Garage solutions (when Tundra won't fit)
Discussion in '2.5 Gen Tundras (2014-2021)' started by TundraLuv, Jul 6, 2018.
  1. Jul 7, 2018 at 6:22 AM
    #61
    sprtbkr
    sprtbkr Average Member
    Scott
    Denver, CO
    2018 Tundra SR5 4x4 Double Cab - Inferno
    TRD Wheels & Tires, Double Cab Fold-down Back Seat mod, LED Interior Lighting, Turned Off Seat Belt Chime, Franken-key (Flip Key), Duraliner Bed Liner, Bed Rails, Hood Wind Deflector, Console Gun Safe, iBoard 5" Running Boards, TRD Sport Bed Vinyl, Fortin Evo One Remote Start with Mycar Cellular Module, Plasti-dipped Badges and Bumper End Caps, Tinted front windows, Extang Solid Fold 2.0, Pop-N-Lock, TUNDRA tailgate inserts, RCI Powder Coated Skid Plate - coming soon - 12” android radio, oemaudio+ Reference 500Q, under dash/seat lighting.
    Pudge likes this.
  2. Jul 7, 2018 at 6:22 AM
    #62
    Not a bad option.
    @1UPPER should have some good ideas.
    Pudge likes this.
  3. Jul 7, 2018 at 6:28 AM
    #63
    NCinCO
    NCinCO Is it Friday yet?
    Gary
    Thornton, CO
    2018 Smoked Mesquite Limited CM TRD
    Sounds like moving was the right choice. Unless you are absolutely tied to the house, family pass down, etc., It wouldn't be financially beneficial to do what you were wanting. The cost of the additional changes is where the legs would be chopped off.
    We've thought about adding a garage door to the back of ours for a drive through feature. Like you, that idea went out after we started looking at how much yard space we would loose. Nope, nope, and nope! I like my yard.
  4. Jul 7, 2018 at 9:25 PM
    #64
    TundraLuv
    TundraLuv [OP] New Member
    Kent
    IA
    2018 Midnight Black Metallic Limited Crewmax
    I live in a HOA and the houses look all fairly similar. It's a great idea but I don't know if I could get away with it. Ramps should be here Monday, going to try that first although long term not ideal to pull up on a ramps everytime.
    Pudge[QUOTED] and 4x4_Angel like this.
  5. Jul 8, 2018 at 5:49 AM
    #65
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Thats what SHE said!
  6. Jul 8, 2018 at 5:57 AM
    #66
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Ok one Sexual pun and then on to being serious. Sometimes it’s a gift to be a few inches long. Lol
    I don’t have a simple solution for this one. Can you send some pictures of the backside of the garage? If you try to retrofit the garage door it’s going to be a pain. My first idea is to do a small extension on the back side of the garage. I’ve got an idea but I need to see the back of the garage and the inside wall on the backside as well.
  7. Jul 8, 2018 at 6:04 AM
    #67
    4x4_Angel
    Bree
    Funky Town, Texas
    All that matters is you know how to use it...
  8. Jul 8, 2018 at 6:52 AM
    #68
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Thanks for that lol
  9. Jul 8, 2018 at 7:31 AM
    #69
    TundraLuv
    Kent
    IA
    Will do when I get home tonight.
    1UPPER[QUOTED] likes this.
  10. Jul 8, 2018 at 1:19 PM
    #70
    TundraLuv
    Kent
    IA
    Here are the updated pictures. truck flush with wall2.jpg front of garage door.jpg
  11. Jul 8, 2018 at 1:20 PM
    #71
    TundraLuv
    Kent
    IA
    Here is the updated distance by parking flush up against the wall. updated back of garage pick.jpg
  12. Jul 8, 2018 at 1:50 PM
    #72
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    wow! no room for errors.
  13. Jul 8, 2018 at 2:46 PM
    #73
    4x4_Angel
    Bree
    Funky Town, Texas
    :eek::eek:that sucks:( hopefully @1UPPER can help you out!
    T-Rex266 likes this.
  14. Jul 8, 2018 at 2:59 PM
    #74
    Pudge
    CT
    Tight like prom night. Gonna take some serious work if those ramps dont work out.
    Mountun Goat and 4x4_Angel like this.
  15. Jul 8, 2018 at 3:04 PM
    #75
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    That’s what I did and mine fit perfect.. snug all the way to the wall but it fit
    NCinCO[QUOTED] likes this.
  16. Jul 8, 2018 at 3:07 PM
    #76
    TundraLuv
    Kent
    IA
    Tried backing it in the other night. No luck, still sticks out.
