Fully boxed frame vs c-channel
Discussion in 'General Tundra Discussion' started by WrigglingWilly, Sep 26, 2019.
  1. Oct 13, 2020 at 12:59 PM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    Nope :thumbsup:
    Terndrerrr[QUOTED] likes this.
  2. Oct 13, 2020 at 1:11 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I was curious what the numbers (roughly) were and was bored.
    Pulled out my ass; 4x2 frame with 0.125" walls but:
    Torsional stiffness (like when you're flexing) increases by ~42%.
    Vertical bending stiffness (whoops, jumps, speed bumps, load in bed, etc.) increases by ~23%
    Granted, you have a 50% increase in materials and there's more structurally efficient ways to do it, but considering how (relatively) easy it is to box the frame versus other options, that's a pretty good return on investment.
    reywcms, ColoradoTJ, Darkness and 3 others like this.
  3. Oct 13, 2020 at 2:47 PM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    no
  4. Oct 13, 2020 at 2:49 PM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    #fuckyeahmath :woot:
    :bananadance::taco::kona::dancingbacon:
    chugs and 831Tun like this.
  5. Oct 13, 2020 at 2:54 PM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Obviously the BEST way is to cage the truck. But that's expensive, heavy, and uncomfortable (loud cab, race seats /harnesses, and helmets)
    Boxing the frame is a good compromise as long as you don't need rollover protection
    I'm still torn on the center section. That shit is like a half inch thick as it is. I'm not sure how much the boxing plates will add
    831Tun likes this.
  6. Oct 13, 2020 at 7:04 PM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    yeah I was just under my truck. That middle section is thick.
    For boxing the rear, would you box in both open C rails AND tie them together with an X?
    It’s the big X pattern that I’ve seen some do to join both rails together after boxing them in that makes me wonder about the spare still fitting...
  7. Oct 13, 2020 at 7:44 PM
    Vizsla
    Vizsla 2 = 2.5
    Just depends on your level of commitment and the fabricators preference to keep or remove factory crossmembers, but the x in the back needs to stay imo.. Pros and cons to both, but the same is achieved in the end. Mine has the factory crossmembers removed and replaced with tube. Bunch of work, expensive to do correctly, but definitely stronger, just not sure that much is needed. I like it though, works great. Obviously no spare, probably not too hard to make one work, but way easier with the factory x brace.5FF5ECD5-A22C-4672-A320-F3EF10F9CA4A.jpg
    ColoradoTJ, 831Tun, snivilous and 2 others like this.
  8. Oct 13, 2020 at 7:46 PM
    GravityGear
    GravityGear Parking Lot Prerunner
    Aurora, CO
    2014 Black DC TSS Off Road 4x4 5.7
    Transfer Flow tank, Pinstripe Suit
    Are you jumping your truck? Hucking dunes? Doing 1450 stuff with your friends? If you say no, just box it and retain the stock crossmembers. It's a lot of weight to add some 1.5 120 DOM as crossmembers. I've seen it done, but then I have the question of why not just back-half it?
    I'm honestly surprised your shit isn't back-halfed.
    snivilous and Terndrerrr[QUOTED] like this.
  9. Oct 14, 2020 at 9:51 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Dave I love you man you the homie. But respectfully, that shit is overkill haha
    The factory X brace works great. Its specifically designed to stiffen torsional rigidity. And it doesnt add a lot of weight. Just box the c channel and make sure the boxing plates are contoured to the shape of the X brace so that the X brace is fully integrated into the new boxed frame. Spare tire will be unaffected
    I've been wheeling this truck since 2013 and in that time I've wheeled with MANY trucks and seen MANY different setups. Dont overthink this shit, box the rear and call it a day.
  10. Oct 14, 2020 at 10:53 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    You mean like this?
    joonbug, 831Tun, Vizsla and 1 other person like this.
  11. Oct 14, 2020 at 7:30 PM
    Vizsla
    Vizsla 2 = 2.5
    Haha, think I said that. A little overkill can’t hurt though.
  12. Oct 14, 2020 at 7:39 PM
    Vizsla
    Vizsla 2 = 2.5
    And I did it first, see a few shops trying to copy my junk now lol.
    joonbug, 831Tun and osidepunker like this.
  13. Oct 14, 2020 at 7:44 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Too late. Already over thought and copied Dave's truck. :rofl:
    joonbug and osidepunker[QUOTED] like this.
  14. Oct 14, 2020 at 7:54 PM
    Vizsla
    Vizsla 2 = 2.5
    Yep Warren, if I could explain how much work goes into what you, Joon, and I have done it would be ignored by most. Definitely overkill. I cringe when I see shops removing crossmembers without replacing, then webbing some tube between the added inside plates. :help:
    papasmurf, joonbug and 831Tun[QUOTED] like this.
  15. Feb 21, 2021 at 7:54 PM
    liltrok
    liltrok New Member
    Anaheim, CA
    2nd Gen DC RW
    Does anyone make a frame boxing kit? Or do you have to make your own?
  16. Feb 21, 2021 at 8:00 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I never found a kit. It wasn't too hard to fabricate the pieces but it was kinda labor intensive. There are a lot of ways to screw it up. I copied what I'd seen a fabricator do.
    ColoradoTJ and liltrok[QUOTED] like this.
  17. Oct 31, 2024 at 4:21 PM
    rcsbguy
    rcsbguy New Member
    Pulled the bed off today and @ironrynofabrication is going to box it up. On the RCSB, it’s nearly impossible to box any further up than what I circled. The pass side front by the cab can be boxed, but the drivers side with all the fuel stuff, we can’t touch. Too much stuff in the way. Very, very awkward angles. More pics tomorrow. Also will add 2 front bed mounts and support under the bed to keep the bed from cracking.
  18. Nov 2, 2024 at 8:53 AM
    rcsbguy
    rcsbguy New Member
    Done. We tied into the factor x braces / crossmembers. Was that right or wrong? No idea. But does it drive 1,000 times stiffer and does my bed no longer bounce? Yessir!
    BTW we dropped the fuel tank and boxed it all the way up. It was 100% worth doing, tank only needs to come down a few inches. Then fireproof blankets and fire watch standy.
    I dont have a finished photo of everything, these are all 70% done or less photos.
    Work done by @ironrynofabrication
  19. Nov 5, 2024 at 5:39 PM
    #49
    rcsbguy
    rcsbguy New Member
    2mchfun and Vizsla like this.
  20. Nov 5, 2024 at 5:58 PM
    #50
    centex
    centex New Member
    Boxing frames is old school stuff. Goes way back in hot rodding. It definitely adds stiffness and structure to the frame and I recommend it.
