GEN 3 (2022+) Wheels and Tires Photo thread
Discussion in 'Wheels & Tires' started by Tsquare, Jan 16, 2022.
  1. Jun 15, 2023 at 2:29 PM
    #3301
    Jinkx
    Jinkx New Member
    Keith
    2022 Tundra SR5 with TRD package
    Air filters//Exhaust//Level kit//Tires and visual accessories
    my poke 20x9 +1
    Wanted to add I did have to move the front rear wheel well liner back barely rubbed there with the +20 I prob would have cleared but I was ok with that due to want poke and easy fix !
  2. Jun 15, 2023 at 2:30 PM
    #3302
    Jinkx
    Jinkx New Member
    Keith
    hope all this helps
  3. Jun 15, 2023 at 2:32 PM
    #3303
    SR72
    SR72 New Member
    Devin
    2025 Tundra TRD Rally Ice Cap White
    OEM tonneau cover, door edge guards, all-weather mats and spray on bed liner.
    For sure man. I had the Terra Grappler G2s on my Ram 1500. Great tire, but once I saw how much more aggressive the Recon was I knew I had to have them. Spend the extra money for the Nittos and you won't have any regrets long-term
    Lucky0402 likes this.
  4. Jun 15, 2023 at 2:39 PM
    #3304
    Jinkx
    Jinkx New Member
    Keith
    luv lol
  5. Jun 15, 2023 at 3:43 PM
    #3305
    Jinkx
    Jinkx New Member
    Keith
    ST72 Yes sir that what I did.
    Nitto Recon Grappler 315/60/20
    57 lbs lol luv them!!!!
  6. Jun 18, 2023 at 7:54 AM
    #3306
    Tundra17944Ever
    Tundra17944Ever ‘16 Limited to ‘23 1794
    Tom
    GA
    2023 Tundra CrewMax 1794 TRD 4x4
    Fuel Rebel 6 Bronze 20x9 +20 Nitto Recon Grappler LT295/60R20 PRO fender flares color matched and wired Fox suspension from TRD Pro TRD Pro shift knob Grille surround color matched CBI Covert bumper with bull bar Rear bumper arms color matched BakFlip MX4 tonneau cover WeatherTech mats Gloss black window trim TT cat shield Black TRD grille Tufskinz tailgate letters Tufskinz TRD logo and stripes Tufskinz door sill protector Center console safe TWC 5” exhaust tip TWC slip-on exhaust TWC titanium valve stem caps Beat Sonic amp TRD air filters Diode Dynamics amber fog lights Color matched digital camo fog light bezel OEM Dashcam
    @Jinkx well the day finally arrived. Thanks to your pics I just had to have them.
    Ohbewan23, Lucky0402, vichmr and 13 others like this.
  7. Jun 18, 2023 at 8:10 AM
    #3307
    4mm
    4mm New Member
    Francisco
    2015 Sequoia
    Awesome colors
  8. Jun 18, 2023 at 10:30 AM
    #3308
    Tundra17944Ever
    Tom
    GA
    Thanks!
  9. Jun 18, 2023 at 10:35 AM
    #3309
    Jinkx
    Jinkx New Member
    Keith
    Tundra 1794 BEAUTIFUL BROTHER.
    Luv the Bronze with the brown,
    I don’t have to even ask I know you’re in luv lol.
    And the caliper covers to top it off.
    Hell yes AWESOMENESS
    ummmmmm DETAILS
    Rim size
    Off Set
    Tires
    How dare you leave us hanging lol
    Your body lines pop in that color.
    Looks like your lifted??
    Again luv it brother good job!
    Not to give you more ideas
    I just did the RC 4 inch lift
    Luv it. The ride is factory like.
  10. Jun 18, 2023 at 10:43 AM
    #3310
    Jinkx
    Jinkx New Member
    Keith
    couple pics in case u need more ideas lol
  11. Jun 18, 2023 at 11:07 AM
    #3311
    Tundra17944Ever
    Tom
    GA
    Thanks!
    Details:
    Fuel Rebel 6 20x9 +20
    Nitto Recon Grapplers LT295/60R20
    RC 1.75” front and 1” spacer in the rear
    I saw your Ready Lift 3/1 for sale. If I wasn’t already lifted I’d get it from you.
  12. Jun 18, 2023 at 11:49 AM
    #3312
    Jinkx
    Jinkx New Member
    Keith
    You have the perfect setup if don’t want any rubbing and don’t want to have to modify anything in the wheel well. They should make this a standard post for others wondering what size
    Anything in 18/20 Rim diameter
    Width 9 inches
    Tires 295/70/18 or 295/60/20
    +18 to +20 Offset
    Both come out to about 34.5 diameter
    Tread 9.5 to 9.0
    Section width 12.2 to 11.8
    neither size will rub and both will give you about 1/4 inch of poke of tread not figuring in the sidewall.
    A +1 Rim will give you about 1.5 inch of poke or to make it simple it will expose the first tread block on most tires
    This should answer most questions about wheel and tire sizes. Yes you can fit more tire. But neither one of these requires any mods to wheel well liners or crash bracket removal
    Tom likes this.
