where the ambient sensor shows up as -37 but clears on the next start up.
    Silver17[QUOTED] likes this.
  6. Aug 22, 2023 at 6:10 AM
    #186
    19PlatinumCrew
    19PlatinumCrew [OP] New Member
    Dave
    MGM 19 Platinum Crew
    Toytec 3" coilover lift,295/75/18 on Method Nv,Nitto tires,Retrax cover,spray liner.
    No new updates on the Supercharger...they said probably 7 to 10 days before they could get shipping info. I pulled my cat plates off so National Speed can weld in a sensor bung,rotated tires and drained Trans while it was on jack stands..will keep yall posted on the progress
  7. Aug 22, 2023 at 6:22 AM
    #187
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    Cannon fodder v2.0
    Speaking of IAT.
    It’s been Africa hot in Houston...maybe hotter, this past week or so.
    But – my IAT delta is rock solid @ ~26-29 degrees on the hwy.
    City stop lights….40-45 degrees….cools back off quick.
    The ’34 Ford’s A/C is AWESOME…it’s bearable to cruise around now. However – it makes it hard to wave back at folks when the windows are up. For theater of the mind – riding in it is like sitting sideways in a bathtub.
  8. Aug 22, 2023 at 6:44 AM
    #188
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    No gauges. Now, I'm wondering if I can get readings on the digital gauges in the Phoenix Automotive HU which is plugged in to the OBDII port. Hmmm, I have some tinkering to do.
  9. Aug 22, 2023 at 7:25 AM
    #189
    e30cabrio
    I have an Innovate PSB1 and AutoMeter Fuel Pressure gauge. I use my Kenwood for the rest.
    Mdl likes this.
  10. Aug 22, 2023 at 10:40 AM
    #190
    19PlatinumCrew
    Dave
    I did purchase the psb1...will mount it in the vent like HulkSmurf14 did. I have my scangauge 2 mounted on that side so I felt this would be a good idea, it's not wired up yet gonna let National Speed do it and weld in the bung.
    HulkSmurf14 and e30cabrio like this.
  11. Aug 22, 2023 at 10:43 AM
    #191
    19PlatinumCrew
    Dave
    Nobody you running a Maggie air box
    nobodyintexas[QUOTED] likes this.
  12. Aug 22, 2023 at 11:01 AM
    #192
    e30cabrio
  13. Aug 22, 2023 at 11:15 AM
    #193
    nobodyintexas
    nobodyintexas What?
    South of Houston
    It’s sitting new in the box
    just got it to the house
    might install it next week
  14. Aug 22, 2023 at 11:17 AM
    #194
    e30cabrio
    It drops right in, easier than OEM somehow. (for me at least)
  15. Aug 22, 2023 at 11:29 AM
    #195
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Good to know
    I used up all my cuss words dropping the cat plates to do a drain and fill
    e30cabrio likes this.
  16. Aug 22, 2023 at 2:20 PM
    #196
    19PlatinumCrew
    Dave
    You got the part numbers I'm looking for the larger one as I'll be running the smaller pulley
  17. Aug 22, 2023 at 2:31 PM
    #197
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I’ll post in morning
  18. Aug 22, 2023 at 2:37 PM
    #198
    19PlatinumCrew
    Dave
    Thanks......I appreciate it
  19. Aug 22, 2023 at 2:50 PM
    #199
    nobodyintexas
    nobodyintexas What?
    South of Houston
    I’m proud I did this on my phone. Small wins.
    HulkSmurf14 likes this.
  20. Aug 22, 2023 at 3:02 PM
    #200
    Silver17
    Eastern PA
    I’m also proud of you! Buttttt that Intake is the same size MAF tube as the stock intake. @19PlatinumCrew is looking for the larger supercharger specific intake in order to avoid maxing his MAF sensor out I believe?
  21. Aug 22, 2023 at 3:07 PM
    #201
    nobodyintexas
    nobodyintexas What?
    South of Houston
    Tru dat
    Im staying stock so purchase accordingly
  22. Aug 22, 2023 at 5:00 PM
    #202
    VWTim
    VWTim Mid-Travel Crew
    Corvallis, OR
    Cooling medium popped in my head the other night. Thinking back to high compression SCCA VW motors, water wetter gave a noticeable reduction in pre-ignition/knock. Anyone know how Toyota pink responds to water wetter?
    reywcms likes this.
  23. Aug 22, 2023 at 5:45 PM
    #203
    19PlatinumCrew
    Dave
    Thanks Silver...SCOL called me I made sure to order the 4" one...it is ordered.....also thanks Nobodyintexas for the part number
  24. Aug 22, 2023 at 5:53 PM
    #204
    19PlatinumCrew
    Dave
    Just got the order process it shows m351957206 as Magnuson airbox lid trd 5.7..
    M351957020 as Magnuson, 5.7 tundra airbox base..total for both with shipping 309.56 top is not in stock at time I ordered
  25. Aug 22, 2023 at 6:40 PM
    #205
    Saltyhero13
    Not sure. I know wrong coolant was causing issues on one of the blowers; probably the Harrops.
    I think @Fastlane47 runs water wetter.
  26. Aug 23, 2023 at 4:30 AM
    #206
    nobodyintexas
    nobodyintexas What?
    South of Houston
    awwwww mannnnnnn.
    this thing does not come with the lower air box section!
    my lower section is the part that is broke - those tabs closer to the engine cracked.
    anybody have the lower airbox part number?
    and no sticker!
  27. Aug 23, 2023 at 4:58 AM
    #207
    19PlatinumCrew
    Dave
    These are the numbers that were sent to me but they are for the larger tube,don't know if the lower box is the same
  28. Aug 23, 2023 at 8:17 AM
    #208
    VWTim
    Corvallis, OR
    Isn't the lower box just an early Tundra airbox? '07 thru ???
  29. Aug 23, 2023 at 8:27 AM
    #209
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    I run it in mine. Whipple also recommends adding it.
  30. Aug 23, 2023 at 9:28 AM
    #210
    19PlatinumCrew
    Dave
    It is the 7 thru 13 I believe
    VWTim[QUOTED] likes this.
