FOAM CANNONS ?
Discussion in 'Detailing' started by 2010bigdog, Nov 18, 2018.
  1. Apr 5, 2019 at 6:45 PM
    ProtoJ
    ProtoJ New Member
    2018 Crewmax TRD Off-Road
    I love my auto geek foam cannon with poor boys pre soak!
    aperezsh and Pudge like this.
  2. Apr 5, 2019 at 6:54 PM
    War Machine
    War Machine SSEM # 5 3MW
    It is really solid.
    I use CG honeydew snow foam. I follow the instructions on the label. I think it’s two ounces soap, the rest with WARM water. (It makes a big difference)
    One thing that may throw you off. Turning towards minus on the dial gives more foam. You’d think it’s the other way around.
    I changed the orifice and got worse results, so I changed back. I ended up reading later that changing it out is not recommended for larger PSI pressure washers. Not sure where the cutoff is, but it works great as is for me.
    Pudge[QUOTED] likes this.
  3. Apr 5, 2019 at 6:56 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Thanks Jason
    War Machine[QUOTED] likes this.
  4. Apr 5, 2019 at 6:58 PM
    War Machine
    Guess the sun is coming back out. Been lonely here!
  5. Apr 5, 2019 at 7:03 PM
    Pudge
    CT
    Finally starting to warm up, it's been killing me man. I hope to use the cannon this weekend.
  6. Apr 7, 2019 at 10:38 AM
    schaderaide
    schaderaide New Member
    Ryan
    Orange County, CA
    Anyone use the foam canon or any of the stuff from Slick Products?
  7. Apr 7, 2019 at 11:08 AM
    geno0506
    geno0506 New Member
    Michael
  8. Apr 7, 2019 at 11:09 AM
    geno0506
    geno0506 New Member
    Michael
  9. Apr 7, 2019 at 11:27 AM
    Pudge
    CT
    Faht Nocker, T-Rex266 and War Machine like this.
  10. Apr 7, 2019 at 1:39 PM
    Pudge
    CT
    Ended up power washing the foam off and the truck was very clean which I was surprised by. I did a quick wipe down with ech2o, then rinse, and some hydro2. Came out pretty good but kinda foggy. I think I went too strong on my hydro2 mix. Ended up going over it all with a spray bottle of ech2o,water,and reload mix to get rid of the foggy finish. My beadmaker didn't arrive on time for this wash but should be here soon.
    The winter was rough on the car but my reload application in Sept, then hydro2 in November seems to have held up pretty well.
    Definitely needs to be clayed and buffed in the near future. Hopefully I'll find the time next month.
    Oh I went cheap and quick on the tires and plastic with some 303, ran out of time and energy for today.
    aperezsh and War Machine like this.
  11. Apr 7, 2019 at 1:52 PM
    YsoSeRiouS!
    YsoSeRiouS! A good day...for a good day
    NorCaL
    2019 White Platinum CM
    aperezsh, Pudge and War Machine like this.
  12. Apr 7, 2019 at 1:59 PM
    Guhner123
    Guhner123 New Member
    Gunner
    2017 Tundra SR5 MGM
    Toytec/Eibach 3/1 lift kit 295/70/18 TOYO AT 18 Inch Method NVs
    This is the only picture I have of a mid wash. But I have the foam cannon from chemical guys and this thing works magic. I do also use the snow foams from chemical guys too which explains the mass foamyness.
  13. Apr 7, 2019 at 2:07 PM
    G10dra
    G10dra Not a New Member
    there is something to be said about feeling the satisfaction of washing your own car. Knowing that you've scrubbed each and every reachable corner/edge/trim and underbody and then wiping it down dry only to say "Goddamit, I've missed a spot." .
    The satisfaction is there.:)
  14. Apr 7, 2019 at 2:08 PM
    Guhner123
    Gunner
    2017 Tundra SR5 MGM
    The worst part is when your fully done and your emblems and handles keep dripping :annoyed:
    jtwags, Finch, YsoSeRiouS! and 2 others like this.