  13. Jun 19, 2023 at 6:21 PM
    #3313
    Boatracer
    Boatracer New Member
    2023 Limited 4x4 hybrid
    Ok, in an effort to give back. I am half way through about 4 days of looking at data, pictures, and products.
    2023 Limited 4x4 Longbed Hybrid
    Stock were 265/60-20 with 20x9+60mm offset
    Now Weld Racing Roll Formed 20x9 with +20mm offset
    1. Buy a light wheel. The Fuel and all those cast wheels are insanely heavy (pick one up)
    2. Toyo Open Country R/T 35x12.50
    3. First pictures with them absolutely stock 4X4 suspension
    A. They do not hit anywhere (tire shop amazed) but they are really too close to run full time like this
    B. The truck is geared a bit different and yes, manageable but noticeable (of course)
    4. Next week I am installing the Rough Country kit that is 3.5 Lift complete with rear struts, Upper Control Arms (UCAs), 1” diff drop, skid plates
    I’ll add more pictures but here are enough for you to consider for your build. I’ll lastly say when you lift buy 3.5” in the front, the front A-Arm swings down (to lift truck) and the front wheel will rock in a little bit. If you use a +20mm offset on a 9” wheel and 12.5 width tire, it is further from the truck (sits more outboard than stock) so it will swing back to around original inside tire position. If you are considering 3.5” or 3” slugs, they may do more to geometry in the front end than just clearance issues. I hope this helps.
  14. Jun 19, 2023 at 7:54 PM
    #3314
    Dan33108
    Dan33108 New Member
  15. Jun 19, 2023 at 8:07 PM
    #3315
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    At 0 offset, you can expect several inches of poke.
    Your OE wheels are +60 offset and narrower so nearly 3” different than the ones in the link.
    Ideal offset for no poke would be around +30.
    If you wind up with a lot of poke, you can add some wider fender flares to even things out.
    Tom likes this.
  16. Jun 19, 2023 at 8:21 PM
    #3316
    Boatracer
    Dan, your new tires are 20mm wider than stock, so that means 10mm extra “poke” (half the 20 on side), but thats with a +60mm backspace on your stock wheels, so essentially +50 (60- 10) gets you to where you are, and then just measure your stock tire and how far further out you want the tire to be to your satisfaction. I agree that it’s about and inch to the edge of the fender to be flush, which is 25.4mm, which translates to 25mm (50-25 = +25mm) to bring your 20x9s with a 285 tire to edge of the fender. Keep in mind that as you raise the truck, the front wheels will swing in toward the truck, so stock height PBNB is spot on, but if you level the truck an inch or two up front, +20mm.
    If you use those +0 20x9 wheels and 285mm tires, and don’t level the front, I’m gonna guess it’s 1.25 too wide if you don’t level the front, and just under 1” too wide if you do level the front.
  17. Jun 19, 2023 at 8:29 PM
    #3317
    Boatracer
    Here’s mine now before I raise 3.5” up front. Rear will stay the same because it’ll drop the axle straight down (no A-arms).
  18. Jun 19, 2023 at 8:30 PM
    #3318
    Boatracer
  19. Jun 19, 2023 at 8:43 PM
    #3319
    Boatracer
    Here are all three comparisons. You can go measure fro the side wall on currrent tire to how far you want it our there. All the math is done.
  20. Jun 19, 2023 at 8:45 PM
    #3320
    Boatracer
    Here’s mine for those interested.
  21. Jun 19, 2023 at 9:06 PM
    #3321
    Jinkx
    Jinkx New Member
    Keith
    BoatRacer
    Sure you may have a lighter wheel (can’t find weight on Weld)
    Totally understand trying to keep weight down
    but your tire choice is 70 lbs!
    Not saying anything bad but you’re much better off going a lighter tire then a lighter wheel because the tire is the farthest from the hub.
    Your rim choice is the perfect size for about a 1/4 of tread poke.
    My fuel wheels Rebel 6s
    were 39 lbs
    My tires 315/60/20 SL Recon Grapplers
    We’re 57lbs
    Total 96 lbs
    YOUR Tires are 70lbs
    Let’s say your rims are 30 (can’t find lbs on welds) that puts u at
    100 lbs.
    My tire is a little wider then yours and taller but not by much. Just a diff approach. Not easy finding a true light weight wheel that doesn’t cost a fortune!!!! Hence why most truck people don’t buy them as it’s already a huge expense.
    Nice truck brother we have similar color choices :)
    Boatracer likes this.
  22. Jun 19, 2023 at 9:16 PM
    #3322
    Jinkx
    Jinkx New Member
    Keith
    luv the white
    BoatRacer
    I’m selling a 3/1 ReadyLift kit with control rms and rear shocks if your still looking :) 3gen Sales sec!
  23. Jun 19, 2023 at 9:52 PM
    #3323
    YF19EX
    YF19EX New Member
    2023 Tundra TRD Pro Solar Octane
    Diamondback SE Cover, Talons Cat Plate, Go Rhino D1 Steps
    Welp, I got a screw in the rear tire edge of my (OEM) Falken Wildpeaks. Went and plugged that but I don't want to drive on it for long. Although the OEM Wildpeaks handled well, and even got me though some snow, I did want to upgrade them eventually.