  17. Jul 8, 2018 at 3:08 PM
    #77
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
    you can try these wood look barn door shower curtains. ;)
    maybe cut sheet rock in that area and make a box bumper to fit into.Screenshot_20180708-180507.jpg
    4x4_Angel likes this.
  18. Jul 8, 2018 at 3:28 PM
    #78
    Trooper2
    JR
    Houston, TX (Suburban South)
    Rip out the sheet rock to the studs, gain 1/2"! Only around the front bumper area....... :)
    I believe the ramps will work, but curious how you will fix them to floor so they do not move???
    An elevated slab or (step up)in front may work well also, maybe 3-4", or how ever tall the ramps are.
  19. Jul 8, 2018 at 3:37 PM
    #79
    TundraLuv
    Kent
    IA
    Ramps will be here Monday. I'm not sure yet how I'm going to make sure the ramps don't move. My girlfriend still has to get her car next to mine.
  20. Jul 8, 2018 at 4:23 PM
    #80
    Professional Hand Model
    Hand Protectors
    Quick! Some one grab a garage extender!
    Serious note: No (easy/cheap) fix for this. Cheapest is take off back bumper. Most expensive is add a few feet to garage. Somewhere (in the middle closer to cheaper) is head of those studs at the front bumper (with a header like over load bearing doors and windows) to create a niche for your bumper to pull into. Max this will gain you is 1/2” plus 3.5” for a total of 4”. This will take your bumper right up to the backside of your kit cabs drywall. Only a 1/2” of drywall between your bumper and the kitchen.
    This leaves no margin of error for accidents. You may also have plumbing in wall that will prohibit doing this.
    Quick! Someone grab the truck shrinker!
    TundraLuv[OP] and aRabidLunatic like this.
  21. Jul 8, 2018 at 4:42 PM
    #81
    RickC
    RickC NOT a new member
    Rick
    Knoxville TN
    2017 CrewMax Platinum 4x4 5.7
    SCS Wheels, Line-X, WeatherTech, UnderCover Flex bed cover
    The easiest fix is to park in the driveway. :)
  22. Jul 8, 2018 at 4:55 PM
    #82
    Trooper2
    JR
    Providing it works, Thinking some 2 x 4's anchored to the floor boxing in 3 sides of the ramps should keep in place.
    The ramps could still be tricky for everyday use. Thinking a bigger hearty wood ramp structure anchored to floor would be a more permanent solution.
    Pudge likes this.
  23. Jul 8, 2018 at 5:05 PM
    #83
    @1UPPER can build you something or guide you in the right direction. I wish he was in CO. I would have had him build my house.
    4x4_Angel and 1UPPER like this.
  24. Jul 8, 2018 at 5:08 PM
    #84
    NomadicFrog
    NomadicFrog Took 5 yrs, finally got rid of "New Member" here
    Mark
    Flagstaff, Arizona
    2003 Tundra SR5 4x4 TRD Off-Road Access Cab
    First mod: Gaffer tape over door lock/unlock beeper
    Why not just embrace this solution? Put a pass-through hole there so you can admire your Tundra while you do the dishes!
  25. Jul 8, 2018 at 6:16 PM
    #85
    1UPPER
    TEXAS
    Flux capacitor!
    Thank you very much for the complement! When OP can add some photos of the back of the garage I can see if he has some other options.
  26. Jul 8, 2018 at 6:33 PM
    #86
    TundraLuv
    Kent
    IA
    Here you go 1upper.
  27. Jul 8, 2018 at 6:47 PM
    #87
    1UPPER
    TEXAS
    Flux capacitor!
    Can you send pics of the very back wall inside and outside of your garage? I’m trying to determine if you can install a header along the back wall and do a small addition to the back of your garage.
    ColoradoTJ, 15whtrd and T-Rex266 like this.
  28. Jul 8, 2018 at 6:51 PM
    #88
    Coolhardy
    Coolhardy New Member
    Harris
    2014 black tundra
    Too many to list
    U either have 2×4 or 2 x 6 in your garage wall. Rear bumper sticks out good 3-4 inches as compared to front bumper. What if u cut the 2 x4 right at above the height of the rear bumper and support it little outside the width of the truck. I m pretty sure there is no load bearing joist running that way.
    Now u should be able to gain the 3-4 inches that u need. U just have to reverse your truck in the garage everytime but u have the back up camera.
    Would that work?
  29. Jul 8, 2018 at 7:18 PM
    #89
    TundraLuv
    Kent
    IA
  30. Jul 8, 2018 at 7:19 PM
    #90
    TundraLuv
    Kent
    IA
    additional pics.
