Front Trd sway bar.....
Discussion in 'Suspension' started by JerseyTundra1260, Nov 17, 2017.
  1. Jul 27, 2018 at 6:18 AM
    #271
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
  2. Jul 27, 2018 at 7:03 AM
    #272
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I installed the rear bar and it made a nice improvement in handling. Not sure if I wanna spend in this upgrade since I already have a sway har up front.
    Anyone heard of shock tower mount crossbars for the front of our trucks? Wonder if that would help too?
  3. Nov 28, 2018 at 5:53 PM
    #273
    dongkatsu
    dongkatsu New Member
    Dong
    2017 Black Tundra Platinum
    7" bds gone due to issues and switched out the kit to Readylift 6" and up to 7"
    I would like to pick one up. is there discount code?
    @Roman
    Rica25 likes this.
  4. Nov 28, 2018 at 6:16 PM
    #274
    Professional Hand Model
    Hand Protectors
    Have the original 02’ TRD front sway bar that was recently reattached after having the rusted sway links replaced. The improvement was instant. Just bought a Hellwig 7700 for the rear for grins and this thing handles like a magnet on the curves.
    Couple of reccos. Use lube on the shaft sway bushings or your spring out of turns will feel sluggish. Do not tighten the sway links bolts to tight.
    justfortun likes this.
  5. Nov 28, 2018 at 6:31 PM
    #275
    dongkatsu
    Dong
    Rica25 likes this.
  6. Nov 29, 2018 at 3:56 AM
    #276
    Hand Protectors
    It probabaly does, but I’m too cheap to buy a torque wrench. I’ll be renting one soon for the carrier bearing replacement. Will proper torque at that time.
  7. Nov 29, 2018 at 5:40 AM
    #277
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I've done the rear sway bar and the 111 lb-ft is the torque spec right from the factory manual and you definitely want to get them to that spec.
  8. Nov 29, 2018 at 6:50 AM
    #278
    Roman
    Roman
    Franklin, TN
    The part itself is already heavily discounted when purchased through our online store. The only promo code we have is for a discount off of shipping: FORUM20
    Rica25 likes this.
  9. Nov 30, 2018 at 8:16 AM
    #279
    dongkatsu
    Dong
    @Roman thanks and tried using that shipping code and says expired code.
  10. Nov 30, 2018 at 8:41 AM
    #280
    Roman
    Roman
    Franklin, TN
    It's still good. I just ran a mock ticket, and it discounted the shipping for me.
    Rica25 likes this.
  11. Nov 30, 2018 at 11:18 AM
    #281
    dongkatsu
    Dong
    @Roman i'll try again. thanks!
  12. Aug 11, 2019 at 7:31 AM
    #282
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Rica25 likes this.
  13. Aug 11, 2019 at 12:31 PM
    #283
    wktjr
    wktjr New Member
    Maine by way of New Jersey
    2013 Tundra SR5, Black Crewmax
    e30cabrio[QUOTED] likes this.
  14. Nov 30, 2019 at 3:35 PM
    #284
    focal
    focal and the Warthog
    Nikolai
    VA / NC
    2011 Tunda Rock Warrior 5.7 DblCab
    I’m about to order a front bar but I bought the truck with no front sway bar or hardware. Does this replace all existing parts or do I have to order the bolts, nuts, bushing and brackets? Thanks
  15. Nov 30, 2019 at 3:47 PM
    #285
    e30cabrio
    All you get is the sway bar. Toyota sent mine unboxed to the dealer. It got scratched up.
    focal likes this.
  16. Nov 30, 2019 at 4:57 PM
    #286
    mech_engineer09
    mech_engineer09 Tundra Enthusiast
    Ohio/Pennsylvania
    2020 MGM Platinum
    Ceramic Pro, XPEL Ultimate Plus, Woolwax Undercoating, Diamondback HD, TRD Air Intake, TRD Skid Plate, TRD Front & Rear Sway Bar
    I just installed mine on Friday. You use existing hardware. Just replace the bar. Very easy install once you get the skid plate off.
    focal[QUOTED] likes this.
  17. Nov 30, 2019 at 5:13 PM
    #287
    mech_engineer09
    Ohio/Pennsylvania
    2020 MGM Platinum
    Torque specs. Note. Do the 111 lbs-ft bolt before putting back into truck. No room to torque it when it’s on the vehicle.
    for the directions on the rear sway bar it says you can be +/- 12 lb-ft I’m not sure if this would apply to the front bar as well. I would always put on a few extra just to be safe if any bolts loosen up over time.
    Matala and focal like this.
  18. Jul 10, 2020 at 8:43 PM
    #288
    gupster88
    gupster88 New Member
    Brett
    Charleston, WV
    2019 Toyota Tundra SR5 TRD Off-Road
    For those who installed this, did you find it easier to install with the tundra on the ground (tires installed obviously) or with the tundra on jack stands and tires removed?
  19. Jul 11, 2020 at 5:05 AM
    #289
    tech1208
    tech1208 Old Salt, New truck
    Orlando, FL
    2023 Tundra Platinum 4X4 Blueprint Blue
    I installed this on the ground and with the skid plate in place. Took thirty minutes with air tools.
  20. Jul 16, 2020 at 11:22 AM
    #290
    Don't do it with the skid plate on unless you want to risk scratching it up. The bar weighs 29 pounds.
  21. Jul 16, 2020 at 11:38 AM
    #291
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    I installed the TRD front sway bar on my 2012 Crewmax long ago and noticed an immediate difference.
  22. Oct 6, 2020 at 3:13 PM
    #292
    TheBubbaDude
    TheBubbaDude New Member
    2020 Tundra TRD Pro
    AJT Blackout Kit 1.25" Wheel Spacers NRG 285/70/18 Meso Customs TRD Start Button
    Any updates on this thread? I'm considering upgrading the front sway bar.
  23. Oct 6, 2020 at 4:22 PM
    #293
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Magnuson Magnum TVS 2650 S/C Sniv's Speed Shop 65mm pulley RCF Throttle Body TRD PRO BBS Wheels TRD Front Sway Bar TRD Rear Sway Bar Fox TRD Pro Shocks Limited mirrors (auto darkening/backup camera/power fold/puddle lights) Limited Grill Mod Automatic Climate Controls Mod Automatic Headlamp Mod Sequoia Transfer Case Mod Sequoia Leather Steering Wheel Mod Sequoia Limited Gage Cluster Mod Sequoia LED Headlamp Upgrade Window Tint 15/70% Fake Manual Transmission Mod 10" BAMufflers Stainless Catback Valhalla Catalytic Converter Shields Engine Block Heater Illuminated Ignition Key Ring Mod Deck Rail System w/cleats Solid Offroad Engine Mounts
    I can't imagine what would change...