    Also, I think my TRD Pro suffers from the premature tire wear the factory alignment gave us. It feels even at 6200 miles, the tire outer edge is wearing heavily.
    I went and bought a new set of Nitto Recon Grapplers in 295/70R18 116S. Most of my off-road excursions are trails and some hills at best, so I decided to go with the lighter version of the tire. I'll post picks as soon as the job is done.
    Siopao, KClav and kilocharlie106 like this.
  24. Jun 20, 2023 at 2:07 AM
    #3324
    Jinkx
    Jinkx New Member
    Keith
    Very smart move probably the best all around tire size! Especially for stock wheels. Run them at 35 psi that’s it!
    That’s straight from Nitto
    I run my 315s SL at 35 so far perfect wear and I chalk tested them even contact
    Sounds like your old tires may have been under inflated for outer edge wear or you’re driving hard into corners lol.
    Def send pics and don’t panic when u see them they will clear. They look HUGE off the truck but these Tundras just eat that size up… Be prepared to smile !!!!
    One Neg is you will lose about 2 mpg but to me it was soooooo worth it when u see them. You’re going to wonder why Toyota ever put 265s on stock. Well prob for fuel mileage lol.
    BUT when I put on my 315/60/20 SL and took off my 305/70/18s Load Range E I actually went from 16.4mpg to 18.8 seriously.
    Two reasons one the lbs savings and To the SL tires are a harder tread so less rolling resistance then a Load range E.
    For those who don’t know in the Nitto Recon Grapplers the SL is the exact same tire but it’s 6 ply instead of 10/12 ply in like a E load rating.
    Very very few of us need a E or F load range tire. In fact only max haulers or max towers or serious off road need anything that heavy again that’s straight from Nitto. So why do they make them Supply and Demand. Good luck can’t wait to see and hear you when there in brother!
    Black widow TRD and YF19EX like this.
  25. Jun 20, 2023 at 2:25 AM
    #3325
    Jinkx
    Jinkx New Member
    Keith
    DAN To make it simple for u a 0 or +1 will give u about 1 to 1.5 inch of poke or more simple the first tread block on your tires on average…A + 15 to +20 offset will give you about a 1/4 inch of poke…
    BoatRacer gave great info but it can become overwhelming lol trust me there’s a reason I know this. Spent 2 months is studying rims and tires before choosing. First pic +1 poke second +20 poke.
  26. Jun 20, 2023 at 4:55 AM
    #3326
    Boatracer
    I’ll add this. After you get your lift right, bolt on spacers are super safe and cheap (used by ford and Dodge on all front of 4x4 duallys that are 3” thick). It’s a great way to move them out, or back in a bit. I am contemplating color matched 2” flares and may use a set. My taste is not to shoot the side of the truck in tire shine or mudd (but it looks good on somebody else’s truck LOL)
  27. Jun 20, 2023 at 5:21 AM
    #3327
    Jinkx
    Jinkx New Member
    Keith
    Be careful with spacers though. If the dealership sees them and let’s say you have a worn out wheel bearing, front 4x4 has issues or brakes show premature wear it can void your warranty…
    My experience has been dealerships don’t care to much about lifts as long as it’s not extreme (over 4 inch) …Many sell them on new trucks as an add on.
    I asked my dealership before I put my 4 inch on and they said no problem especially because I still use the stock springs and struts in the front and Rear springs in the rear. So my angles like on the upper control arms is not changing. It’s in the factory location basically because my spinndle was changed not my upper control arm.
    I did not need an alignment post RC 4 inch lift it was in specs so it must be keeping everything close to the factory specs!
    Im Not a fan of pushing the wheel out with spacers but that’s just me I know it’s done all the time!
    Do your best to get the right wheel and avoid spacers unless you’re stuck on getting a wheel pushed out and you don’t want to change wheels.
    Jyst diff of oppinion and that’s why this site is great we can all learn something!
    Siopao likes this.
  28. Jun 20, 2023 at 6:50 AM
    #3328
    daveneezy
    daveneezy New Member
    CT
    2023 Lunar Tundra TRD Sport
    Since you guys are discussing poke, maybe you can help me. I’m considering the SCS Blaze 10 in 17 x 8.5 with -10. Is my biggest disadvantage too much poke with this set up? This is going on my sr5 trd sport after I do the Cornfed 3/1 kit.
  29. Jun 20, 2023 at 7:01 AM
    #3329
    FLKX
    FLKX New Member
    Vossen HF6-4 9.5 +30 (35 lbs) with lightweight 275/65R20 RIV Scorpion AT tires (48 lbs).
    Sitting at -0.3 camber all around... no poke!
    Fast and smooth at 83 lbs per corner.
    ncart and cellphoneyoda like this.
  30. Jun 20, 2023 at 7:01 AM
    #3330
    Tom
    Tom New Member
    Just imagine 3-4” poke on each side