  15. Apr 7, 2019 at 2:09 PM
    War Machine
    What are the yellow things on your handles?
  16. Apr 7, 2019 at 2:10 PM
    Guhner123
    Gunner
    2017 Tundra SR5 MGM
    Those are rags. I foam them on the vehicle and then use them to scrub the vehicle. A little trick a detailer taught me instead of using a bucket.
  17. Apr 7, 2019 at 2:43 PM
    Pudge
    CT
    I'm about to remove my only remaining emblem (the platinum one) for that reason.
  18. Apr 7, 2019 at 2:45 PM
    Pudge
    CT
    So if my truck were dirtier and needed a 2 bucket wash after foaming it, should I rinse the foam off first or just go right into using my mitts? I assume rinse to remove debris and also the foam may dry before I could get all the way around the truck.
  19. Apr 7, 2019 at 2:46 PM
    #49
    geno0506
    geno0506 New Member
    Michael
  20. Apr 7, 2019 at 3:00 PM
    #50
    Pudge
    CT
    I found one for my powerwasher. Karcher k2. Came with the correct fitting. Depending on your power washer you may need to do the same or buy and adapter. I like how my adapter was built into it. Well worth it.
    geno0506[QUOTED] likes this.
  21. Apr 7, 2019 at 3:03 PM
    #51
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    After using the foam cannon, do you typically use a power washer at a low setting to wash off the foam? and are you then pretty much done, besides drying and applying whatever wax you use?
    Or do you foam the truck, scrub it by hand with a rag, and then wash it off with power washer or hose?
    The foam cannons seem really cool, I'm just not sure of the entire cleaning process and how or if it saves time from doing everything by hand.
    Also, if it is sunny and relatively hot out...I live in Phoenix...I can't imagine you could get all that soap off your truck before it started to dry. I'm guessing you could only soap and then rinse one section at a time.
    Sorry I keep thing of questions. Is this a two hose process?...one hose connected to the foam cannon and one hose connected to the power washer?
    Now I'm thinking it might save time doing the actual washing, but the setup and break-down might add a significant amount of time.
    I already do a good job washing by hand, I can't imagine the cannon and pressure washer would do a better job than hand. The only reason I would use that stuff is if it is faster.
    TRD Pro Rookie likes this.
  22. Apr 7, 2019 at 3:06 PM
    #52
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    To scrub the paint?...Or wheels, fender liners, underneath the rocker panels?...I'm guessing you use them once and toss them?
  23. Apr 7, 2019 at 3:08 PM
    #53
    geno0506
    geno0506 New Member
    Michael
  24. Apr 7, 2019 at 3:10 PM
    #54
    Guhner123
    Gunner
    2017 Tundra SR5 MGM
    Yeah for paint and yes they are one and done. I buy them in bulk at Costco. They’re microfiber towels.
  25. Apr 7, 2019 at 3:18 PM
    #55
    Pudge
    CT
  26. Apr 7, 2019 at 3:29 PM
    #56
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    Same on the MTM. I just follow the lead of Matt Moreman from Obsessed Garage.
    https://www.obsessedgarage.com/pages/about
  27. Apr 7, 2019 at 3:31 PM
    #57
    I rinse and then use two bucket method.
  28. Apr 7, 2019 at 3:59 PM
    #58
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    BRILLIANT! However I reuse mine. Wash them in the laundry.
  29. Apr 7, 2019 at 4:00 PM
    #59
    Guhner123
    Gunner
    2017 Tundra SR5 MGM
    I’ll reuse the ones that are clean but I usually scrub the tires with them too so that destroys them.
  30. Apr 7, 2019 at 4:25 PM
    #60
    geno0506
    geno0506 New Member
    Michael
    When you all use the foam canon, is there certain steps you use! I tried before and thought you just spray and let sit, then rinse off! I guess you have to brush too! :eek:
    Pudge likes this.
